• Latest threads
    • Custom feed
      • News
        • Updates
          Old 4th July 2006, 05:58   #1 (permalink)
          gtobynj
          gtobynj's Avatar
          Was it the VW MAFs or wasn't it?
          And should I put them back on?
          The usual MAF type problems, hesitation, rough running when cold, yada yada, etc.
          Bought some Radio Shack electronics cleaner and cleaned my MAFs. Night and day difference, or at least night and dawn - much better, but not quite 100%, so ordered the VW MAFs.
          Installed 'em and got my 100%. 250 miles later, SES light and I am on reduced power (not limp home, but boomy and a bit under the weather). So I swap the BMW MAFs back in and after 200 miles or so, the SES light goes off.
          In the meantime, I had booked her an appointment with the quack. They pull the codes and get something they told me they (said) hadn't seen before "caused by 0000005/4 1214710/4" which relates to a pre-CAT O2 sensor.
          BMW SIB 12-07-04 related to this particular error code and required re-programming of the DME, which was carried out.
          SO:
          Was the error caused by installation of the VW MAF?
          Was the error triggered by the VW MAFs "NEW" status, but not going to be an ongoing issue?
          Do I put the VW MAFs back on - they seemed (butt dyno) to smooth out the engine a provide more linear power.
          Opinions please?
          gtobynj is offline
          Old 4th July 2006, 06:05   #2 (permalink)
          gsfent
          gsfent's Avatar
          SO:
          Opinions please?
          Unlikely it was the VW MAF's. Lots of folks here have used them with good results. I would guess you have a CPS starting to go bad. That will give a bunch of different false codes, including a bad O2 sensor, and sometimes a bad VANOS. I would reinstall the VW MAF's. It may take the car a couple hundred miles to adapt to the new MAF's.
          Dinan Stage3 suspension and CAI, SS jet coated headers, Evosport UD pulley kit, IATS, PC Gold 93, open brake ducts, Hamann front splitters, TEC cupholder, Euro tilt/slide armrest, 6k HID fogs, 6k super white low beams, V1/Stealth1, 2.65 diff w/40% lockup/2x dynamic, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit
          gsfent is offline
          Old 4th July 2006, 12:12   #3 (permalink)
          Mattkins99
          Mattkins99's Avatar
          Well, if your O2 sensors were bad, it would make sense that the bad MAFs would mask the problem.
          Matt Atkins
          President Seattle5s (Puget Sound E39 SIG)
          http://www.seattle5s.com/
          '01 Lemans Blue M5 :-)
          -Dinan CAI
          -Dinan Stage 2 software
          '94 Green Pathfinder SE :-|
          Mattkins99 is offline
          Forum Jump
          How to test the MAFs yourself and How MAFs work DavidS E39 M5 and E52 Z8 Discussion 359 11th October 2008 06:37
          POLL: VW MAFS? YEA! or NEA! Beamer_usa E39 M5 and E52 Z8 Discussion 168 13th March 2008 22:59
          After the VW MAF's, more power but lags in the middle sonicgrounds E39 M5 and E52 Z8 Discussion 1 22nd June 2006 22:30
          VW MAFs & BMW MAFs compared (pictures) Salty E39 M5 and E52 Z8 Discussion 82 21st May 2006 06:07
          MAF's for VW TDI vs M5 AFX E39 M5 and E52 Z8 Discussion 18 12th May 2006 18:34
          Page generated in 0.28977 seconds with 11 queries
