Old 24th May 2006, 22:43   #1
olis1
olis1's Avatar
Garage: 2001 M5 Dinan S1
need feedback from owners with Dinan Stage III suspension
I have the Stage III suspension from Dinan. Its the Koni setup. I bought the car with this setup so I can't really tell how it is compared to stock since I've only briefly test driven M5's with stock suspensions and that was all before I drove this car.
Anyways, I notice you can still drive the car a but beyond the suspension. What I mean is things still move around quick a bit at times. I'm referring to maybe getting on the power hard and going through a 40 miles an hour sweeper with a bump or 100mph plus on freeway gradual sweep with a bump. Car just rocks around more then I'd like.
I don't know how to quantify this but just want to get an idea if this is normal. Its almost like the rebound is slower then it should be. I checked the front and its set at 3/4 turn from full soft which is the dinan spec i got from the previous owen. Can't check the rear.
Most of the rocking seems to come from the rear. Keep in mind my base point for comparison is my 97 M3/4 that I sold. That car never moved around on you and you could never really get it to a speed that caused suspension movement that made you nervous.
I guess what it comes down to, is.. is this normal for a heavier, higher center of gravity car?
I do love the current ride for comfort.
Anyone in South OC with same suspension so we could compare?
Thanks,
Jon
olis1 is offline
Old 24th May 2006, 23:31   #2
KirklandM5
KirklandM5's Avatar
Garage: 2001 M5 Titanium Silver
Send a message via AIM to KirklandM5 Send a message via Yahoo to KirklandM5
well the guys at dinan told me...from the factory... the M5 has a front spring rate within 5% of where they did their 540i suspension....so I assume Dinan takes the understeer out by relatively stiffening the rear...with stiffer rear and a bigger bar out back..
With a firmer rear setup, I'm not surprised you made the comments you did....maybe try reducing the shock damping out back or going to a softer rear bar setting.
2001 E39 M5 Titanium Silver/Silverstone
1997 BMW M3 Gruppe N Race Car
2005 X5 4.4i
KirklandM5 is offline
Old 25th May 2006, 02:29   #3
EM5PWR
EM5PWR's Avatar
Garage: 02 M5
it gets a little wiggly at times, you just need to get used to the movement i guess.. i have now , at first i didn't care for it , but it's the driver not the car..
EM5PWR is offline
Old 25th May 2006, 04:40   #4
Need4Spd
Need4Spd's Avatar
Your '97 M3 did not have 400 bhp and the torque of the M5. Going on the accelerator hard in a corner and hitting a bump at the same time will break traction and give you some wiggle, even with a Dinan setup. To reduce this, you could try playing with tire pressures or moving the rear bar links one hole further out (softening roll stiffness at the rear). That will take some load off the rear and make the front tires work harder relative to the rears.
Need4Spd
Need4Spd is offline
Old 25th May 2006, 04:41   #5
MCarRacr07
MCarRacr07's Avatar
Garage: 08 Space Grey M3
Sales Feedback: (4)
I have the JRZ set-up with the camber plates installed up front.....and I have not experienced any of that "butt bounce" you describe....what type of bushings are in your rear sway bars???...if anything my set-up might be a bit "too firm"......though I'm not sure what the big diff is between the JRZ and the Koni.
I went with JRZ only to try something different as I already had a koni set-up in my last car....
Good Luck
MCar
MCarRacr
89 M3 (Track Car)SOLD
95 M3 (Track Car)SOLD
08 M3 (lil Beast)
00 M5 (BIG Beast)R.I.P
00 540 Sport (Gone)
03 330xi (Gone)
06 330xi (Gone)
08 328xi(New Arrival)
04 325xi(New Arrival)
MCarRacr07 is offline
Old 25th May 2006, 05:41   #6
olis1
olis1's Avatar
Good Luck
MCar
I have the Dinan bushings. I only know this because I broke a sway bar brkt and switched from stock to beastpower brackets. Had the bushings out and they had a dinan stamp.
I'm surprised the replies are suggesting softening up the rear sway or softening up the damping. I was kind of thinking I need a little quicker damping or a little less roll but maybe is a combination of the car settling down due to all the torque.
The car definitely has very little understeer. In fact I think it could probably follow the M3 through a long sweeper a the same speed. Grip is good.
olis1 is offline
Old 25th May 2006, 06:07   #7
KirklandM5
KirklandM5's Avatar
Yeah, the M5 actually has plenty of grip even from the factory, but what we don't like is the "balance"....
Yes, when you hit the M5 throttle, there is quite a bit of weight transfer to the rear.
