Old 9th July 2006, 16:16   #1
AFX
Garage: E60 M5 Black
Troubleshooting cold engine hestitation/power loss? (not the MAF's/no error codes)
Well, this is the second time I change my MAF's, but this time the problems did not go 100% away.
On cold engine, the car is still hopping/wont run smooth by just driving steady at a fixed speed. This problem disapears when the rpm light goes out for 4' and 4.5' rpm.
Other thing is that I still are short of power. Can't get it to just spin by rolling at 1000-1500 rpm and floor it (yes, the DSC=off).
The ppl at the local dealer (man, they're knowledge sucks) says nothing is wrong according to their read outs from the engine (ever heard that before?).
So now, I'm giving up. The "specialists" on M-engines in Norway is 1800 km away, and that's to far away... And I cant just keep on changing parts as they're quite expensive in Norway.
Anybody with some really good ideas on what to look for?
Any measurements that can be done for compare that I could post here?
You guys are my final hope...
AFX is offline
Old 9th July 2006, 16:29   #2
gobuffs
gobuffs's Avatar
Garage: Chiaretto Red 02 M5
So it runs better once it is warm(er)? I would check the coolant temp sensor and wires (but that is a guess from similar symptoms on S14s).
gobuffs is offline
Old 9th July 2006, 16:45   #3
AFX
Yes, when the 2 first leds at the rpm instrument goes off then she runs smoothly again. But still, the spinning is out of the question. I would loved to have her dyno'd to see what she performs now...
AFX is offline
Old 9th July 2006, 17:03   #4
imolaman
imolaman's Avatar
Garage: 2001 BMW M5 Imola Red
Send a message via MSN to imolaman
AFX,
I would remove the spark plugs and check for excessive wear. AFAIK worn plugs would not always throw a code on the DIS, but would definitely affect performance adversely.
Also have a look at the condition of your air filters. You did not say when last she had a service, so worth checking.
Of course, more unlikely, but you could have been sold a factory defect set of MAF's. Check DavidS' post on how to test them, if you have not done so already.
I hope this might point you in the right direction.
Rudi
2001 Imola Red II E39 M5 - Stock
imolaman is offline
Old 9th July 2006, 17:08   #5
AFX
Originally Posted by imolaman
AFX,
Rudi
I will check the spark plugs tomorrow then.
Air filters are ok, replaced them in May. Also did the Inspection II at the same time. The MAF's did I get from DavidS. But of course they could be defect, but I doubt that. The hesitation of the cold engine has "always" been there, it's just less noticeable just after I replace the MAF's.
But thanks for the tips; I will check'em up!
AFX is offline
Old 9th July 2006, 21:39   #6
Beamer_usa
Beamer_usa's Avatar
Garage: explosive ford pinto
The top three culprits would be MAFS, Spark Plugs, and O2 sensors (4). I would replace all three of those first and see if that solves your problem. If not then at that point you must dig deeper and spend more $$$. Unfortunately $tealers are the same world round! Clueless Keep us posted and good luck!
Dinan Cans
Dinan Software
Beamer_usa is offline
Old 9th July 2006, 23:53   #7
Red line
Garage: '02-M5 Imola Red
Might be a bad fuel injector. an engine requires more fuel to run smoothly when it is cold. Some cars have an extra fuel injector that works only at startup to cure the problem.
'99 Ferrari 550.
'02 E39 M5 Imola Red. Sold.
'93 Dodge Viper R/T-10. Sold.
'92 Corvette ZR-1. Sold.
Red line is offline
Old 10th July 2006, 00:01   #8
AFX
Well, this is a dummies question; the O2 sensors; is this the sensors located just before and after the catalysts?? Honestly; I don't know...
AFX is offline
Old 10th July 2006, 00:53   #9
jclyman
jclyman's Avatar
Suggestion: My car has had a hesitation when cold since new (there is a slight hill about 100 yards from my house where it shows up). I used to wait to turn the Sport button ON until it warmed up. Now, I set Sport ON immediately and NO hesitation. Never any hesitation anymore (46,000 miles).
- Daniel Boorstin
jclyman is online now
Old 10th July 2006, 00:54   #10
jclyman
jclyman's Avatar
Yes, 2 before and 2 after.
- Daniel Boorstin
Long and technical: thoughts on cold air intakes and temp sensor relocation greg E39 M5 and E52 Z8 Discussion 48 4th August 2006 10:23
Can't go into first gear when engine is cold Tony Chien E39 M5 and E52 Z8 Discussion 10 30th March 2004 00:01
Servey: Will you let yourself being tempt to race when the engine is cold? Joxer E39 M5 and E52 Z8 Discussion 20 22nd March 2001 03:28
Page generated in 0.16080 seconds with 11 queries
