Old 18th June 2006, 04:44   #1
HOVO
HOVO's Avatar
Garage: Titanium
OEM shigter rubber boot replacement
Hi, i had a quick questions... I cant afford the short shifter kits that are out on market right now so I oppted to buy a replecement plastic boot to get rid of some of the sloppyness from my shifter... anyways before I tear into the car I was wondering, do I need any special tools of some sort to disassemble the shifter and replace the boots and rubber bearing? Im a shade tree mechanic I can do basic overhauls but Im not sure if theres any dealer specific tools that are required... I dont want to tear apart the interior and find out I need to wait and order more tools lol..
thanks in advance.
2002 Titanium M5.
HOVO is offline
Old 18th June 2006, 05:15   #2
ard
ard's Avatar
All hand tools. I think I did a total UUC install, including removing the stock shifter and selector and installing the new with a flat blade screwdriver, allen wrench and plier.
That said, you will likely not find a worn "plastic boot"... just a bunch of 'less than optimally precise' parts.
Check it out- worth an hour to see what the parts look like.
A
ard is offline
Oil filter housing rubber mount broken (also steering servo fluid reservoir) DavidS E39 M5 and E52 Z8 Discussion 15 16th January 2008 16:38
FS: Bosch F00C2G2032 MAF sensors for E39 M5, winter tires, rubber mats, OEM parts MPRESIV For Sale or Wanted 11 3rd February 2006 18:21
UUC direct fit replacement clutch bmwusa E39 M5 and E52 Z8 Discussion 185 14th October 2005 20:51
Help on OEM colours and leather types? M540i LE E34 M5 Discussion 10 13th February 2005 02:20
Another Weak OEM Part. U Joint (Rubber) Kings MotorSport E39 M5 and E52 Z8 Discussion 6 9th November 2004 03:34
Page generated in 0.12899 seconds with 11 queries
