Old 5th August 2006, 19:38   #1
Jayson
Jayson's Avatar
Garage: m5
Send a message via AIM to Jayson
Troubleshooting stalling?
I've had this happen a few times recently. Say I pull out to turn or pull out a parking space I'll step on the clutch to and it will just stall out. Any ideas? Clutch sensor?
Jayson is offline
Old 5th August 2006, 20:38   #2
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
did you get a software change when you did the dinan flywheel? Should raise the idle speed to 800rpm with the lighter flywheel. I would bet that is is if you still have the stock idle speed.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 5th August 2006, 23:51   #3
imolaman
imolaman's Avatar
Garage: 2001 BMW M5 Imola Red
Send a message via MSN to imolaman
It sounds like the stalling is most prevalent when you turn the wheel at low engine speeds. I'll take a stab in the dark and say to check your power steering pump. If it's faulty it might be pulling excessive power from the engine hence causing the stalling.
Would be interested to hear the outcome. Please keep us posted.
Rudi
2001 Imola Red II E39 M5 - Stock
imolaman is offline
Old 6th August 2006, 00:11   #4
Jayson
Jayson's Avatar
Garage: m5
It's not when it sitting still, it's when i get moving.
And the power steering seems to work just fine.
Jayson is offline
Troubleshooting stalling at idle in Sport mode? angusf E39 M5 and E52 Z8 Discussion 22 11th September 2006 10:35
Troubleshooting engine stalling...? Schex E39 M5 and E52 Z8 Discussion 17 25th August 2006 00:37
Troubleshooting stalling on cold start after cleaning MAFs? JLH E39 M5 and E52 Z8 Discussion 2 4th August 2006 03:43
Troubleshooting random stalling while coasting? MatthewS E39 M5 and E52 Z8 Discussion 11 26th June 2006 06:24
Stalling Issue - unsolved maxm5 E39 M5 and E52 Z8 Discussion 9 24th February 2006 13:17
Page generated in 0.09449 seconds with 11 queries
