Old 18th April 2006, 15:29   #1
100%Cocoa
100%Cocoa's Avatar
Garage: E39 M5 Carbon Black/Caramel
Rear Parking Sensors gone mad!
I've searched loads on this but can find no previous reference.....
On Saturday I started the car in the morning, put it in reverse and the most god-awful noise came from behind me. It sounded like the parking beeper but was much higher pitched, louder and on constantly rather than beeping. I took it out of reverse and the noise stopped. The same thing happened 3 more times that day but has been fine since. At one point the beaper stopped all together (nearly took the front off a Hyundai - oops!) but did start working again shortly afterwards. The electrics in these cars are certainly quirky!
Has anyone else experienced this?!
100%Cocoa is offline
Old 18th April 2006, 16:00   #2
Ahmed
Ahmed's Avatar
Garage: Ex- E39 M5
My beeper doesnt work now. I only hear "clicks"
2006 Sepang Bronze/Naturelle Brown E60 M5
Eisenmann Sport Mufflers
Miesterchaft Sections 1 & 2
Evosport Headers
Evosport Pulley
RPi RAM Scoops + Block Off Plates + BMC Filters
AL-Tuning Software
Eibach ProKit Springs
20" Breyton Race CS with Yokos
White Angel Eyes, 6000K HID's & LED Plate Lamps
ACS Roof Spoiler
Ahmed is offline
Old 18th April 2006, 16:07   #3
Callero
Callero's Avatar
Garage: M5, Carbon black
Send a message via MSN to Callero
Has happened to me once, I just shut off the ignition and then it was fine again.
2002 ///M5 - Carbon black "sleeper"
  • No wing
  • No badge
  • "What happened? Wasn't that a 520??"
Callero is offline
Old 18th April 2006, 16:13   #4
SA-M5
Garage: check sign.
I have the same with the front PDC. Sometimes it gives me a continuous sound while nothing in front.
SA-M5 is offline
Old 18th April 2006, 18:09   #5
Anita
Anita's Avatar
Garage: 02 M5 TiSi
My back one's sometimes go nuts in the snow--I think the slush and stuff must have splashed up on them so when I put it in reverse, they think something is back there. I think I remember every rare once in a while the front or rears just beeping once or twice for no apparent reason also.
Maybe BMW needs to invent PDC sensor washers too
"When will I know that I really can't go
To the well once more time to decide on
When it's killing me, when will I really see
All that I need to look inside
Come to believe that I better not leave
Before I get my chance to ride" RHCP "Snow"
Anita is offline
Old 19th April 2006, 01:50   #6
Laidback
Garage: Camaro lol:)
Sales Feedback: (25)
the very same thing happens to my sensors too...whats causing it?
Laidback is offline
Old 20th April 2006, 16:41   #7
Anita
Anita's Avatar
Garage: 02 M5 TiSi
I wish I knew LOL I'll have to add that question to my "trivia for my SA list".
I forgot to add that my front sensors will sound when I exit a parking lot of something with steep pavement after I've just backed up- the front of the car is that close to the pavement because of the sharp angle.
Of course yesterday, the front sensor did one spontanious beep just to torture me
Anita is offline
Old 9th May 2006, 20:18   #8
Anita
Anita's Avatar
Garage: 02 M5 TiSi
OK I finally asked my SA about this last week and I hope I'm remembering it right
What he said is most likely there is something on the lens, a bug or bit of dirt for example, that might not even be that visisble, and that you should clean the lens with glass cleaner and that usually helps. He said when they do fail then tend to do so in a more dramatic way, like continuous beeping.
Hope this helps! Now get out there and clean those poor things!
Anita is offline
Old 12th May 2006, 22:46   #9
jajo
jajo's Avatar
Garage: BMW M5
Send a message via AIM to jajo
I just had my car in for an alignment, and brought up the PDC on my car. Mine doesn't work anymore. They quoted me about $400 to replace two sensors.
2002 M5...and after 6 years, I STILL can't get enough of it
jajo is offline
Old 12th May 2006, 23:35   #10
R748
R748's Avatar
Garage: 2001 M5
Wow, you've got to be kidding! The sensors are around US$70 each from Crevier BMW (online). This is an easy DIY job if one is comfortable removing the black trim that is around the bumper. It's just disconnect old sensor and reconnect new sensor, put back the trim. You may want to spend $1 or $2 and buy some extra trim clips in case any of them break (they are not very strong). Including shipping and tax, you should easily save yourself $200+.
Are you sure that both sensors are bad? It may be just one. Park the car in quiet place, turn key to ON, press PDC button. Then walk to each of the sensors, put your ears directly next to them. Working sensors will click noticeably. The bad ones will be silent. Replace only the silent ones.
R748 is offline
Adjusting handbrake imolaman E39 M5 and E52 Z8 Discussion 19 15th April 2007 22:45
BMW M6 Press Release no 5: Body, Design, Equipment: Light and Safe, Sporting and... Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 9 15th December 2004 22:25
Guys, whats a better lube/oil for the rear diff...... FAST 5 E39 M5 and E52 Z8 Discussion 5 7th August 2004 13:22
New option on E60 (from autospies). Gene E60 M5 and E61 M5 Touring Discussion 7 23rd January 2003 18:09
Page generated in 0.19487 seconds with 11 queries
