The best engine cleaner! - BMW M5 Forum and M6 Forums
post #1 of 27 Old 10th June 2006, 04:55 PM Thread Starter
whatheheck
whatheheck's Avatar
I did a search and I didnt find any on this subject so here it is.
I'm sure some of you have used Gunk or some other brand of engine cleaner to clean your engine. I have used Gunk engine cleaner on my cars a few times over the years and I hate the residual petroleum smell that stays on the car for weeks. And as the engine burns off the left over chemicals - the smell goes inside your car as you drive. I hate it. And I love my engine clean so I searched for something better.
So, here you go, shared by a friend of mine, the best engine cleaner you can buy. No smell, very friendly to the engine, rubber hoses, plastic, works quick and does a fantastic job. Cost: $2.99 a can and worth every penny.
Scrubbing bubbles! I have used this stuff three times in all my cars and it worked great! I urge you to try and post results.
Spray on directly to a cool engine, let it soak for about 2 minutes, scrub a little bit on areas with caked on grease, then hose the engine off with water, start the engine, let it warm up to dry, walk away, no need to wipe down, come back in about half an hour and check the results, let me know.
Careful always with your electrical connectors, scrubbing bubbles wont hurt it, it's the water that you have to worry about. Dont let the water get in to your Xenon ballast and HID bulbs either so cover those with plastic. Basically the same directions you get when using any engine cleaner.
Let me know how it works for you. Oh, get the lemon scented version. It smells better.
Dan
whatheheck is offline
post #2 of 27 Old 16th January 2007, 07:47 PM
DavidS
Moderator Emeritus
DavidS's Avatar
Hello Dan,
Sounds useful... so you prefer syntethic lemon smell over petrol smell... :-)
If you have a can of it at hand, would you like to post what´s written in the contents part of the label, please?
Does it say anything about the pH value (acidity / causticity)?
David
DavidS is offline
post #3 of 27 Old 16th January 2007, 07:59 PM Thread Starter
whatheheck
whatheheck's Avatar
Hi David. Yes, I prefer simulated lemon scent over petrol anytime : )
I am currently here at work and dont have a can with me handy but here is the info I was able to gather over the internet.
Yes, kindly check it out and see if scrubbing bubbles contains anything that can harm our beast.
http://householdproducts.nlm.nih.gov...ds&id=19001091
Thanks!
Originally Posted by DavidS
Hello Dan,
David
Dan
Evolve ECU Tune, Tubi Rumore exhaust, BBS RGR rims; Polk Audio Tweeters, 5500K Osram Cool Blue HID,Valentine 1 Radar Detector; Laser Interceptor Laser Jammer; All LED interior lights, LED footwell lights, LED trunk lights, Ultimate Cup Holders, 3rd brake light LED flasher, ash tray delete; LED license plate lights; RPI Ram Air Scoops + Block off plates; BMC Air Filters.......
post #4 of 27 Old 16th January 2007, 08:19 PM
DavidS
Moderator Emeritus
DavidS's Avatar
Thanks for the great link, Dan!
It looks safe enough for the car. Basically water plus slightly concentrated hand dishwashing stuff plus an antibacterial compound and a flammable gas to propel it out of the spray can.
Should be perfectly safe for the engine, but I think any hand dishwashing stuff plus some water into a manually pumped atomizing spray bottle would be just as effective.
What I don´t like about it is the Dialkyldimethylammonium methyl sulfate, that kills bacteria, good bacteria and bad bacteria alike.
This might sound like a good thing, but it is not. Too frequent exposure to compounds like these is precisely how we get so called "super bugs", resistant bacteria.
Besides our skin is in symbiosis with protective bacteria that keep infectious bacteria away from microscopic wounds. Kill too many of those good bacteria and you leave the field open to nasty bacteria, aka "hospital illness".
I´m not saying you shouldn´t wash and keep clean, I say don´t use antibiotics or antibacterial stuff unless necessary, and only in the places needed.
