Old 10th June 2006, 05:52   #11
KBK
KBK's Avatar
Garage: E39/Anthracite Metallic
Must be a reason. It could be as simple as it has been shown, that over time, they are less likely to develop a crack. Who knows. Or, that overall..there is no remotely measurable performance difference, so the manufacturers do what they like. Could even be a pad dislocation (walking) issue.
KBK is offline
Old 10th June 2006, 08:11   #12
jaj
jaj's Avatar
Garage: 2008 M3 Coupe Space Grey
The rotors go on with the vanes inside producing a pumping action that throws air "out" of the rotor as it turns. Putting them on the wrong way hinders the cooling process considerably and may cause pad fade (read: not good).
The slots end up whichever way around that the manufacturer decided that they should end up - it's the internal fins that matter.
I suppose the "forward slanting" fins pulls the pads into the center of the rotor, but the effect will be minimal.
Cheers
JJ
jaj is offline
Old 10th June 2006, 16:17   #13
E55AMG2
E55AMG2's Avatar
Actually, they mount them that way on track cars to help keep the pads clean and to aid the radial vents in pulling air thru the rotor to keep it cool. The venting effect (for pad outgassing) works regardless of the direction of the slots.
E55AMG2 is offline
AP Discs - grooves keepleft E39 M5 and E52 Z8 Discussion 16 17th August 2004 16:35
M5 tracking grooves in the road daniel E39 M5 and E52 Z8 Discussion 7 18th November 2000 01:31
Page generated in 0.09007 seconds with 12 queries
