PPI Results - Good, Bad, Run? Help Needed - BMW M5 Forum and M6 Forums
Old 1st June 2006, 00:41   #1
JPGisMe
JPGisMe's Avatar
Garage: 2002 TiSilver BMW M5
Hi, I just had a PPI done on a 2001 M5, approx. 30,000 miles, $36k. I'm not a car guy (yet!), so I have no idea if the problems listed are serious, consistent with any 5-year old M5, or something that should warrant a significant reduction in price. Any thoughts are very, very much appreciated.
Here's the list:
Tires Cupped and Noisy
Valve Cover Gaskets Seeping
Both Front Motor Mounts Leaking
Moisture on Bell Housing. Fluid Accumulating in Belly Pan.
A/C Belt is Dry Rotted and Cracking
Oil is Dirty. Due for 30k Major Service.
Rear Differential is Seeping
Window One Touch Feature Inoperable from all Switches except Driver's
Front End of Car has been Painted
Cigarette Lighter Element Sticks when Pushed in
The shop didn't give me an exact quote, but seemed to suggest it would cost several thousand dollars to fix everything. Rear differential and motor mounts were said to be major expenses. No warranty, so everything will be out of pocket.
Again, I appreciate any comments you all have. The car drives well (fast, tight suspension) and has a color combination I like, but if this is a list of problems that I wouldn't have to deal with on another car, I'm willing to wait it out.
Thanks for the help. If this isn't the M5 for me, there's one out there with my name on it!
JPGisMe is offline   Reply With Quote
Old 1st June 2006, 02:39   #2
cassino95
cassino95's Avatar
Garage: Jet Black M5
Hi,
Sounds like you had a thorough inspection...ie. cigarette lighter sticking
, dam thorough. From the list the ones that trouble me are the leaks
which from the rear to beneath the engine are a royal pain and costly too.
Valve cover leak is no biggie. The front end paint suggest that it's been in
an accident or fender bender.
With all the M5's out there, I would personally keep looking, but that's just me. Keep your emmotions out of it until you bought one.
01' Jet Black/Caramel M5
96' Alpine While/Modena Natur Nappa M3
cassino95 is offline   Reply With Quote
Old 1st June 2006, 17:38   #3
JPGisMe
JPGisMe's Avatar
Thanks, Cassino. Is this normal for beasts of this age/mileage?
I just got a quote from the PPI shop for $5500 for all the work, so this deal looks like a no-go. But I'm still not clear on whether any of this is "normal" for a beast of this age, and how much should/could have been avoided through routine maintenance or servicing while the car was still under warranty. Thoughts?
The car does drive well, so I'd still be tempted if the price were right, but I've got no idea what other issues could be lurking with this particular beast if some of the issues listed above have arisen as a result of poor maintenance or operations.
Thanks for the help. This board has really been great (although it's a TREMENDOUS time suck once you get addicted!).
Old 1st June 2006, 17:59   #4
Salty
Salty's Avatar
Garage: 2000 M5 Avus Blue
Looking at it another way, if you buy the car (colour combo you like!) and do all the repairs, you will have a 100% sound beast for $41,500 ... or less if you can bargain them down a bit with your repair list.
I personally would have an oil analysis done - the very dirty oil and the leaks are evidence of poor maintenance practices. Many M5 diffs have seepage. It is a common problem and does not necessarily mean the diff needs replacing. Change the diff oil, snug up the bolts and "Bob's your mother's brother".
Virtually any M5 you end up buying will have to have something done to it right away.
Then again, hold out for a board member's M5 and you know it will have been treated right. I like my car but wish I had waited a bit longer before buying.
Does the M5 in question have any after-market goodies?
Good luck.
Salty.
2000 M5 Avus Blue
Interior: titanium trim, Motorsport tri-color fabric seat & door panels w/ black leather, split folding rear seats w/ ski bag, sunshades, alcantara, DSP, etc, etc.
Mods:
- stock 2003 angel eyes upgrade
- Supersprint Magnum exhaust and X-pipe
- Rogue Engineering tranny mounts
- hardwired Valentine One.
- DME upgrade Sept 08.
- Red Line 70W80 tranny fluid
- door mounted cup holders
Salty is offline   Reply With Quote
Old 1st June 2006, 18:18   #5
JPGisMe
JPGisMe's Avatar
The beast in question has an aftermarket exhaust and suspension. Both are nice, and I'd take the car with them over without, but not enough to make or break the deal.
I can inquire about the oil analysis. Is that the same thing as a leak-down?
