Old 9th June 2006, 03:22   #1
Al-Afghani
Garage: 02 M5, silver
low oil question, winshield washer
Ok so I got this warning light stating (engine oil low). IT's been about a week and I have driven no more than 200 miles. I drove it hard a few times in the past week (maybe 2) but not much or for long.
I checked the oil and I realized it was low so I added some. Do you guys think this may have done any damage to the engine?
The warning came a week ago and then yesterday and that is when I decided to check it.
Also, Winshield washer low alert comes on. Today I also added winshield washer, but I realized I added it to the wrong tank, after looking @ the manual it seems I added it to the "Reservoir cleaning sysyteM" or something like that. What do you guys add for winshield washer? it says water in the manual, can I just add normal winshield washer for both systems? Should I drain the reservoir cleaning system winshield washer that I poured in there?
Any help is appreciated
Al-Afghani is offline
Old 9th June 2006, 07:28   #2
E55AMG2
E55AMG2's Avatar
If it says low oil, that is the "Idiot Light" to remind you that you have indeed waited too long to check your oil. If/when you see it, stop and get oil immediately. At the very least, you should be carrying 1L of oil at any given time.
E55AMG2 is offline
Old 9th June 2006, 12:04   #3
jclyman
jclyman's Avatar
I suggest you read the manual before you open the hood the next time ... pouring the wrong fluid in the wrong place could be disasterous ... in this case, I would just use up the fluid you added, it's just not as strong as what is recommended.
If you don't have a manual, you can download one from the BMW NA site.
- Daniel Boorstin
jclyman is offline
Old 10th June 2006, 01:12   #4
Al-Afghani
NO i have a manual, I just saw the "white" tank and said "YAY that must be it"..oh well..**** happens
Old 17th June 2006, 05:59   #5
aaronmiles
aaronmiles's Avatar
Garage: 1999 Imola Red M5
Send a message via MSN to aaronmiles
what you have done is fine ... the thank that you filled is for the intense cleaning system.. you press the little S on the stalk (I think its an S) and it just uses a stronger solution. I normally put a full bottle of the BMW windscreen cleaner in it
1999 Imola Red M5. Extended Caramel Interior
Mods on my pre-update beast:Eisenmann "Race" exhaust (76mm tips), 19" Hamann PG2's, AACAI, Clear Angel Eyes, MK4 Nav, GC's M5 Coilover kit w/front camber plates, Dinan Front and rear sway bars, D/A swaybar mounts, Dinan front and rear strut brace, Braided brake lines, Eibach 3mm wheel spacers, Rogue Engineering underdrive pulleys, IATS Relocation, Powerchip, Xenon foglights & Lower engine covers w/Brake duct cutout
2008 Volkswagen Golf GTI. The wifes new car
2005 Ford Territory Ghia. The wifes car. (Sold)
1986 Toyota Landcruiser HJ75. The farm ute.
aaronmiles is offline
Old 17th June 2006, 06:54   #6
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
on my car, i seem to get a 'check engine oil' warning consistantly when i'm about half a liter low. Not a big deal for street driving in my book. I generally check it weekly, but it's a nice reminder. You need to get a feel for when your light comes on, as the car will vary a bit.
As for washer fluid, the small tank is for intensive washer fluid, i buy the intensive wash at my dealer (actually get the regular washer fluid there too, cheap enough, and works well). The large tank has it's inlet neck between the intensive tank and the engine. Early cars have a white cap, later cars have a black one, iirc.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 17th June 2006, 18:24   #7
DrewKeen
DrewKeen's Avatar
Garage: Imola M5, Black SVT Cobra, Orange Pinto
Send a message via AIM to DrewKeen
I believe they changed to black (IF they did) because the early white ones (like mine) get nasty easily.
Imola Red; Black/Silver Sport
DrewKeen is offline
Old 17th June 2006, 19:14   #8
ard
ard's Avatar
I seem to recall that BMW no longer sells the "intensive" fluid due to "shipping restrictions" or "hazardous materials restrictions" or "environmental concerns".. so they just recommend straight windsheild concentrate in the intensive, and the same but diluted in the regular.
ANy truth to this, or is the original intensive fluid still available?
OT: speaking of knowing where to fill... my sisters' ex-husband decided to change the oil in her VW rabbit years ago. Did fine draining the oil, got the plug back in no problem. Skipped the filter part as he forgot to buy one. Filled it back up with oil. (Was wondering why it only took 3 quarts.)
She drove it 2 miles, until it ended it's life.
He added oil to the radiator.
Ex...
A
ard is offline
Old 18th June 2006, 01:37   #9
Gamedemon
Gamedemon's Avatar
Garage: Anthracite M5
Ex...
A
Is that the reason an EX was added to husband ? That is just TERRIBLE !
Gamedemon is offline
Old 18th June 2006, 02:00   #10
Laidback
Garage: Camaro lol:)
Sales Feedback: (25)
now you know so next time check your fluids regularly ok
"Illegitimus non carborundum"
Laidback is offline
Quick question about oil change Mr. J E34 M5 Discussion 8 5th June 2007 23:13
Thoughts on my M5 after being in the shop, and question about oil leak... UltFamCar E34 M5 Discussion 7 20th September 2006 00:43
Engine Oil Leak Suspected - Non-Linear Oil Usage 507bhp E60 M5 and E61 M5 Touring Discussion 12 10th December 2005 22:05
How Much $$ Do You Pay for an Oil Change?? cohenfive E39 M5 and E52 Z8 Discussion 31 4th September 2004 03:28
Press Release no 2: The new V10 engine in the BMW M5: A masterpiece in engine cons... Gustav Most Memorable Threads' 31 4th July 2004 22:23
Page generated in 0.19695 seconds with 11 queries
