Old 8th June 2006, 22:39   #1
JayC
JayC's Avatar
Garage: Acura TL -- Shopping for E39 M5
HELP!!! ERROR CODES GALORE!!!
So, I just installed my VW MAFs a couple days ago, and the car has been doing great since then...better power, more smooth, etc. Until yesterday when out of the blue my SES light came on. I got the Peake reader in the mail today so I checked it out and I have a TON of fault codes...Looking for advice from people that have any idea what this all means and what I should do...Thanks!
1. Timeout SMG-CAN --- DELETED
2. Crankshaft/Camshaft Position Correlation Cyl 5-8
3. Misfire During Warmup, Cyl 3
4. Misfire During Warmup, Cyl 5
5. Misfire During Warmup, Mult. Cyl.
6. Control Unit Self-Test, Safety Concept Master Check ---- DELETED
7. Air Fuel Adaption, Cyl 1-4
8. Air Fuel Adaption, Cyl 5-8
9. Misfire with Empty Fuel Tank
10. Engine Coolant Temp., Plausability ---- DELETED
EDIT---oops...read some of the B's as 6's...so delete the ones i wrote delete next to and add these:
11. Exhaust Camshaft position sensor, Cyl # 5-8
12. Catalyst System efficiency, Cyl #1-4
13. Catalyst System efficiency, Cyl #5-8
14. Exhaust camshaft VANOS position control, Cyl #1-4
Let me reiterate that I have felt nothing out of the ordinary after the switch to the VW MAFS, just this SES light (delayed). I've only had the beast for a few weeks so this is the first SES light that I've gotten. Advice???
JayC is offline
Old 9th June 2006, 01:36   #2
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Reset the SES light with the Peake reader and see what comes back. I would be looking for possibly a bad CPS. If so, not a big deal.
gsfent is online now
Old 9th June 2006, 02:03   #3
Mattkins99
Mattkins99's Avatar
Garage: '01 Lemans Blue M5
I was running on fumes once in my 540 and had these same errors. I'd assume something similar caused these.
From reading here, it seems bad MAFs mask bad O2 Sensors, so when you replace the MAFs they cause the O2 sensors to work harder and if they are bad, cause faults.
As for the CPS... usually you're driving down the road and BAM it feels like you have no power and the gas pedal doesn't do anything (that was my experience at least) so it could be bad. Again, on my 540, it was only a $60 part, but when they go bad on the beast, I'm sure they will be more.
Matt Atkins
President Seattle5s (Puget Sound E39 SIG)
http://www.seattle5s.com/
'01 Lemans Blue M5 :-)
-Dinan CAI
-Dinan Stage 2 software
'94 Green Pathfinder SE :-|
Mattkins99 is offline
Old 9th June 2006, 02:43   #4
ard
ard's Avatar
First. Don't panic.
Codes are stored until reset. THese may be a year old. Your SES might have been set by something relatively benign, but now that you pulled them you see all of them. The dealer's computer will pull code AND mileage at which it last occured.
I agree- reset and monitor. Pull codes anytime you want, light or not.
I've (almost) run out of gas... many of the misfires are from that IMHO. Might even trip others?
Anyway, report back....
CPS can start flaking out and still not have the total power loss that is usual, good news is that it will eventually fully fail and give you that "half horsepower" feel.
A
ard is offline
Old 9th June 2006, 02:57   #5
KBK
KBK's Avatar
Garage: E39/Anthracite Metallic
Plugs are simply in need of a change.
See my thread (I started it) on VW MAF's.
The whole top of the engine gets heat damaged by lean burn caused by bad MAF's.
The plugs get burnt.
You put in new MAF's.
Mixture ratio richens considerably.
This swamps out the plugs--which were on the absolute verge of failure. Now their poor state is amply illustrated.
You also get 'bad catalyst' warnings, from the plugs being swamped and the fuel/air ratio being so different-due to the new MAF's.
Replace the plugs, and the rest of the SES warnings should go away over time.
But get those new spark plugs in that car.
The only potential 'real' codes..are the CPS codes, but they may go away as well!
What pisses me off..is the dealers use this as a money making machine..and take care of everything on the list..at GREAT and HUGE expense to BMW, or the owner of the car..when it's actually a pair of $59.99 sensors. Almost every frikin' time.
They'd replace both CPS sensors, all four o2 sensors, the cat coverters and suddenly...maybe...you might somehow need a Vanos job too??
$15,000 dollars later....
...well..either you dump the car into their waiting arms, or dump it on the open market.... or you come here and find out the REAL deal.
KBK is offline
Old 9th June 2006, 06:02   #6
Tessio
Garage: 2001 M5 Carbon Black
Got a similar mess shortly after replacing mine
I agree with the other posters, suspect the CPS's first. On mine, the driver's side intake and exhaust CPS's turned out to be the culprits, but when I got them I found them to be a different design so I went ahead and did the passenger's side too.
No more codes and it's been months.
Changed the plugs too at the time. Well worth it, she accelerates like ripping silk now.
Tessio is offline
Exotics galore in Manhattan KRM Off Topic Forum 5 18th November 2002 18:22
GUMBALL 3000 send-off pics galore! blue max Gumball 3000 Forum 52 15th May 2002 17:47
Look at the cars I saw today. (Pics Galore) BostonRocket E39 M5 and E52 Z8 Discussion 16 27th April 2002 18:12
Mini Video Clips Galore! EBMCS03 GTBoard.com: General Sportscars 6 25th April 2002 00:21
LI Meet ... pics galore! blue max E39 M5 and E52 Z8 Discussion 22 7th April 2001 02:04
Page generated in 0.14458 seconds with 11 queries