My concern is exactly what Salty's raised--namely, that these issues aren't all "normal" and might be indicative of other potential problems down the road related to maintenance or servicing. Thus, $5500 might be just the beginning.
While I'm prepared to spend the cash for a beast and am aware of (and comfortable with) the expected annual operating costs, it seems like most of the advice on this board is to limit the potential downside on the back end by getting as good a car as possible on the front end.
But oh how I want to be zooming along in my very own beast right now!
Old 1st June 2006, 18:23   #6
Ben Carufel
Ben Carufel's Avatar
Garage: 2000 Estoril Blue M Coupe
The oil analysis mentioned above is not a leak-down, which tests (in general) the strength and performance of the gaskets in the motor.
The above poster was referring to an actual microscopic oil analysis done by a lab. See the following link:
http://www.blackstone-labs.com/gas_engines.html
Ben
2000 Estoril Blue M Coupe [Perfection]
2000 Biarritz Blue 528i Touring [Hauler]
1989 Alpine White S50 325i [Fun Machine]
1967 MGB GT [Classic]
Ben Carufel is offline   Reply With Quote
Old 1st June 2006, 19:42   #7
Habu
Garage: E39 M5 TiAg
Sales Feedback: (3)
JPGisMe,
$5.5K may be just the start. I wouldn't think the cracked belt, lighter & window would be a big deal. The front end paint, if it was just to clean up the rock marks, would be ok. I'd check to see if the seems on the fender, hood and bumpers are lined up. I wouldn't be too concerned about the dirty oil. I think the oil turns color pretty quickly even after its been changed recently.
The front tire cupping may be a suspension issue, you mention you have aftermarket suspension pieces so if there was uneven tire wear I'd think it may be an alignment issue but cupping of the tires could be balancing or shocks. Moisture from oil could be elusive to repair. To me, low $40K is a good deal for the mileage and year. But like you mention, is this it or the tip of the iceburg?
I'd walk unless you really have your heart set on this car.
Bob
Habu is offline   Reply With Quote
Old 1st June 2006, 19:54   #8
wilsodh
wilsodh's Avatar
This list does not look terribly atypical. As Salty mentioned, slow seepage is not uncommon and may not necessarily be an issue ("leaking" is obviously a different matter). I wonder how many M5's on the road today could hold up to a thorough PPI without some of these items being flagged. That said, the previous owner does not seem to have been a maintenance fanatic. I assume you have the records of when the oil was last changed? You would need this to properly assess whether 'dirty oil' is a concern.
I'd say it may be in the running... IF you are crazy about the color combo and features and it drives perfectly. You could used the PPI to talk the price down. Otherwise, keep looking and get a better feel for what's out there.
Dave
'00 Royal Red/black/walnut M5
'El Diablo'
’00 Black/black DA s/c M5
Carrillo rods, Arias pistons,
Schrick cams, Vortech T-trim,
Supersprint headers/exhaust,
Old 1st June 2006, 21:31   #9
ard
Super Moderator
ard's Avatar
Pass.
This is indicative of a car not well cared for...
While I agree that this is not unsual (my car had two diff leaks, one valve cover leak) these were addressed when discovered- not ignored.
If they will fix it, THEN sell it to you- maybe.
A
Old 1st June 2006, 22:53   #10
olis1
olis1's Avatar
Garage: 2001 M5 Dinan S1
Well I bought my '01 M5 with 30k miles and it had a bunch of oil on belly pan that wasn't caught by the PPI. I was pissed. It was a rear main seal leak. This alone is a $1000+ job so be careful. That price is really low though. I paid more then $10k above that but my car had over $20k in mods so its more difficult to value.
What brand tires are they that they cupped. If Michelins I'd be concerned but if they are Kuhmos or something cheap it may be the fault of the tire.
Why not get the seller to fix it all.
olis1 is offline   Reply With Quote
Semi OT: Almost the end of an era. It's been a good 6 year run. Clem E39 M5 and E52 Z8 Discussion 4 10th May 2006 06:24
Help!!! good quality body shop needed in San Jose sgou E39 M5 and E52 Z8 Discussion 1 30th September 2001 18:30
The good, The bad, and the Ugly (update on ME) fais2000 E39 M5 and E52 Z8 Discussion 21 15th June 2001 19:26
DRAG STRIP RESULTS!!!! Yupkwondo E39 M5 and E52 Z8 Discussion 23 13th June 2001 07:03
good news and bad news Dr.Mike E39 M5 and E52 Z8 Discussion 9 11th January 2001 06:41
