Old 25th May 2006, 15:49   #1
Manx M5
Manx M5's Avatar
Garage: March 2006 E60 M5, Interlagos Blue
Break Judder with gentle breaking
Hi Guys.
I have read a number of posts on warped disks, or more to the point some of you guys believe that its not a warped disk but more build up on the disk that causes judders through the steering wheel with gentle breaking..
Ive been to the garage and they have said this is rubbish.. and said ill need new front disks or rotors as u guys call them..
If my disks are not warped is there are fix without buying new disks?
Any help would be great..
ps i have recently fitted new OE front pads
Its not the pace of life that concerns me.. its the sudden stop at the end!
March 2006 M5
Speed Delimited
Manx M5 is offline
Old 25th May 2006, 17:27   #2
wilsodh
wilsodh's Avatar
Originally Posted by Manx M5
Hi Guys.
Its not rubbish. Not all pedal pulsation is due to warped discs. One reason is brake pad material operating outside of its designed temperature range and it has left a thicker than normal deposit in one area of the disc surface, creating a "sticky" spot that will grab with every revolution of the disc. Another source may be grease or other foreign materials, usually deposited on the disc during wheel maintenance, can likewise create a slippery spot on the disc, also creating the sensation of a grab or warped brake disc. You mentioned you recently had oem pads installed...
Might want to get a second opinion before shelling out $$ for new disks.
'00 Royal Red/black/walnut M5
'El Diablo'
’00 Black/black DA s/c M5
Carrillo rods, Arias pistons,
Schrick cams, Vortech T-trim,
Supersprint headers/exhaust,
wilsodh is online now
Old 25th May 2006, 17:38   #3
cosioboy
cosioboy's Avatar
Garage: 2000 M5 Carbon Black
I second that - don't shell out money before you are sure.
Here is a great article you can read, I encourage you to look through the StopTech's website, especially their White Paper section. Here they dispell the myth of warped discs. Also, you can search through Dave Z.'s website, a lot of great info there...
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
THE WIFE (divorced but with visitation rights)
Das Beast:: Carbon Black 2000 E39 M5
Factory Love: PDC, Folding rear seats with ski bag, Black extended leather with Alcantara headliner, aluminum trim (swapped from burlwood)
The Looks: Full 2001+ facelift upgrade: Euro AEs, Euro Celis taillights, steering wheel, grey instrument cluster, ACS Rooflid Spoiler
The Ride: Dinan Stage III Suspension, Dinan Front Strut Tower Brace, TCD rear sway bar brackets, X5 4.8is thrust arm bushings, 275/35/18 Michelin Pilot Sports all around on rear OEM 9.5” rims
SuperSprint Me: Supersprint Headers, Supersprint Magnum exhaust, Supersprint X-pipe
Stop-and-Go: StopTech 355mm front BBK (red calipers, cross drilled rotors, Axxis Ultimates pads), Powerchip Gold 93 (v3), Dinan clutch assembly, Dinan lightened flywheel, Cold Air Intake, UFMotorsport IATS
SolelyManualGear: Rogue Octane SSK with WSR, Rogue Tranny mounts, Rogue Clutch Stop, UUC illuminated aluminum shift knob
The Sound: MB Quart Reference Series component speakers all around, M-Audio subs retrofit, Dension Ice>Link Plus i-Pod adapter
The Light: PIAA custom 3-watt Luxeon blue AE LEDs, Xenon/LED Interior Lighting Kit, 6000K fog HIDs, Euro rear fogs activated
Tech Gadgets:16x9 widescreen, MKIV DVD Sat Nav, Bluetooth, Valentine 1
Little extras: 35% Tint, M5 Trunk Mat, TEC cupholder, custom ///M5 Ultimate Pedals, extra OEM staggered wheels with Pirelli SnowSport 240 winter gear, Dinan trunk insignia
THE MISTRESS
Das 'other' Ubber-Beast:: 2008 Audi B7 RS4
Named "Buffy", the Exotic Car Slayer
Factory Love: Sprint Blue, Ivory Leather, Premium Package, Titanium Package
Owner Love: Stasis Motor Sport Suspension'ed, MTM 10mm Spacer'ed, Euro RS4 flat steering wheel'ed, JHM Short Shifter'ed, StopTech Stainless Steel Braided, Tinted, Valentine'd, Lamin-X'ed, Lidatek'ed, Clear Bra'd, Milltek'ed de-resonated valved Exhaust, de-badged, and most of all: De-Bangled! Dunlop Wintersport 3Ds on extra set of stock 19's for all-weather FUN courtesy of Quattro GmbH
THE WEEKEND Track ESCAPE
Das Mini Beast:: Sparkling Graphite Metallic 2008 135i
Factory Love: 6-spd manual, Black Boston leather, ///M Sport Package, Heated Seats
Owner Love: JuiceBox 3 PnP, Rear Fogs Retrofit, 255/35/18 non-RFTs, blackened grills, 35% ceramic tint, BavTech Scanner, hardwired Escort 8500ix, various other goodies. Upcoming mods: aFe Dual Cone Intake, Active Autowerke Intercooler, Dinan Oil Cooler, Dinan Stage III Koni Suspension, BMW Performance Exhaust, Macht Schnell Gauges, more to follow...
cosioboy is offline
Old 25th May 2006, 17:45   #4
Talat Hameed
Garage: M5 2000 Silverstone Metallic
Hi Guys.
