Old 9th June 2006, 16:15   #1
Cemessi
Cemessi's Avatar
Garage: The 39th M5
Which way do the grooves go?
I have stoptech grooved discs and despite putting them on correctly (labeled L and R) I don't think they are on the correct sides, I think the grooves are going the wrong way.
Does anyone have a picture of theirs?
Cemessi is offline
Old 9th June 2006, 17:07   #2
KBK
KBK's Avatar
Garage: E39/Anthracite Metallic
In the direction of rotation, they scrape across the bottom (groove part closest to center of wheel hub) of the brake pad first, and then the top last. The groove leaves the top of the pad last, in the direction of rotation. The outer part of the disc's groove leaves the pad's area last.
Push water and dirt/gasses..OUT. To the outside of the spinning disc. Aided by centrifugal forces.
KBK is offline
Old 9th June 2006, 17:14   #3
Cemessi
Cemessi's Avatar
Garage: The 39th M5
Makes perfect sence but its not the way Stoptech say to put them. Take a look at this picture and making a note of the L and R on the discs. This is the way I have mine
http://www.dynospotracing.com/brakes...h_audi_kit.jpg
Cemessi is offline
Old 9th June 2006, 17:18   #4
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
I agree with you. I think they are labelled backwards. I understand the slots are to let gases escape. Why not check with resident brake guru Dave Z, who also sells these? I will look at mine later.
gsfent is offline
Old 9th June 2006, 17:18   #5
KBK
KBK's Avatar
well, I guess you found out differently, then. Common sense does not rule this time. Must be a reason.
On my old car, the venting was in the manner I spoke of. I wonder why the difference.
KBK is offline
Old 9th June 2006, 18:48   #6
Habu
Garage: E39 M5 TiAg
Sales Feedback: (3)
Cemessi,
Thanks for bringing that topic up. I've noticed that the slots appear to go counter to what I'm used to. Must be a reason though because I've seen them on other cars that way.
Bob
Habu is offline
Old 9th June 2006, 18:56   #7
welsh_willo
welsh_willo's Avatar
Garage: Avus Blue e39 m5
Send a message via MSN to welsh_willo Send a message via Skype™ to welsh_willo
the same
Cem
mine are the same
i.e as per stoptechs fitting instructions
welsh
Welsh _ Willo
welsh_willo is offline
Old 9th June 2006, 21:40   #8
whatheheck
whatheheck's Avatar
Garage: 2006 M6 Indianapolis red
Sales Feedback: (3)
Here's mine. Passenger side.
So which way is correct?
Dan
whatheheck is offline
Old 9th June 2006, 21:53   #9
welsh_willo
airflow
mmmm
less to do with the slots
more to do with the vane design for increasing centrifugal airflow and wheel rotation
Welsh _ Willo
Old 9th June 2006, 22:13   #10
Blue Thunder
Garage: 1999 M5 Avus Blue Metallic
I have slotted Brembos and here is how they are oriented:
1999 M5 Avus Blau Metallic
Twin Rotrex superchargers, Front mount intercooler, Steel sleeved block, Forged CP pistons, 10.5:1 compression, SS Headers, SS race cats, TUBI Rumore,
UUC 11" V12 cerametallic clutch + flywheel, UUC EVO3 SSK w/DSSR, Brembo GT4 brakes front/back, KWv3's, Angel Eyes + Angelibrights, Celis
19" Hamann PG2īs, Strongstrut front Strut Brace, BMW fire extinguisher, Phatbox MP3 player, CF interior trim, Voltphreaks battery
http://www.cardomain.com/ride/2417213/1
1989 E30 M3 White - track toy
S50B32 with a supercharger - 500+ hp, 1300kg rocket for the Ring
Blue Thunder is offline
AP Discs - grooves keepleft E39 M5 and E52 Z8 Discussion 16 17th August 2004 16:35
M5 tracking grooves in the road daniel E39 M5 and E52 Z8 Discussion 7 18th November 2000 01:31
Page generated in 0.18179 seconds with 12 queries
