Originally Posted by KingM5
The front M5 KONI's have exactly 1 7/8 turn from full soft to full firm (675degrees) therefore I adjusted the fronts 506.25 degrees (1 7/16 turn) from full soft (3/4)
The rear M5 KONI's have exactly 2 5/8 turn from full soft to full firm (945degrees) therefore I adjusted the rears 472.5 degrees (1 5/16 turn) from full soft (1/2)
Please correct me if I'm wrong
You seem to have set the rear to 50% setting (halfway between full soft and full firm. From what I've seen, folks trying this setting invariably tear the shocks off a second time and soften them to somewhere between 1/2 to 1 turn from full soft. With the springs you have, anything over 1-1/4T from full soft will almost definitely be too stiff. If you could tell us the spring rate or coil specs, we'd know more. If you have a dial caliper, please tell me wire diameter, coil count and coil OD. We can compare them to H&R progressives for 540i and get a real good estimate for damper setting. The rear of the car is only 120# heavier than a 540i, about 1 skinny passenger or less than a tank of gas.
If the dampers are set too high with moderate rate progressive springs, you will discover that the car goes into an instantaneous oversteer condition under hard transient maneuvers. This makes the highly predictable E39 chassis feel more like like a solid axle Mustang in evasive meneuvers and rain conditions.....not good. The car will be unforgiving try to swap ends under racey conditions. It can get you in trouble if you have a couple beers or conditions are not optimal.
The setting you chose is higher than Ground Control or Dinan recommends & I found it to be way too stiff also. In this case, higher is NOT better for handling. I might try 1-3/8 Turn from full soft if I had 425lb/in GC-Eibach race setup...generally most other springs are lower rate and require less damping.
If you set the rears to 50%, your first test drive impression will be yikes. It will ride harder than a Z06 or M3. The extra damper rate will most definitely degrade handling, even on a dry track. I think you would need 500#/in rate springs to make those shocks move in a properly-controlled fashion, so tires follow the road surface and allow suspension movement instead of overpowering the springs & skipping along like a solid axle...
There are a few threads here and elsewhere about koni settings that have been posted by folks who learned the hard way. You might review them. The optimal shock settings for GC are lower than what you chose.
JMO.....
