6th August 2006, 04:59
#3
2001 BMW M5
Originally Posted by ECB
From the manual:
You can respond to unpleasant external odors by temporarily excluding the flow of outside air. The system then recirculates the air currently within the vehicle. By repeated actuations of the button, you can select one of three different operation modes.
Indicator lamps off: outside airflow operational
Left-hand indicator lamp on – AUC mode: the system recognizes pollutants in the outside air and blocks the
flow of air when necessary. The system then recirculates the air currently
within the vehicle. Depending on the air quality, the automatic system then switches back and forth between outside air supply and recirculation of the air within the vehicle
Right indicator lamp on – recirculated-air mode: the flow of external air into the vehicle is permanently
blocked. The system then recirculates the air currently within the vehicle.
So it can tell if someone farted outside my car huh? Thats incredible.
