Installing a novelty item...starter button - BMW M5 Forum and M6 Forums
Old 1st July 2006, 21:48   #1
swingkat420
swingkat420's Avatar
Garage: 01 M5 Le Mans Blue
I'm installing a Starter Button...yes yes I know...useless to some, but like I said, more of a novelty item.
Anyways, I yanked out the steering column anyone know which one is the starter wire? there are two green wires and one purple wire, just needed to know which one to tap into.
thanks!
swingkat420 is offline   Reply With Quote
Old 1st July 2006, 22:36   #2
Tozzy
Tozzy's Avatar
Garage: M5 -00 Avus-Blue
The wire that connects to the starter relay is marked with RT in the diagram, That would be Red (Rot in german). Look for connection 5 at the steering column connector, there is often a marking in the plastic near the wire.
Are you putting a big Red button for the starter?
Tozzy is offline   Reply With Quote
Old 1st July 2006, 22:43   #3
suprfknman
suprfknman's Avatar
Garage: 2001 BMW M5 BLACK
Like one of those Staples easy buttons hehe. Sounds like youre playing with fire to me I wouldnt want to mess with any of that wiring these cars have enough problems to begin with. So to use this button you will have to put the key in and turn it to run and then press the button to start or does it have some keyless recognition system where you just keep a fob in your pocket? Will you be bypassing the clutch safety switch?
01 BLK/BLK
05 Toyota Sequoia (for the winter)
04 S55 AMG
05 S4 Cab
91 JZA70 twin turbo supra RHD
suprfknman is offline   Reply With Quote
Old 1st July 2006, 22:52   #4
SC'dKellenersM5
SC'dKellenersM5's Avatar
Garage: Red White and Blue
I dont know of anyone who has actually installed one themselves...but Discovery Automotive has installed quite a few, maybe you can contact them and swindle them to give you some info.
Im in the highspeed aluminum business
SC'dKellenersM5 is offline   Reply With Quote
Old 2nd July 2006, 18:13   #5
gbogh3
gbogh3's Avatar
Garage: 02, M5 Sterling Grey
Sales Feedback: (3)
If you do bypass everything, would you still be able ot use the 'code' feature in the computer? I would guess not since there will no longer be a #2 position for the key?
Why don't you just glue the key in?
Although I must admit it sounds very cool, just wondering about some of the functions you may loose?
2010 X5 3.5 diesel, dialy driver, loaded, Awesome Car!
2002 E39 M5 Sold
2004 X5 4.8is Sold
2005 X5 3.0 RIP
1995 E36 325i Sold
1989 E30 325i RIP
1972 3.0s Sold
gbogh3 is offline   Reply With Quote
Old 2nd July 2006, 19:02   #6
swingkat420
Not really bypassing anything besides turning the key in all the way to start the car. Hooked up a wire to e-brake (so it won't turnover unless the e-brake is on) and to the ignition wire. It would be nice to keep the key in the pocket, press the clutch and push the button. Rather spend that money into something else. I know most people frown upon putting a push-start unless it was a standard item. I just wanted to do it, just to do it. And no, it's not a big red button.
Old 2nd July 2006, 21:01   #7
cableguy
cableguy's Avatar
Garage: 2003 996 GT2
If it works for you then go for it.
I for one will certainly be interested in how you get on and would love to see some pics when the mod is complete.
C.
2003 996 GT2 - Brutal...
cableguy is offline   Reply With Quote
Old 2nd July 2006, 22:23   #8
Beamer_usa
Beamer_usa's Avatar
Garage: explosive ford pinto
Don't forget to put the key in the ignition every once in a while to keep the key battery charged up
Dinan Cans
Dinan Software
Beamer_usa is offline   Reply With Quote
Old 3rd July 2006, 10:36   #9
tommiexboi
Garage: BMW E46 328I / BMW E39 M5
i love mine and it works great... i'm sure you'll love it
tommiexboi is offline   Reply With Quote
"Accept" button + StealthOne a_ok2me E39 M5 and E52 Z8 Discussion 13 23rd November 2005 17:44
Push button starter gh342000 E60 M5 and E61 M5 Touring Discussion 6 13th October 2005 04:30
traction control button trick ? Hogie E60 M5 and E61 M5 Touring Discussion 5 11th September 2005 23:51
Starter Button? M5_ForMe E39 M5 and E52 Z8 Discussion 6 11th June 2005 18:31
Strange problem with key button to unlock doors... fumaras E39 M5 and E52 Z8 Discussion 2 11th February 2004 03:43
