Old 16th April 2006, 07:16   #1
DavidsM5
DavidsM5's Avatar
Garage: 2000 M5, Ti-Silver
Radio/amp stopped working.....
The radio and CD on my beast suddenly was intermittent yesterday and finally stopped working today.
The DSP option on the menu page is not even shown.
The radio functions still seen to work, I can change channels and such but there is no sound.
I suspect that the DSP amp is gone.
Anyone experience this issue?
Is it time for a nice aftermarket amp?
David
DavidsM5 is offline
Old 16th April 2006, 08:26   #2
TQ2K
TQ2K's Avatar
Garage: 2003 BMW M5 - Petrol Mica/Champagne
Sales Feedback: (6)
Send a message via MSN to TQ2K Send a message via Yahoo to TQ2K
Experienced the same issue and dealer found fault codes in the radio module so they've reset it. Since then no more issues.
TQ2K - |
'03 BMW M5 - Individual Petrol Mica/Champagne
- UUC Evo III SSK, DSSR, & Clutch Stop
- OEM Bluetooth + Snap-in Adapter | OEM Backup Camera
- SS Headers, X-Pipe, Exhaust | Dinan CAI + HFM + IATS
- Dinan S2 (Koni) & Rear Strut Brace | Strong Strut Brace
- Brake Ducts | 19" BBS CH Wheels | TCD Brackets
- Custom PC Gold 93v3 | Dinan Lightened Dual-Mass Flywheel
- Voltphreaks VPH 900 (7lbs. Lightweight Race Battery)
'04 BMW X5 4.4i - Alpine White/Truffle
TQ2K is offline
Old 17th April 2006, 06:38   #3
CWY_M5
CWY_M5's Avatar
Garage: '00 M5 Silver; '91 M5 white; '01 525iT white; '94 525ia Black
Here's the fix - DSP Amp and fuse in the "FM module?"
I'm an expert with this issue, since it has happened a few times now.
If your radio light still turns on, and you can switch chanels, CD tracks, etc, but just no sound, do the following:
1. Rear left corner, unplug EVERYTHING on the DSP, and wait over night. Some say this fixes it, althought this has never fixed it for me.
2. My sure way of fixing this is to remove all DSP connectors (3 of them), and another smaller unit (I believe it's called FM Module) sitting right to the rear of the DSP unit. It should have 3 connections: 1. co-ax, 1. optial, and another square - difficult to remove connector. With this square connector removed, there will be a fuse in ther - 7.5amp I believe - unplug this, and if not tripped, plug back in, everything should work now.
If your Nav / Radio light doesn't work, then you may have a Nav computer problem, or just a "conflict" with your other additional units - in my case, bluetooth retrofit from EIS.
Hope you fixes it.
Chino
CWY_M5 is offline
Old 17th April 2006, 06:45   #4
DavidsM5
DavidsM5's Avatar
Hope you fixes it.
Chino
Thanks Chino.
I'll try this now.
Update!
Did the above but still not working....
I'll leave it unplugged till the morning.
Hopefully it will cure itself but I'm not holding my breath.
It's a good excuse for an amp upgrade anyways!
David
DavidsM5 is offline
Old 17th April 2006, 11:40   #5
dave_gt
dave_gt's Avatar
Garage: E39 M5 Le Mans Blue
I hope it all works this morning mate.
If you do decide to go down the route of upgrading the stereo there are gigantic benefits that can be had over the stock set up while still keeping the standard head unit. Unfortunately there is a 'but.' As far as I know, the DSP amplifier that you have uses digital signals as inputs (not 100% sure cos I don't have DSP) and this means that they can't be used as a line signal into an aftermarket amplifier.
This would be an issue that I wouldn't recommend trusting to your local car-audio shop unless they really do know their BMWs but board sponsor Bavarian Soundwerks may be able to help you out.
Alpine have just released their vehicle hub which is designed to be used to integrate amplifiers, games consoles, reversing camera etc into factory head units. I'm thinking of getting one for mine so I can add bits & clean up the factory signal a bit. http://www.alpine-electronics.co.uk/...ith-Alpine.htm
2001 M5, Lemans Blue / Silverstone
Standard except for a few bits & stereo:
6.5" Focal components, 10" Directed sub, IceLink, JL Audio & Directed amps (hidden). Predator ICE, Stealth bulbs, V1, Roadpilot
1990 Mazda MX-5 (brilliant) 1998 Nissan Primera GT (modded)
dave_gt is offline
Old 17th April 2006, 17:17   #6
KBK
KBK's Avatar
Garage: E39/Anthracite Metallic
The front end of the car...dash display..is a 'digital controller' ONLY.
a digital control signal is ent back to the rest of the system. It IS possbile to make a 'black box' to 'fit' after that front end box..and run the dash display..on a real audio system. But that's quite a large bit of work.
After all the stealth box guys have done exactly that, for the valentine radar detectors. They made a box that translates the digital signals from the valentine and inserts them into the BMW hardware/software system.
So it can be done. The work is slightly different, but not that different.
KBK is offline
Old 17th April 2006, 17:48   #7
DavidsM5
DavidsM5's Avatar
Update:
All plugged back and still not working....
Off to the dealer I go.
DavidsM5 is offline
Old 17th April 2006, 18:27   #8
KBK
KBK's Avatar
If you have customized the system with this 'bluetooth' stuff, or any other such electrical/digital signal/'interruptive' cabling, it is likely that these cables and connections are at fault.
Re-connect to original spec. If it is not good then (with proper re-connecting to original!)..then there is a fault with the DSP gear/DSP box. Could still be cabling, though.
The front box (dash display) sends a pure digital control signal to the rear DSP box. If that signal pathway is degraded, it is possible to get non-operational kinds of faults. The radio still works as it is in the front box, and sends an analog singal to the rear DSP box, oddly enough. The DSP won't work, though, as it is not getting correct transfer of it's digital control signals. The electrical signal pathway for the DSP box, from the front..is very much like the single digital cable that runs from your DVD player to your surround processor in your video system at home. Different format and function, but basically the same.
Once gain, if there is custom wiring, to interrupt the digital signal from the front box to the DSP control box..this is the likely cuprit.
KBK is offline
Old 17th April 2006, 18:46   #9
ehssan_alkhiyami
ehssan_alkhiyami's Avatar
Garage: BMW M5 E60
Send a message via MSN to ehssan_alkhiyami Send a message via Yahoo to ehssan_alkhiyami
David , Don't waste your time buddy , the Amps if gone ,,belive me cuz I had it before on my 540 .. and even WilM5AD had the same problem ,,, and we both replaced it with another one ,, but we bought a second hand ..
available on ebay I belive ... good luck bro .
E.K
ehssan_alkhiyami is offline
Old 17th April 2006, 19:06   #10
KBK
KBK's Avatar
If you need a new amp box, David, I've got a line on a few. Let me know. I just turned one down for $150US. I'm not that sure about that source...but I have about 20 other places I can buy the box, that are reputable.
KBK is offline
Troubleshooting stopped wipers? M5Joe E39 M5 and E52 Z8 Discussion 11 19th April 2008 03:08
Pacific BMW stopped selling parts online? LeatherMan E39 M5 and E52 Z8 Discussion 10 9th March 2006 03:15
Aircon stopped help ! Carrera2RS E39 M5 and E52 Z8 Discussion 5 8th July 2005 10:30
Electric Head Rest, stopped working. (help) plisken E34 M5 Discussion 24 31st May 2005 10:45
I stopped burning oil! dave E39 M5 and E52 Z8 Discussion 6 19th July 2001 02:40
Page generated in 0.15559 seconds with 11 queries
