Check engine oil level... - BMW M5 Forum and M6 Forums
Old 3rd May 2006, 12:04   #1
openroad
Garage: M5 1999 Carbon Black
Bother....
I am miles away from a BMW dealer and need some 10w60 oil as this message came up when I switched the engine off this morning. Does anyone know if I can just substitute 10w30 this one time. Also, any ideas how much oil I will need to glug in to make this message go away? I have a whole refinerery of the 10w60 at home, just none with me.
Botherations
openroad is offline   Reply With Quote
Old 3rd May 2006, 12:36   #2
Pip
Garage: E39 M5 Carbon Black
It is 1 litre from top to bottom mark on the dipstick.
I think you can use alternatives in an emergency but I suggest same viscosity if possible.
Pip
Pip is offline   Reply With Quote
Old 3rd May 2006, 13:36   #3
sumo69
Garage: E39 M5 Silverstone
IMO... any decent oil as a top up is better than running a low oil level.
Low oil - engine goes bang, warranty denied.
Top up - worst case, do an oil change when you get home! If LL01 oil used, very unlikely to have any adverse effect.
Sumo69
sumo69 is offline   Reply With Quote
Old 3rd May 2006, 16:04   #4
bmwdctr
bmwdctr's Avatar
Garage: '01 M5 Titanium Silver w/black interiour
All synthetic oils are designed to be cross compatible We have roads out here (California, Arizona, New Mexico, and Texas) where you might not see a gas station for several hours at freeway speeds! It would be best not to make a habit of mixing oils, in a pinch you'll be fine. Happy motoring
Dave
2001
TitaniumSiver
-Air intake system
-Supersprint cat-back exhaust
-Pure white LED Angel eyes by Umnitza...that failed.
- Dice iPod integration
-Stage one Rainbow speaker upgrade
-10" Kicker SolarBaric sub driven by an Elemental Designs NINe.2 amp
bmwdctr is offline   Reply With Quote
Old 3rd May 2006, 16:23   #5
Need4Spd
Need4Spd's Avatar
Just be sure it's a synthetic, preferably meeting API spec. But if you are forced to use regular dinosaur oil, which I agree is preferable to not restoring the oil to the proper level, then do so and change it when you get home. Next time, I'm sure what you will do is carry a spare bottle in the trunk in one of those special BMW containers or a sturdy zip lock bag.
Need4Spd
'01 M5 (now my brother's car) UUC SSK + Rogue WSR/RE Tranny Mounts+Royal Purple Synchromax/Axxis ULT Pads/StopTech SS Lines/TC Design from BeastPower Anti-roll Bar Brackets/Dinan LtWtFlywheel and Stage 3 suspension/4xOEM rear 275 Goodyear F1 Asymmetrics/Vines thrust arms/IATS relocation/10w-60 oil/hardwired Escort 9500i/Euro Armrest/TEC Cupholder/IceLink/PowerChip 91 Gold/TUBIs!/Strong Strut/BSW Stage 1/BT/Angel iBrights 3.0/space-saver spare by Bimmerzone
'11 Jaguar XFR, Quicksilver exhaust, Escort 9500ci
Unnamed weekend Italian 2 seater with DCT
Future - F10 M5 with manual transmission?
Need4Spd is offline   Reply With Quote
Old 3rd May 2006, 19:01   #6
eljockvis
eljockvis's Avatar
Garage: e39 m5 avus blue
hi
just go to halfhords and get castrol synthetic 5w 30/40
it will be fine!
eljockvis is offline   Reply With Quote
Old 4th May 2006, 00:40   #7
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II 93 M5 3.8 Sterling Silber
Have you checked the oil level yet? My "check oil level" warning comes up when I am about half a litre low. It happened to me recently on a trip, i checked the level and continued on. Even if you're at the 'add a litre' mark, i think gentle driving for a little while would be fine.
That said, in the manual, they do state it is ok to add "a quality synthetic oil" of whatever the current rating is. If you pick up some mobil 1 15w50 at a local auto parts shop, you'll be fine.
mottati is offline   Reply With Quote
Old 4th May 2006, 00:49   #8
M5Don
M5Don's Avatar
Garage: E39 M5 Jet Black
BMW NA issued a SI regarding substitution oil for the 10w-60 S62s. They claimed that the BMW/Castrol 5w-30 synthetic can be used in conjunction with the recommended 10w-60. They did advise however, that mixing the 5w-30 will greatly shorten the usable life of the 10w-60 in the engine. So use the BMW 5w-30 or Castrol Syntec 5w30 (identical oil w/o infrared tracer) and change the oil when you get home.
-M5Don
http://www.UFMotorsport.com
mailto:don@ufmotorsport.com
M5Don is offline   Reply With Quote
Old 4th May 2006, 01:57   #9
M5 Dave
M5 Dave's Avatar
Garage: 2000 M5 Ti-Silver
Infared tracer? This is in 10w-60? Why, for checking oil leaks?
M5 Dave
2000 TiSilver M5 - Supersprint Headers, Tubi Catback Exhaust, Active Autowerke Tuned ECU, Active Autowerke CAI, Custom Hi-Flow Air Filtration, UUC 11" Performance Organic Clutch/Aluminum Flywheel, UUC Short Shifter, UUC DSSR, UUC Clutch Stop, UUC Tranny Mounts, Strong Strut Front Strut Bar, Riken Raptor Tires, AXXIS Deluxe Plus Brake Pads, UUC Shifter Knob, DEPO Projector39 HID DDE Clear Corner Headlights, Xtec HID Xenon Low beams, High Beams and Fogs (six ballasts), MK4-16:9-V28 Nav Upgrade, Bimmian Interior Xenox Lighting, V1 Radar Locater.
M5 Dave is offline   Reply With Quote
Old 4th May 2006, 03:19   #10
M5Don
M5Don's Avatar
Actually, the 10w-60 doesn't have it. But the BMW bottle 5w-30 does. For some reason, BMW wanted the ability to (if needed) see if the branded oil was being used in an engine. What I didn't understand about it was that it isn't even legal to deny a warranty claim based on a customer's use of an aftermarket consumable fluid in their car.
S85 V10 oil level service bulletin cobradav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 5 12th November 2006 18:10
A Better Way To Check The Engine Oil Level?!?! Anita E39 M5 and E52 Z8 Discussion 1 6th April 2005 00:26
Key Fob Issue - you too? MAH E39 M5 and E52 Z8 Discussion 15 11th February 2005 20:35
OT New Z06 rebel1 E39 M5 and E52 Z8 Discussion 86 12th January 2005 00:43
Press Release no 2: The new V10 engine in the BMW M5: A masterpiece in engine cons... Gustav E60 M5 and E61 M5 Touring Discussion 31 4th July 2004 21:23