Killing all bacteria is as produtive as killing all humans just to get rid of all murderers...
David
http://www.m5board.com/vbulletin/showthread.php?t=54788
http://www.m5board.com/vbulletin/showthread.php?t=88323
DavidS is offline
post #5 of 27 Old 16th January 2007, 08:27 PM
ECB
ECB's Avatar
My car had a pretty bad infection a few weeks ago and I felt obligated to prescribe some antibiotics. Some Pen VK and it cleared right up.
03 M5 Titanium Silver/Black Luxury/Burl Walnut
ESS VT 550 S/C 92mm pulley, Supersprint headers and Race cats, Eisenmann Sport Exhaust, RK Autowerks/Evolve tune,
Aquamist HFS-3 water methanol injection, Rogue SSK w/ RP Synchromax fluid, fog light delete,
H&R Springs, Dinan 17mm rear sway bar, TCD sway bar brackets, Ultimate Pedals, Euro Armrest,
Hardwired V1, Angel iBrights v.2, 6000K Low beams, 70W High beams,BSW Speaker Upgrade & 10" Sub
04 M3 Jet Black/Black Nappa/6 spd
Max PSI Turbo, Supersprint Resonated Sect. 2, Eisenmann Race Muffler
Rogue SSK, H&R springs, Koni Yellows, Squared 18's
ECB is offline
post #6 of 27 Old 16th January 2007, 08:40 PM
beastunleashed
beastunleashed's Avatar
beastunleashed is offline
post #7 of 27 Old 16th January 2007, 09:05 PM Thread Starter
whatheheck
whatheheck's Avatar
Thanks for the excellent report David.
If I can sort of summarize what you said = Scrubbing bubbles is safe to use for cleaning car engines. Based on its listed chemical contents - you are not aware of any chemicals present that can be harmful to metal, rubber or plastic parts?
But just like anything, only use it if you have to. (I use it about twice a year.)
Dan
David
Dan
post #8 of 27 Old 16th January 2007, 10:48 PM
6spd
6spd's Avatar
I've used stuff like that in the engine bay, It was a no name brand.
Another great thing is if you need to remove paint try Easy Off oven spray, It will lift the paint off in a hours time.
Gunk is nasty stuff for our storm drainage systems, I haven't used it for over 15 yrs now.
I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way.
Modifications
Chipped paint
Worn tyres
Dirty Carpet
Chipped windshield
6spd is offline
post #9 of 27 Old 16th January 2007, 11:10 PM
DavidS
Moderator Emeritus
DavidS's Avatar
Dan
Dan,
In short: yes.
I´m generally opposed to the marketing trend of putting antibacterial compounds into all sorts of household common goods where it is not needed. It is plain stupid. Except it sells well...
David
DavidS is offline
post #10 of 27 Old 16th January 2007, 11:42 PM
E55AMG2
E55AMG2's Avatar
303 Aerospace cleaner works better, has no smell, and is guaranteed safe on any surface (you can even wash fruit with it if properly diluted). The only downside is that it's a bit more expensive than the Gunk stuff.
E55AMG2 is offline
BMW Agreed to Out-of-Warranty Engine Repair JFB E39 M5 and E52 Z8 Discussion 35 22nd April 2005 07:15 AM
New Dinan Article Gustav E39 M5 and E52 Z8 Discussion 3 24th February 2005 08:00 PM
New M5 information direct from Mr. Donnie Isley of the BMW Performance Center atomic80 E60 M5 and E61 M5 Touring Discussion 1 15th September 2004 10:45 AM
14 September press release in English, 0-100 4,7s SuperBMW E60 M5 and E61 M5 Touring Discussion 0 14th September 2004 12:23 PM
Official press release: Engine / Drive System enots E60 M5 and E61 M5 Touring Discussion 9 24th June 2004 01:50 AM
