6th May 2006, 17:46
#11
02 M5
dinan stage 3... great stance with a great ride ..
6th May 2006, 17:49
#12
Several
Might I suggest you give Ground Contol a look. We have installed this system on many board members cars and have had nothing but positive feedback.
Ground Control E39 Suspension System
Please let me know if we can answer any questions for you.
6th May 2006, 17:50
#13
2001 BMW M5 Jet Black
How much is the dinan stage 3 installed? Whould I need to change my wheels (19 in Hamanns PG3)?
6th May 2006, 17:59
#14
Originally Posted by Le3
I currently have Hamann 19 inch PG3's on the car. Would you suggest going to a different wheel as well as the sway bar, suspension, tires, etc. to improve the handling. I am always so nervous with the low profile tires and potholes.
I wonder what they weigh? A light weight wheel really makes the car feel more nimble. I went from 4 rear oe wheels with 275's (oe rear wheels weigh around 25-26lbs each) to dinan wheels which weigh around 17 lbs each and i could really feel the difference. I'd bet a 19" wheel weighs considerably more than the oe wheel.
6th May 2006, 18:04
#15
What type of Mods would you need to improve the handling significantly?
The M5 doesn't need necessarily more speed, but on that back roads how can you make your car keep with the Porsche?
Suspension? Sway bars?
Please give me your incite. I am considering selling my M5 to go back to a Porsche, but the M5 is so nice. I just want that go-cart feel again?
Is it possible?
I have the JRZ coilover set-up.Sway bars & camber plates(Overkill unless you track the car) and I can tell you that the lean/roll associated with the car has all but disappeared. And this is on stock rims/rubber.......
Regards
MCar
7th May 2006, 07:06
#16
02, M5 Sterling Grey
I think the E39 M5 is actaully faster that a standard 997 off the line, but on the back roads the 997 is faster.
I think you are right, I also think its faster once you get up to speed, 60,80 and 100. I recently killed a 997 cab. I am pretty sure it was a Triptronic, but I was very surprise with the right gear how much fast the beast was!
Go Kart, it will never be, sorry. Given everything equal, the 997 should be faster around the twisties. It sounds like suspension will make a BIG difference, now the question is which one?
2010 X5 3.5 diesel, dialy driver, loaded, Awesome Car!
2002 E39 M5 Sold
2004 X5 4.8is Sold
2005 X5 3.0 RIP
1995 E36 325i Sold
1989 E30 325i RIP
1972 3.0s Sold
7th May 2006, 17:33
#17
m5
997 0-60 is rated at 4.1 to 60 and the E39 m5 is rated at 4.8 The 911 is much easier to launch I got my money on the 911 from a stand still. That said, i was just refering to around the back roads.
7th May 2006, 17:40
#18
I don't think that the 997 is 0 - 60 in 4.1. According to Porsche and Motortrend the 997 does 0 - 60 in 4.8 and the 997S does it in 4.6. Still it would be a good straight stand still race, but the Porsche would kill us on the twisties.
7th May 2006, 21:17
#19
Administrator
BMW M3 DCT Sedan / Limousine
997 has better traction off the line thanks to the tail engine.
7th May 2006, 23:00
#20
Is it possible?
Feel free to disagree, but the most important aspect of handling is balance, not grip. Having said that, I believe the first mods to better M5 handling are camber plates, wider front tires (275 all around is best) and an adjustable rear sway bar. That will significantly reduce understeer and let you use more of the grip the car already has. AFTER that, I'd go the rest of the way with shocks, struts, front sway bar, and front and rear strut braces.
www.ebsart.com
2011 X3 35i, Alpine White with Nevada Chestnut interior and waveline wood trim
-Ceramic tint on all windows
-DVDinMotion DVD software unlock
-245/275 P Zeros f/r on 18x8.5/10 BBS RG-Rs
2007 Z4 M Coupe, Titanium Silver with Imola Red interior and silver trim
-for paint details: www.myartcar.com
-for mod details: www.mymcoupe.com
2003 M5, Imola Red with black interior and silver trim
-Dinan S2 drivetrain
-Dinan stage 3 suspension with JRZ shocks
-StopTech brakes
-Rogue Engineering short shift kit and clutch stop
-275/35R18 Michellins f/r on 18x9.5 BBS RS-GTs
-Progressive window tint
-Euro dash and armrest conversions
-CDT/Total audio, NavTv w/ DVD
-Seat massagers
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