I have a similar problem. What did you find out and how was it fixed?
Talat Hameed is offline
Old 25th May 2006, 20:29   #5
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Hi Guys.
Check the thrust arm bushings. Classic for judder on gentle braking. And check the ball joints while you are there.
gsfent is online now
Old 26th May 2006, 14:15   #6
Manx M5
Manx M5's Avatar
Hi Guys, thanks for the responses, that article is very informative but i can not see where it says how to cure the problem of pad material deposits on disks...
I have just had a major service completed on her and they say they check all the ball joints and bushes.. they found the rear antiroll bar brackets were broken and missing so im inclined to belive them.
Hard braking doesnt seem to show up the judder, its only on very gentle braking, that article (http://www.stoptech.com/tech_info/wp...rakedisk.shtml) seemed to refer to hard braking..
Also had two rear pirelli pzero rossos fitted yesterday, christ what a difference to traction and they are not even scrubbed in yet! Had them fitted before to a 350z i had and they were good on that but the M5 seems to love them!!
March 2006 M5
Speed Delimited
Manx M5 is offline
Old 26th May 2006, 16:08   #7
Luke@tirerack
Luke@tirerack's Avatar
Garage: 2001 Porsche Carrera
Originally Posted by StopTech white pages
Myth # 1 – BRAKE JUDDER AND VIBRATION IS CAUSED BY DISCS THAT HAVE BEEN WARPED FROM EXESSIVE HEAT.
The term "warped brake disc" has been in common use in motor racing for decades. When a driver reports a vibration under hard braking, inexperienced crews, after checking for (and not finding) cracks often attribute the vibration to "warped discs". They then measure the disc thickness in various places, find significant variation and the diagnosis is cast in stone.
When disc brakes for high performance cars arrived on the scene we began to hear of "warped brake discs" on road going cars, with the same analyses and diagnoses. Typically, the discs are resurfaced to cure the problem and, equally typically, after a relatively short time the roughness or vibration comes back. Brake roughness has caused a significant number of cars to be bought back by their manufacturers under the "lemon laws". This has been going on for decades now - and, like most things that we have cast in stone, the diagnoses are wrong.
With one qualifier, presuming that the hub and wheel flange are flat and in good condition and that the wheel bolts or hat mounting hardware is in good condition, installed correctly and tightened uniformly and in the correct order to the recommended torque specification, in more than 40 years of professional racing, including the Shelby/Ford GT 40s – one of the most intense brake development program in history - I have never seen a warped brake disc. I have seen lots of cracked discs, discs that had turned into shallow cones at operating temperature because they were mounted rigidly to their attachment bells or top hats, a few where the friction surface had collapsed in the area between straight radial interior vanes, and an untold number of discs with pad material unevenly deposited on the friction surfaces - sometimes visible and more often not.
In fact every case of "warped brake disc" that I have investigated, whether on a racing car or a street car, has turned out to be friction pad material transferred unevenly to the surface of the disc. This uneven deposition results in thickness variation (TV) or run-out due to hot spotting that occurred at elevated temperatures.
here's an interesting read
Luke Pavlick
Perfomance Specialist
ASE Certified Master Tech
For more info or to place
an order please click the
link below my name or call
800-428-8355 ext. 362
for prompt personal service.
www.tirerack.com
Luke@tirerack is offline
Old 26th May 2006, 17:09   #8
wilsodh
wilsodh's Avatar
Interesting indeed. Thanks Luke. I've long wondered if the 'warped disk' concept had some urban myth aspects to it.
Dave
'El Diablo'
Old 30th May 2006, 15:29   #9
Manx M5
Manx M5's Avatar
Yeah this is the same article that is linked above.. i think.. it explains the issue with hard braking and does not say how to remove the build up of friction material..
should i get the disks lightly skimmed? or is there a less drastic fix..
It seems to me that it doesnt matter what we call it warped disks or build up of friction material i appear to be facing the same bill for a set of new front disks!
March 2006 M5
Speed Delimited
Manx M5 is offline
Old 30th May 2006, 15:53   #10
welsh_willo
welsh_willo's Avatar
Garage: Avus Blue e39 m5
Send a message via MSN to welsh_willo Send a message via Skype™ to welsh_willo
try some more abrasive pads
Tom
try some more abrasive pads for a stint other than the stock pads ?
dave Zeckhausen will advise you if you pop him a mail
remember Jons pagids < yellows ? ..> ... they cleaned the discs but were much more agrresive on the surface ..
the stoptech site gives you a number of options if you mooch thru it ..
BTW how many miles have the dics done ?
Rob
Welsh _ Willo
welsh_willo is offline
Correct break in procedure, finished at 3100 miles / 5000 km Gustav E60 M5 and E61 M5 Touring Discussion 66 12th November 2008 20:55
Brake Judder skyetripper E39 M5 and E52 Z8 Discussion 14 31st May 2006 19:08
Is the 1K mile break in period "mandatory" or "suggested"? wolfturbo E60 M5 and E61 M5 Touring Discussion 11 8th January 2006 23:58
Breaking in the M6 M-bitious E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 2 7th November 2005 17:35
Spring Break: CT to Ohio mikhail E39 M5 and E52 Z8 Discussion 8 11th March 2004 01:11
Page generated in 0.17145 seconds with 11 queries
