Old 8th June 2006, 23:09   #1
mubarak
mubarak's Avatar
Garage: white bmw m5
clutch
hi:
need help.... when i am at fourth gear at 4500 rpm and i double the clutch and press the accelator the clutch is slipping but when i drive normal it does not ... is that normal or i need new clutch
thanks all of you
mubarak is offline
Old 8th June 2006, 23:39   #2
mubarak
mubarak's Avatar
no one how come?
mubarak is offline
Old 8th June 2006, 23:42   #3
Kain
Garage: 2000 BMW M5
Send a message via AIM to Kain Send a message via MSN to Kain
As Gustav would say, "it's only been 30 mins, please be patient."
Kain is offline
Old 9th June 2006, 00:02   #4
TiM5
TiM5's Avatar
Garage: Imola Red/Black Sport M5
sounds like you need a clutch.
Thanks, TiM5
SOLD!-2k Imola/Black Sport
-Tubi Style regular version
-Rogue SSK+WSSR
-19x8.5- 19x9.5 ACS type III racing wheels-
General exclaim UHP tires 245/35f-275/30r
-bimmernav bluetooth kit
2006 Volvo V70R
blk sapphire/nordcap-nav,gt,prem,climate,sub,full tint
2007 HHR
2003 Yukon
2004 HD Heritage softail
TiM5 is offline
Old 9th June 2006, 00:12   #5
mubarak
mubarak's Avatar
by the way last time i changed my clutch in july 2002....when i change it the car has 46000km ..... now the car hase 149000km...you think guys it is the time to change or the clutch last more than that
mubarak is offline
Old 9th June 2006, 00:17   #6
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Clutch life depends on break in and driving style. These clutches are not robust, but some members report 100k miles.
What do you mean it slips when you "double the clutch"? You mean double clutch on a downshift to rev match? On an upshift, there is no no need to double clutch. In any event, when your foot is copletely off the clutch pedal (assuming you didn't just drop the clutch at 3000 rpm), there should be no slippage.
gsfent is offline
Old 9th June 2006, 00:34   #7
mubarak
mubarak's Avatar
i now what you mean... not downshift or upshift i am in fourth gear not changing .... when i get to 4500 rpm i double the clutch and take my foot quikly and full throttle ...there the clutch slpping ... you got it
mubarak is offline
Old 9th June 2006, 00:52   #8
gsfent
gsfent's Avatar
Still don't know what you mean by "double the clutch". You are in 4th gear at 4500 rpm, and then you simply floor the throttle? If so, you are correct, there should be NO slippage. But if you are clutching out and then letting up quickly while giving it hard throttle, you could cause the clutch to slip as it takes up. Bad, clutch can't take a lot of abuse like that. If you simply wait for the clutch to hookup, you will eat it up quickly in that circumstance. Right thing to do is release the throttle. Again, not sure what "double the clutch" means, so I am just guessing. Hope that helps.
gsfent is offline
Old 9th June 2006, 01:02   #9
mubarak
mubarak's Avatar
yes....... your right i am clutching out and letting up quickly and giving hard throttle....if it slippe this way is that mean i need new clutch or not
thanks again and sorry for miss understanding
mubarak is offline
Old 9th June 2006, 01:39   #10
gsfent
gsfent's Avatar
Not necessarily. If you are nailing the throttle, it may be more torque than the clutch can handle. I have never done that, so I am not sure. But if it is not otherwise slipping, I would say the clutch is OK, and STOP DOING WHAT YOU ARE DOING or you WILL need a new clutch!
gsfent is offline
New Sachs Power Clutch tripleD E39 M5 and E52 Z8 Discussion 13 12th April 2005 22:04
FAQ regarding UUC & Spec clutch kits marcvip E39 M5 and E52 Z8 Discussion 119 4th April 2005 23:12
Stage 3 (6-puck ceramic) clutch 1st impressions 1badm5 E39 M5 and E52 Z8 Discussion 11 2nd November 2004 22:00
Yet another clutch theory/technique thread greg E39 M5 and E52 Z8 Discussion 8 18th March 2004 18:55
TECH: those w/ non-original clutch --> light clutch pedal? Teutonaddict E39 M5 and E52 Z8 Discussion 0 31st July 2002 20:44
Page generated in 0.16237 seconds with 11 queries
