Old 9th June 2006, 17:26   #1
Mike Krieger
Mike Krieger's Avatar
Garage: 2000 M5 Oxford Green
Rebuilt Engine
Is there a reason no one talks about having a rebuilt engine. Does the cylinder wall treatment prevent boring out the cylinders and using larger pistons? Is there not enough wall thickness to overbore? Is it because no one makes software that would handle the changes in air/fuel etc.? I have two dead cylinders and I don't want to pay $18,000 for a new engine.
Mike Krieger is offline
Old 9th June 2006, 18:20   #2
ard
ard's Avatar
Primarily it is due to the AluSil cylinder wall surface treatment. Impossible to re-create. Some have sleeved the block, but so little space it make it a very difficult and risky task. Rebuilts seem destined for questionable life.
Did you see this:
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Good luck
A
ard is offline
Old 9th June 2006, 18:52   #3
KirklandM5
KirklandM5's Avatar
Garage: 2001 M5 Titanium Silver
Send a message via AIM to KirklandM5 Send a message via Yahoo to KirklandM5
Assuming the bores are within spec, I'd say that a rebuild would have good life. In fact BMW does sell remf'gd engines for the car.
Some people have sleeved the motor.
If you want to talk to somebody with more expereince with this engine, contact Dinan as they have built a few race engines using the S62. they might be able to give you some insight.
2001 E39 M5 Titanium Silver/Silverstone
1997 BMW M3 Gruppe N Race Car
2005 X5 4.4i
KirklandM5 is offline
Old 9th June 2006, 19:02   #4
mjshira
Garage: Silver 2000 M5
on ebay now, check it out, less than 20,000 miles for 10k
mjshira is offline
Old 9th June 2006, 19:36   #5
Mike Krieger
Thanks, it sounds like this is the best solution for now.
Old 9th June 2006, 20:11   #6
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
I would wonder why you have two dead cylinders. Bent valves or damaged seats? Worn or broken rings? Head gasket. Sounds like more/better diagnostic work is needed before you jump into a new engine. Was it you in another thread that said you have an extended warranty? (if not, there seems to be a few people out there recently with 2 bad cylinders!)
My car had 20% leakdown on a cylinder, caused by some debris that got into the engine and nicked a valve seat. Certainly repairable, and i was able to throw some upgrades in for considerably less than a used engine, of unknown quality. My cyl walls looked perfect, and the other 7 cylinders hav 2% leakdown at 73k miles...
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 9th June 2006, 21:37   #7
Mike Krieger
It's my rings. I haven't done a leakdown, but I have done a compression test and two cylinders are very low. I am told that the 2000 engine has different rings that contribute to the oil consumption problem that I have (a quart every 350 miles). I really just want to replace the rings on all pistons, but I don't have a warranty. I could have cylinder scoring or other problems, but I think it is just bad rings. I have 97k on the engine, but I had hoped it would last much longer with all of that $10 per quart oil I have been using. I think when more people have high mileage engines, another solution will be worked out. For now, it looks like I watch e-bay and pick up a low mileage engine.
Old 9th June 2006, 23:31   #8
KirklandM5
KirklandM5's Avatar
yeah a good engine built post 3/00 could be just what you need.
and then you can take apart the old engine for fun and check it out.
2005 X5 4.4i
Old 9th June 2006, 23:36   #9
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
2000 engines made before 03/00 had different piston rings. That is why 10-60w oil required. Check your production date.
If you open the engine up to do rings, do them all. And while the head is off, I would check the valves and port the head. If you go used engine, be very careful regarding the warranty. You don't know where that engine came from. Good luck either way.
gsfent is offline
Old 10th June 2006, 00:02   #10
MAH
MAH's Avatar
Garage: 2001 Imola Red
Mike,
I just went through this painful process. I had a cylinder that needed to be honed out because of a spun bearing. There is 18/1000 of an inch that can be honed out before you would be out of BMW's tolerance range. Mine was honed out just a fraction of the 18/1000 to acheve a smooth surface.
There are plenty of ways to get a good rebuilt engine, even from BMW. I replaced all of my rings. I would have this done at a good independent dealer and not at most BMW dealers.
Mark
MY2001 Imola Red
Lux. Black Interior
Painted Calipers,
Autowerke CAI
Powerchip Software Upgrade
Tubi Catback Exhaust
361RWHP
425HP and growing!
MAH is offline
Engine Rebuild jrturbo E34 M5 Discussion 6 17th April 2006 17:20
Don't know if you have seen these before? Facts about our M5's... Ocean's M5 E39 M5 and E52 Z8 Discussion 13 2nd April 2006 05:41
BMW officially announces new N54 Turbo Engine Callero GTBoard.com: General Sportscars 9 21st February 2006 20:56
New M5 information direct from Mr. Donnie Isley of the BMW Performance Center atomic80 E60 M5 and E61 M5 Touring Discussion 1 15th September 2004 10:45
14 September press release in English, 0-100 4,7s SuperBMW E60 M5 and E61 M5 Touring Discussion 0 14th September 2004 12:23
Page generated in 0.15854 seconds with 11 queries
