Old 9th July 2006, 06:17   #1
sdietric
Garage: M5 Blue
Advice how to remove the rear door panel?
I started today to replace my stock speakers with two sets of MB Quart speakers. Driver door, complex, but no major problems, but rear door, I could not get the panel off. It seems like connected somewhere in the middle, and the instructions I found on the web say it is removed just about the same way as the front door panel.
Anybody having experience removing the rear door panel? Is there a difference because I have the sliding rear curtains?
sdietric is offline
Old 9th July 2006, 09:47   #2
Habu
Garage: E39 M5 TiAg
Sales Feedback: (3)
sdietric,
You shouldn't have any problems removing the door panel. Take the switch and the light out. Undo the door handle and twist it so that the panel come out. Pop the clips out around the perimeter of the panel then lift up.
I don't have the rear curtains so there may be another clip that needs to come out.
Bob
Habu is offline
Old 9th July 2006, 16:47   #3
sdietric
Garage: M5 Blue
rear door panel must be held by something related to the curtains
thanks for the answer, and yes, that's exactly what I did.
I have been doing quite some wrestling with the door panel, normal plastic clips would have broken with that amount of force applied. There must be some kind of metal screw or clip that it holding the door panel in place.
I really assume it is related to the curtains, they were recently replaced at BMW, they didn't seem to have any problems taking the panel off, but now, I just wanted to replace the tweeters...
sdietric is offline
Old 9th July 2006, 17:15   #4
ECB
ECB's Avatar
Garage: 03 Titanium silver M5
Here are some pics a fellow member posted a while back:
http://www.louv.tv/cars/m5/leakydoor/leakydoor.html
I replaced my speakers earlier this year and didn't notice much difference between front/rear door panels but I don't have the sun shades either. Good luck.
ECB is offline
Old 10th July 2006, 13:56   #5
sdietric
Garage: M5 Blue
which glue to use for the vapor barrier
Great. These pictures were very helpful, thanks so much. I missed the two screws hidden behind the top strip.
One question, the vapor barrier seems to be slightly glued sometimes, but loose other times. Does it need to be glued all around.
If yes, which glue to use?
sdietric is offline
Old 10th July 2006, 15:32   #6
ECB
ECB's Avatar
Last year I had a vapor barrier seal fail and water was leaking into my passenger side rear footwell. My car was still under warranty so I let the dealer fix it. If you search, I believe there is a complete write-up on how to do it and what to use to seal it. But if you are not having any water leakage it must be doing its job. Sorry for no help.
ECB is offline
M5 E39 Body Style S62 engine FACTS...Long V-10 4 Me E39 M5 and E52 Z8 Discussion 53 22nd March 2009 16:12
Autocar: M5 beats Ferrari F430 Just_me E60 M5 and E61 M5 Touring Discussion 204 10th October 2007 17:24
BMW M6 Convertible Press Release 1: Design, Body, Features. (in English and German) Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 2 22nd June 2006 23:34
Possible to remove M-Audio Subs w/o taking apart the rear deck? 04ImolaZHP E39 M5 and E52 Z8 Discussion 16 10th June 2006 16:41
Ride Height pics of H&R29441 and 'custom' rear springs OldRanger E39 M5 and E52 Z8 Discussion 9 24th June 2005 05:34
Page generated in 0.12185 seconds with 11 queries
