Old 9th June 2006, 00:36   #1
ktulu
ktulu's Avatar
Garage: 2008 ///M5 - Black Sapphire Metalliic/Black Perforated Merino/Madeiro Walnut
Send a message via Yahoo to ktulu
Bad fuel tank vent valve and new tranny
Got my first SES light at 23k and it appears that it is a bad fuel tank vent valve? Seen a couple of posts about it on here but I was wondering if that could explain why it seems as though sometimes the car is a rocket while at other times its just fast? Could be my imagination or more likely the weather?
I am also getting a new transmission..under warranty! Oh yeh! I purchased the car a few months ago with 18.5k on the clock and I noticed the very next morning that the gears were very notchy. I hadn't really noticed when I drove the car because it was warmed up and the weather was warmer. But driving after 500 miles and letting it sit over night in 20 degree F weather it was definitely not as smooth as one would expect. I mentioned it almost immediately to my local service guy and he was nice enough to let the master mechanic look at it and he said he thought it was basically normal as most M5 trannys seem notchy to him?
So a month or so went by and I brought the car back in for a 4 wheel alignment and some new front tires and mentioned to him again that the tranny was rough. Ended up getting a new clutch and flywheel which was a surprise. Didn't really help the roughness at all but man I had no idea that my clutch was even slipping. I couldn't even turn DSC off without spinning out for a few dozen miles until I got used to it. Much more grip. Can you grab a 4th? Hell yeh!
Anyway when I took the car back for the SES I mentioned again that the tranny just felt bad and it was still hard to even get it in gear at times. So I took the mechanic for a spin and of course it was smooth. Then on the last two turns coming back to the shop I had problems downshifting into second. They called an engineer? who is familiar with the case and it looks like I will be getting a new transmission!
To me it has seemed like the synchronizers weren't doing there job. I have driven standard transmissions since I was 12 and I have never driven a car that has felt so rough shifting. That includes an old Ford 2 ton dump bed.
Anyone else having issues with their transmission with low mileage? Not owning the car for very long I can't say how it has been treated but I am glad to see that BMW takes these things serious. I for one am a happy customer for sure! I only hope that if any VANOS or carbon issues are going to show up at all they show up soon. A warranty is a great thing to have!
2008 ///M5 - Black Sapphire Metallic/Black Perforated Merino/Madeiro Walnut trim/6-spd Manual
2005 X5 4.8is - LeMans Blue/Black Nappa/Anthracite trim | born 05/20/05 - For Sale
2003 ///M5 - LeMans Blue/Black Interior/Aluminum trim/6-spd Manual - retired
2002 525i - Jet Black/Black Sport/5-spd Manual - retired
2002 X5 3.0i - Sterling Gray Metallic/Tan Leather Sport/5-spd Manual - retired
ktulu is offline
Old 9th June 2006, 22:37   #2
imolaman
imolaman's Avatar
Garage: 2001 BMW M5 Imola Red
Send a message via MSN to imolaman
The mileage on my beast is now at 116000km. I started noticing a little roughness in the tranny about a month ago. Following advise from this board I changed the tranny fluid, and definitely noticed an improvement. So much for "lifetime fluids"...
This board is great!!!
2001 Imola Red II E39 M5 - Stock
imolaman is offline
Old 10th June 2006, 02:24   #3
aaronmiles
aaronmiles's Avatar
Garage: 1999 Imola Red M5
Send a message via MSN to aaronmiles
When I had the clutch done I had the fluid changed.. I reckon mine shifts worse now than it did before hand. When I take off I have to double clutch to get 2nd.
Once it warm though its fine
1999 Imola Red M5. Extended Caramel Interior
Mods on my pre-update beast:Eisenmann "Race" exhaust (76mm tips), 19" Hamann PG2's, AACAI, Clear Angel Eyes, MK4 Nav, GC's M5 Coilover kit w/front camber plates, Dinan Front and rear sway bars, D/A swaybar mounts, Dinan front and rear strut brace, Braided brake lines, Eibach 3mm wheel spacers, Rogue Engineering underdrive pulleys, IATS Relocation, Powerchip, Xenon foglights & Lower engine covers w/Brake duct cutout
2008 Volkswagen Golf GTI. The wifes new car
2005 Ford Territory Ghia. The wifes car. (Sold)
1986 Toyota Landcruiser HJ75. The farm ute.
aaronmiles is offline
Page generated in 0.09621 seconds with 10 queries
