Old 16th April 2006, 18:36   #1
eljockvis
eljockvis's Avatar
Garage: e39 m5 avus blue
gearbox oil change
hi
im looking to change my gearbox oil ,diff oil and brake fluid can someone
advise me on whats the best oils to buy ??
i got my diff oils seals changed about 1000 miles ago,will this mean the diff
will have new oil because of this??
eljockvis is offline
Old 16th April 2006, 19:06   #2
ard
ard's Avatar
I had my diff seals replaced- 31k for the input and right output seals, then at 49k they did the left output seal(duh! dealers...) all under warranty. They did NOT change the fluid.
I just changed it (I posted a UOA on the fluid removed) and used 'stock' BMW diff fluid. (Also used BMW MTF-LT-2 manual tranmission fluid for the gearbox.)
Lots of discussion on other non-BMW fluids you can try- given that I had no performance issues and the UOAs showed no abnormal wear, I feel OK with the BMW fluids.
A
ard is offline
Old 16th April 2006, 19:14   #3
RoundelM5
RoundelM5's Avatar
Garage: 2003 M5 - LeMans Blue
Sales Feedback: (8)
Mike Miller (Tech Editor for BMWCCA) seems to swear by Red Line oils for gearbox and diff
'03 Lemans Blue/Black
Dinan: Stage 3/Koni suspension, Stage 2 software, 3.45 differential, LTW wheels, LTW flywheel, strut bar
Stoptech 4-wheel BBK
AA CAI and brake ducts
Tubi Regular exhaust
Rogue Engineering SSK w/ WSR
AngeliBright v2.0 w/ matching fogs and highbeams
TC Design Rear Swaybar Brackets
BMW Bluetooth, Sirius, First Aid Kit
RoundelM5 is offline
Old 16th April 2006, 22:05   #4
eljockvis
eljockvis's Avatar
ok gents thanks for the info,i was hopeing they would have to drain down the diff to change the seals!
so how much oil is required for the gearbox and diff??
one other question i got a new engine fitted under warranty a bout 12,000 miles ago would the mafs have been changed do yous think? the car had 68.000 on the clock at the engine time of change??
Old 16th April 2006, 22:48   #5
mfizzlenyc
mfizzlenyc's Avatar
Garage: 2000 m5 silverstone
thats funny my motor was changed at 68000 as well
2000 Silverstone M5 extended Leather
BBS LMs 19s ,StopTech BBK,Dinan Headers Dinan CF -CAI,Dinan light weight flywheel,Dinan stage 3 suspension, Dinan stage 4 software ,Dinan 3.45 Diff,Dinan Mufflers,SS race cats ,SS x pipe,Rogue SSK , Euro Headlights -ibright v3,MRTM Pedal set, updated steering wheel ,16:9 nav ,Active Auto brake ducts
2009 135 Space gray Black Boston Extended Leather
mods- Bmw Performance Black kidney grills,
1988 10th anniversary Rx7 turbo-mods... 93 rotors 3mm seals streetported lapped and balanced 6 puck non organic clutch Turbo back exhaust blah blah blah
1972 Corvette Stingray 454 4 speed man. Show car condition -FOR SALE
mfizzlenyc is offline
Old 17th April 2006, 00:41   #6
bmwdctr
bmwdctr's Avatar
Garage: '01 M5 Titanium Silver w/black interiour
Gear box and differential will take about 4-5 qts total, not each. The OEM MTF-LT fluid is fine as ARD pointed out, but much more expensive than Redline which is as good as, or better, than original.
The MAFS would be itemized on your bill if they replaced them.
-D
Dave
2001
TitaniumSiver
-Air intake system
-Supersprint cat-back exhaust
-Pure white LED Angel eyes by Umnitza...that failed.
- Dice iPod integration
-Stage one Rainbow speaker upgrade
-10" Kicker SolarBaric sub driven by an Elemental Designs NINe.2 amp
bmwdctr is offline
Old 17th April 2006, 01:54   #7
ard
ard's Avatar
Tranny took around 2.5L at US$30 per.
Diff took around 3 pints or so, around $7 per
They are vastly different fluids...
whats the best tranny fluid?
Adam
PS I'd be surprised if they replaced the MAFs...unless they had failed
ard is offline
Old 17th April 2006, 06:01   #8
Beamer_usa
Beamer_usa's Avatar
Garage: explosive ford pinto
Many fluids to chose from but I would stick with OE IMO
Informative thread:
How much transmission fluid?
Dinan Cans
Dinan Software
Beamer_usa is offline
Old 19th April 2006, 11:26   #9
DavidS
DavidS's Avatar
Garage: 2000 M5 LeMans blue
Sales Feedback: (4)
Would you like to post some details in:
Engine Failures
Thanks,
David
DavidS is offline
Old 19th April 2006, 11:28   #10
DavidS
DavidS's Avatar
Sales Feedback: (4)
I have replaced those fluids:
Gearbox: Royal Purple Syncromax - made a huge improvment of cold weather shift qulity
Differential: new BMW OEM fluid
Brakes: new BMW OEM brake fluid
David
http://www.m5board.com/vbulletin/showthread.php?t=54788
http://www.m5board.com/vbulletin/showthread.php?t=88323
DavidS is offline
DIY Dummies Guides to Oil Change using Fluid Extractor HDClown E39 M5 and E52 Z8 Discussion 0 18th September 2005 01:46
Press Release no 2: The new V10 engine in the BMW M5: A masterpiece in engine cons... Gustav Most Memorable Threads' 31 4th July 2004 22:23
Anyone ever loose oil pressure from an oil change? madyspop E39 M5 and E52 Z8 Discussion 9 22nd April 2004 10:46
Gearbox oil change - Mobil 1 Urban Myth ?? IvanDias E34 M5 Discussion 8 25th April 2002 23:54
Page generated in 0.15553 seconds with 11 queries