As regards to JRZ, those shocks probably have more optimal damping curves for high and low speed damping than what the Koni can do. The whole idea of us using fancy 2-4way dampers in racing, is to smooth out the bumps and be able to lay down power where the track is bumpy.
The LSCMAn can probably comment on what do with valving and anti-roll bar setup.
Old 25th May 2006, 20:41   #8
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
I have the same setup, car came that way. I have no float at all. The only thing I have considered was slightly stiffening the front between and 1/8 and a 1/4 turn; the compression is a little soft for my taste. Otherwise I find the combination of ride and balance on the street incredible. This is how it should have come from the factory IMHO.
gsfent is offline
Old 25th May 2006, 21:47   #9
SDImolaS2
SDImolaS2's Avatar
Garage: 03 M5 Imola Red Dinan S2
Send a message via AIM to SDImolaS2
Interesting,
For the most part my car s/ Stage III is pretty locked down. The time the softness in roll stands out to me is in rapid transitions from hard cornering side to side. The car just takes much longer to transition and take a set than my stock M3/4. However once there it's very precise and stable to bumps and small adjustments. You can unsettle the suspension somewhat with large throttle adjustments, but it is still quite controlable and entertaining.
My M3's shocks are starting to go and that can create a side to side wobble that's simular to what you are describing. How many miles on your M5's shocks? I'm not sure what the life span on koni's are........ the instability doesn't sound normal on your M5. What kind of tires and pressure are you running?
If your are ever down in San Diego and want to compare. I also will be driving up to LAX several times next month mid-day/mid-week.
Paul
Regards
Paul
03 M5 Imola/Black: Sport,Shades,M Bass
Dinan S2
Dinan forged wheels
Passport SRX
Lojack
Ultimate Cupholders
Jabbra Bluetooth
StopTech SS brake lines
PS2 MO 275 f/r
98 M3/4a, 02 Yukon, 02 Audi S8
San Diego
SDImolaS2 is offline
Old 25th May 2006, 23:01   #10
mr_bock
mr_bock's Avatar
Garage: 2002 M5, Sterling Gray
Did you check all mounting bolts/nuts for proper tightness? Check rear sway bar brackets, etc... make sure all is in working order. I had the Dinan front camber plates but the put too much negitive camber (wore the insides of the front tires out). The shop said the plates are non-adjustable? I went with K-Mac hybrid camber plates and a neutral alignment. I don't notice the rear bouncing like you are describing????
Good Luck, hope you get this sorted out!!!!
2002 Sterling Gray, Black and Aluminum interior
UUC Short Shifter & DSSR
UUC Clutch Stop
UUC Transmission Supports
UUC UltraSmooth CeraMetallic Clutch/LWF
Active Autowerks Cold Ram Air Intake - Modified
Air Plenum Heat Shield, 1700 degree black Jet-Hot coating
Alpine amp for JL Audio Sub Woofers
UFMotorsport S62 Intake Air Temp Sensor Relocation
Dinan Stage II Suspension
Dinan 3.45 Rear Diff. Gear Set
Dual JL Audio 10" Sub Woofers
K40/Laser Defuserplus, hidden install
K-Mac Adjustable Caster/Camber Plates
Kelleners Aluminum Sport Pedals & Foot Rest
MB Quart speaker replacement
NAV MKIV DVD
StopTech SS Brakelines
Axxis Ultimate Brake Pads
EvoSport Performance Underdrive Pulley Set
TubiStyle Cat-Back Exhaust
Power Chip 93 Gold - Modified & Sport 'On'
Perma-Cool Electric Engine Fan (no mechanical fan!)
Michelin Pilot Sport II Tires (front/rear stock sizes)
Royal Purple Synchromax Transmission Oil
Red Line 75W90 Differential Gear Oil
Sirius Radio receiver
SS Headers, EVO High Flow CATS
Zionsville Aluminum Radiator w/ Dual Speed Fan
My latest toy... a 2001 360 Modena Ferrari
My 'other' car is a supercharged 1996 911 C2 993
mr_bock is offline
Dinan JRZ Stage III installed- initial impressions EdP E39 M5 and E52 Z8 Discussion 32 8th November 2004 20:16
FS Dinan Stage III kit in UK Carrera2RS For Sale or Wanted 0 14th August 2004 17:50
Wahoo!! Dinan Stage III installed! Stealthne E39 M5 and E52 Z8 Discussion 16 12th January 2002 19:43
Question for Dinan Stage III Owners JonB E39 M5 and E52 Z8 Discussion 15 11th January 2002 16:14
Dinan Stage two suspension BROKER E39 M5 and E52 Z8 Discussion 6 22nd January 2001 23:26
Page generated in 0.18254 seconds with 11 queries
