• Latest threads
    • Custom feed
      • News
        • Updates
          Old 4th June 2006, 03:53   #1 (permalink)
          boostmiser
          boostmiser's Avatar
          Gas mileage drop since Ethanol released
          Well, I'm noticing a difference now. Performance actually seems a bit off. I've also dropped 2 miles per gallon since the ethanol blends have hit. While it could be the o2 sensors, I'm thinking it's the gas because it dropped right when I confirmed the local gas had ethanol (several weeks ago). So now I need to buy more gas at a higher price becuase we are trying to reduce our dependance on foreign oil....I call BS! Anyone else?
          The Upgrades: MKIV Nav Unit / JL 500.1 Amp / JL 12w6v2 Sub / UUC Evo III SSK / UUC DSSR / UUC Tranny mounts / MKIV Nav Upgrade / TCD Sway Bar Brackets
          boostmiser is offline
          Old 4th June 2006, 04:55   #2 (permalink)
          Beamer_usa
          Beamer_usa's Avatar
          Well Connecticut has been doing the ethanol thing for a few years now, since MTBE was outlawed here 4-5 years back. To answer your question, I really have not noticed a negative effect
          2000 Silvr(354)/Blk(M1SW)
          Dinan Cans
          PC 93
          Beamer_usa is offline
          Old 4th June 2006, 05:14   #3 (permalink)
          DrewKeen
          DrewKeen's Avatar
          Send a message via AIM to DrewKeen
          Ethanol does not have as much energy per gallon as gasoline does. It will decrease gas milage.
          The upside is that is does have a higher knock resistance so if you could find a software programmer you could pick up some power by adding in some timing.
          Imola Red; Black/Silver Sport
          DrewKeen is offline
          Old 4th June 2006, 05:45   #4 (permalink)
          TCM
          TCM's Avatar
          Yes, the ethanol is killing my mileage as well. But not much we can do about it. This new plan looks like it is here to stay for awhile. At least we still have around 380bhp to work with I am assuming after the fuel change, haha.
          T.C.
          '01 Silverstone M5
          SuperSprint:X-pipe
          TCM is offline
          Old 4th June 2006, 06:36   #5 (permalink)
          Machtig
          Machtig's Avatar
          Mine has not changed at all. If you're having problems, do some PM (preventive maintenance) and I will bet your problems will be over.
          Machtig is offline
          Old 4th June 2006, 21:10   #6 (permalink)
          jclyman
          jclyman's Avatar
          I would NOT use gas with over 10% ethanol ... actually, I wouldn't use it at all. I think BMW says the same thing ... 10% is OK, by BMW. But, they also state it will reduce your gas mileage and performance slightly.
          - Daniel Boorstin
          jclyman is offline
          Old 4th June 2006, 22:10   #7 (permalink)
          Laidback
          do 76 station have ethanol?
          (New) Mfest featured on Las Vegas Review Journal
          Click here for the article...
          For the latest talk about Mfest pls click here Mfest forum
          myspace
          "Illegitimus non carborundum"
          Laidback is offline
          Old 4th June 2006, 23:11   #8 (permalink)
          jclyman
          jclyman's Avatar
          Not sure, but all stations are required to list if Ethanol (or the old MTFB ... or whatever it was called) is in the gas. A note will appear on all gas pumps that use additives in their gas.
          While I will use 76 or Shell or Texaco, I prefer Chevron as it includes Techron (which BMW dealers sell over the counter), as does Texaco.
          - Daniel Boorstin
          jclyman is offline
          Old 4th June 2006, 23:58   #9 (permalink)
          Laidback
          i was just surprise when i saw the ethanol badge on a 76 station (never really paid attention before about it)...i agree i prefer chevron gas if possible...
          myspace
          Laidback is offline
          Old 5th June 2006, 05:15   #10 (permalink)
          Lscman
          You make it sound as if oil companies are suddenly raising octane rating of their blended fuels. This is not happening.
          If gas is rated 93 octane, it really does not matter much if it has lead, cerium and/or alcohol in it. The knock characteristics of fuels we buy will not change significantly with the elimination of MTBE. Octane is the only useful measure of knock resistance...read the pump.
          Lscman is offline
          Old 5th June 2006, 05:36   #11 (permalink)
          Shakazulu12
          Shakazulu12's Avatar
          Forgive me for not paying attention to anything..... But is this a nationwide change? I was trying ot figure out today why I got about 80 miles less on my latest tank than I normally get.
          Shakazulu12 is offline
          Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post! Add this post to your Facebook Profile Add this post to MySpaceStumble this Post!Google Bookmark this Post!
