Old 9th June 2006, 22:28   #21
imolaman
imolaman's Avatar
Garage: 2001 BMW M5 Imola Red
Send a message via MSN to imolaman
Originally Posted by Al-Afghani
Auction it off, let it be someone else's problem
Al-Afghani,
That is a very rude comment. This is a brotherhood of M5 owners and certainly that attitude is way out of line on this forum. Please refrain from making those statements. M5 owners look out for one another.
2001 Imola Red II E39 M5 - Stock
imolaman is offline
Old 9th June 2006, 23:09   #22
Jon@TheMShop
Representative for themshop.com, m5board.com Sponsor
Garage: '98 M3 and '07 335i sedan
Send a message via AIM to Jon@TheMShop
Originally Posted by wilsodh
Jon,
I dunno, maybe its the photo, but those piston tops don't look all that bad. Don't we expect to see some carbon on the piston tops in normal engines, especially those with some miles?
Dave
Sorry but I forgot to mention this engine had less than 10k and was a 2002 model year. I know its sorta hard to tell just by the pictures but the technician that pulled off the head and the shop foreman said that it had way too much carbon on top of the pistons.
Here's a picture of my damaged pistons at 80k miles on an E36 M3. This had a lot less carbon than the previous pics I posted.
Jon C.
Jon@TheMShop is offline
Old 10th June 2006, 00:14   #23
MAH
MAH's Avatar
Garage: 2001 Imola Red
Been here done this
Brian,
I think we discussed this subject via pm's, but I would still try to go through BMW first. You may not have carbon build up as the issue at all, it could in fact be spun bearings that caused the rings to fail that would give you blow-by and thus failing the leak down test/poor compression.
Open the engine up and find out at the dealer if BMWNA will help out at all. Otherwise have the dealer take it apart and if BMWNA is unwilling to help, box it all up and tow it to good independent.
If I had to do it all over again and BMWNA had not helped out, I would have done this. In fact, I am so concerned with my oil consumption after the repair that I an having it tested to find out if the repairs are not as they should be.
Good luck and I hope you get through quicker than I did.
Mark
MY2001 Imola Red
Lux. Black Interior
Painted Calipers,
Autowerke CAI
Powerchip Software Upgrade
Tubi Catback Exhaust
361RWHP
425HP and growing!
MAH is offline
Old 10th June 2006, 00:51   #24
Al-Afghani
Garage: 02 M5, silver
Originally Posted by ashbash
You should kill yourself.
As for the original poster - search for user MAH's and Tranck's prior posts on engine issues. You may be able to get BMW to give you some goodwill towards repair (not replacement).
-Ash
and why would I do that? Most dealers who buy such a car will fix it under warranty etc...one engine dead, no need to lose a life
Al-Afghani is offline
Old 10th June 2006, 00:54   #25
Al-Afghani
Originally Posted by imolaman
Al-Afghani,
I am just looking out for a fellow M5 owner....maybe you just don't undertand?
Old 10th June 2006, 01:00   #26
MAH
MAH's Avatar
You may get the car repaired by the dealer and it may in fact be under warranty, but that does not mean you would want to keep it after that kind of extensive repair.
Mark
MY2001 Imola Red
Lux. Black Interior
Painted Calipers,
Autowerke CAI
361RWHP
425HP and growing!
MAH is offline
Old 10th June 2006, 01:03   #27
tranck
tranck's Avatar
Garage: 2000 M5 - Silverstone Metallic
Originally Posted by MAH
Brian,
Mark
I have been driving my car a little more now Mark and have noticed that it seems to be using more oil now than before the similar engine work that we both had done.
This piston ring thing has me asking some questions - my tech said that when he looked/tested my rings said they were good and said even if they weren't that I couldn't replace just the rings because they were specific to the pistons.
I don't know about that - all I know is that the car seems to be using more oil than before - nothing real alarming - about a quart every 1500 miles but again, more than before.
Maybe because our cars now are going through the break-in period again but, it's been well over the 1200 mile mark since the work has been done.
I'm thinking about a leak-down test myself.
tranck is offline
Old 10th June 2006, 01:13   #28
MAH
MAH's Avatar
Well I wish mine was only using that much oil. In the 1st 1200 miles it used a quart and a half. Either that or the dealer did not fill it up all the way. I changed the oil at 1200miles and it was darker than I have ever seen it at 7500 miles.
I am taking it to an independent for a good once over. If there is still a problem, back to the dealer it goes, because we do have a two year warranty on the work done.
Does your seem to run a bit rougher than before the repair?
Mark
MY2001 Imola Red
Lux. Black Interior
Painted Calipers,
Autowerke CAI
361RWHP
425HP and growing!
MAH is offline
Old 10th June 2006, 01:29   #29
Blue Thunder
Garage: 1999 M5 Avus Blue Metallic
I think it´s your attitude of unloading your crap onto someone else is bothering people.
It has nothing to do with understanding I think - it´s more about being honest.
1999 M5 Avus Blau Metallic
Twin Rotrex superchargers, Front mount intercooler, Steel sleeved block, Forged CP pistons, 10.5:1 compression, SS Headers, SS race cats, TUBI Rumore,
UUC 11" V12 cerametallic clutch + flywheel, UUC EVO3 SSK w/DSSR, Brembo GT4 brakes front/back, KWv3's, Angel Eyes + Angelibrights, Celis
19" Hamann PG2īs, Strongstrut front Strut Brace, BMW fire extinguisher, Phatbox MP3 player, CF interior trim, Voltphreaks battery
http://www.cardomain.com/ride/2417213/1
1989 E30 M3 White - track toy
S50B32 with a supercharger - 500+ hp, 1300kg rocket for the Ring
Blue Thunder is offline
Old 10th June 2006, 01:31   #30
Al-Afghani
Originally Posted by Blue Thunder
I think itīs your attitude of unloading your crap onto someone else is bothering people.
It has nothing to do with understanding I think - itīs more about being honest.
Like I stated, you can see it that way, but me from attending hundreds of car auctions see it differently. BMW repairs their stuff under warranty, and dealers usually have cheap labor and buy these things cheap. So our friend here may lose 4-5K on the car from the original value, and the dealer guy may only spend a few K fixing it and then another few K in profit. Everyone benefits.
Excuse the attitude, I should have clarified further.
Night of the Living Dead - aka Keyless Entry Hell! nomis E60 M5 and E61 M5 Touring Discussion 61 10th June 2009 01:11
my M5 Dead battery experience.... E39 MFIVE E39 M5 and E52 Z8 Discussion 29 9th February 2007 07:17
Two Dead Cylinders- Help brianhardcore E39 M5 and E52 Z8 Discussion 6 13th June 2006 01:28
Press Release no 2: The new V10 Power Unit in the BMW M6: A Masterpiece in Engine... Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 15th December 2004 01:15
OT:What Digital Camera do you use? MRacer E39 M5 and E52 Z8 Discussion 49 24th December 2001 03:33
Page generated in 0.17828 seconds with 12 queries
