Old 22nd April 2006, 20:52   #1
KingM5
Banned
Garage: Modified Avus Blue E39 M5
DYNO sheets after installing performance parts?
Is finding a location an issue or cost?
Many will benefit from finding out that their car is missing horsepower, consuming too much fuel or at least know if their money spent on
modifications was worthwhile. No one is posting results?
http://www.dynojet.com/dyno_centers/...tive/index.php
KingM5 is offline
Old 22nd April 2006, 20:58   #2
Ahmed
Ahmed's Avatar
Garage: Ex- E39 M5
Maybe cause its a ***** getting the M5 to dyno right. Pulling fuses here and there! Not everyone knows that.
2006 Sepang Bronze/Naturelle Brown E60 M5
Eisenmann Sport Mufflers
Miesterchaft Sections 1 & 2
Evosport Headers
Evosport Pulley
RPi RAM Scoops + Block Off Plates + BMC Filters
AL-Tuning Software
Eibach ProKit Springs
20" Breyton Race CS with Yokos
White Angel Eyes, 6000K HID's & LED Plate Lamps
ACS Roof Spoiler
Ahmed is offline
Old 22nd April 2006, 23:51   #3
SC'dKellenersM5
SC'dKellenersM5's Avatar
Garage: Red White and Blue
generally because of the effort associated with finding dynos in the local area and operators that can be trusted. In addition, the fact that dynos as much as error should not be a factor is, and numbers are easily skewed.
Time associated with a non local dyno and for some people the cost associated as you need to spend anywhere from another 150-400 just to have before and after dyno numbers.
Im in the highspeed aluminum business
SC'dKellenersM5 is offline
Old 23rd April 2006, 00:09   #4
JEM
JEM's Avatar
Garage: Silverstone MY2000 E39 M5
I would note that mottati's full-boat Dinan setup was dynoed recently, he posted the results, and I'd bet they're about as far as you can reasonably go with a normally-aspirated S62 on 91-octane California pump gas.
JEM is offline
Old 23rd April 2006, 04:57   #5
ard
ard's Avatar
I'm a bit conflicted on this...
I'm a big fan of 'trust but verify"... UOAs, ISO5011 testing, etc... and a dyno seems a great way to cut through the marketing hyperbole.
But I've seen big variations in dyno numbers based on where a fan is placed on the engine bay, and other factors... getting a 'true number' and then replicating the test at a later date seem challenging. Plus the $200 a decent dyno should cost is better spent on....
Finally, once I've modded the car what does the dyno number do for ME? There are plenty of posts of people who add mods, dyno and post differential numbers far less than you would expect from the manufacturers' claims. Those posts help the reader, but not the guy who paid for the dyno.
A
ard is offline
Old 23rd April 2006, 05:19   #6
phillym5
Garage: 01 Area 51 M5 Le mans.
For me... trying to schedule some pulls, the "dyno guy" never calling me back, traveling to much, dyno is closed on random days, etc. We only have one dyno in west Michigan.....that I know of.
phillym5 is offline
Old 23rd April 2006, 08:09   #7
JEM
JEM's Avatar
a) Tests taken on the same dyno under similar weather conditions with the same fuel should produce results repeatable to within a couple percent (of course, at 350whp 2% is 7HP.)
b) Tests taken on different dynos under different conditions or with different fuel could be all over the place. Note that in some localities fuel formulations change seasonally. I'd swear in some cases they change because some bureaucrat wakes up with crab lice and wants to spread his misery around.
c) Because of airflow and temperature issues what you get on the road may vary from what you see on the dyno anyway.
JEM is offline
Old 23rd April 2006, 08:19   #8
KingM5
Banned
A
Excuses Excuses
A good dyno shop should not charge more than $85 for 3 runs (that is what 3 local dynos here charge)
Also if you stay with the same brand Dyno say Dynojet the variance in numbers is very small. Just make sure you have a large fan blowing sufficient air to replicate a driving environment.
The point you are forgetting is that when you Dyno your car the big area to focus on is not only your RWHP but the AIR/Fuel ratio which indicates if your car is running at optimum level. Wouldn't you agree that if you discovered from a dyno than your O2 sensors is causing your cause to run very rich your $85 would help produce say 20HP... DYNO's are a great "checkup" and tuning tool.
KingM5 is offline
Old 23rd April 2006, 08:25   #9
phillym5
Would there be any sort of difference between a dynos A/F reading verses having a wide band reading? I don't see how there would be... but just checking.
phillym5 is offline
Old 23rd April 2006, 08:27   #10
SC'dKellenersM5
josh
that wideband is going to be way more accurate than any tailpipe inserted A/F meter.
Where do you get your M5 performance parts nikon Owners Gallery 3 17th August 2002 05:19
BMW E65 7 performance parts? Corax Off Topic Forum 1 13th March 2002 02:30
BMW Performance Center 2002 Driving Schedule blue max E39 M5 and E52 Z8 Discussion 2 12th February 2002 00:51
Where do you buy your performance parts? racerX E39 M5 and E52 Z8 Discussion 9 26th July 2001 16:21
Break In period Joe Lapicki E39 M5 and E52 Z8 Discussion 21 29th March 2001 22:23
Page generated in 0.18303 seconds with 11 queries
