Old 29th May 2006, 21:23   #1
bimmernut1
bimmernut1's Avatar
Garage: Ti Silver M5, Red Porsche C4S
Tire replacement - 2 or all 4
I'm curious whether anyone else has got their car on a 2 tire replacement routine. On my other cars, the rears always wear faster so I tend to just replace those and leave the fronts on and replace them later. Financially, it's always easier to come up with the cost for 2 at a time. The only time I've replaced all 4 is when I've changed manufacturer.
On the M5, they appear to be wearing at a similar rate although I need to replace the fronts now due to alignment wear on the passenger side tire. I bought 4 new Toyo Proxes T1-R's but am considering replacing just the fronts, then running the rears for a few more months. This would get the M5 on a similar two tire replacement routine as well.
I'm curious if anyone else has intentionally put their M5 on a two tire replacement rotation or do you typically just replace all 4 even if one pair still has some mileage left? Anyone seen any difference in M5 handling after the breakin period while running new tires on one end and old ones on the other?
bimmernut1 is offline
Old 29th May 2006, 21:32   #2
trackstar
trackstar's Avatar
Garage: 00 M5 (Carbon BlacK)
I've replaced mine in pairs, since the rears do wear faster than the fronts. As long as you stick with the same tire, shouldn't be a problem IMO.
BMWCCA member#306145
2000 ///M5
M-technic spoiler, B&B exhaust, Dinan rear sway bar, Stoptech BBK, Carbotech pads, Hella euro AE headlights.
"I am a professional driver. This is a closed course."
Life is not a journey to the grave with the intention of arriving safely with a pretty, well preserved body. The goal is to skid in broadside, tires smoking, body all dented, leaking fluids, gas gauge on empty, throughly used up and worn out, proclaiming, "Holy sh!t, what a ride!"
trackstar is offline
Old 29th May 2006, 21:50   #3
imolaman
imolaman's Avatar
Garage: 2001 BMW M5 Imola Red
Send a message via MSN to imolaman
I agree with trackstar. Keep the same brand on both axles. I found that the fronts last approximately the same time as two sets of rears.
BTW I have had good experiences with the Toyo Proxes T1-R's. They are very good in terms of traction but does perform less than satisfactory in wet weather. I'm not sure of the weather patterns in Kansas but over here I changed to the Dunlop SP-Sports when the summer rains started falling. There is not many tires better than those for wet weather in my opinion.
All the best,
Rudi
2001 Imola Red II E39 M5 - Stock
imolaman is offline
Old 29th May 2006, 22:30   #4
ard
ard's Avatar
I run 275s front and rear, so I just rotate to get uniform wear- all 4 at the same time..GENERALLY- I will usually buy 4, but if a pair have a few K left in 'em, I'll put those to the rears- mount fresh rubber up front, and run them down real quick. Then pop the last two on.
In dry conditions I am pretty unconcerned with running them down to 1/32..
A
ard is offline
Old 29th May 2006, 23:01   #5
bimmernut1
bimmernut1's Avatar
Thanks guys. Sounds like there should be no handling problems just changing two. I suddenly remembered I have T1-S's on now. I'm not sure I should have R's on the front and S's on the rear. If I can't mix them (probably can't), I'll go with all four this time then work my way into the 2 tire rotation next time. I'll stick the old tires in the attic just in case of emergency. They should fit right in with the other 8 or so tires from other cars I've saved for the "just in case" scenario that has never happened.
The summer tires must all come off in November or so anyway for a dedicated winter set. This is going to be my daily driver and we do get some snow here.
Kinda disappointed to hear the R's don't perform as well in wet however. I've had good performance out of the S's in the wet and I thought the R's were supposed to be the latest technology.
Old 29th May 2006, 23:33   #6
Jayson
Jayson's Avatar
Garage: m5
Send a message via AIM to Jayson
IF the other tires have less than 50 percent life remaining then replace them otherwise it's fine to change pairs provided its front or rear together just keep the same exact tire.
Jayson is offline
Old 30th May 2006, 00:41   #7
ard
ard's Avatar
L M A O
My wife is constantly whining about a rack I have up in second floor of the barn... just 7-8 spare tires for 'emergencies', two sets of wheels for two other cars, a spare front and rear BMW wheel... one can never be too prepared!
(Apparently the horses feel it crowds their hay...)
A
PS I had the opportunity to use my spare front wheel and tire....AND to mount a spare Dunnie while I waited for a warranty replacement PS2 to arrive (road hazard) so I felt quite vindicated as a pack rat.
ard is offline
Old 30th May 2006, 04:22   #8
bimmernut1
bimmernut1's Avatar
Ard, glad I'm not the only tire pack rat. Right now in addition to the used ones in the attic, I've also got three new sets in the basement. 1 for my M5, a basically new set of winter Blizzaks to fit an e32 (sold the car right after I bought the wheel/tire set), and a new set of Bridgestone S02a's for the 993. I bought that set when one of my tires lost air for no apparent reason. After pumping it back up, it's held for 4 months now, so I'm trying to extend the current tires as long as possible. (Just 1 more Autocross/DE).
Jayson, does the reason behind the 50% guideline have something to do with the rolling radius of the tire and the potential impact on ABS and DSC if the ratio front to rear changes from stock? I'm guessing, only thing I could think of.
295/35/ZR18 on stock rear wheel? M5girl E39 M5 and E52 Z8 Discussion 40 27th March 2009 18:26
Replacement tire opinions for 21" wheels Z8M5 E60 M5 and E61 M5 Touring Discussion 9 20th April 2006 22:48
Tire Repair vs. Replacement scchang E60 M5 and E61 M5 Touring Discussion 7 5th March 2006 01:35
Spareless woes... anyone buy tire replacement warranties? Anzir E39 M5 and E52 Z8 Discussion 6 30th August 2005 00:21
Replacement tire help! TexasM5 E39 M5 and E52 Z8 Discussion 2 15th July 2003 16:42
Page generated in 0.15942 seconds with 11 queries
