• Latest threads
    • Custom feed
      • Updates
        Old 13th April 2006, 21:09   #1 (permalink)
        sycosho
        sycosho's Avatar
        Wheels for my M5.. Not Happy!
        These are the wheels that my friend Ev suggested and they finally came... AFTER 5 months!
        They look ok, BUT I ordered matted black and i got glossy. So pissed!
        Now I have to wait until this problem is resloved before I can put in on the car .
        On the good side, the front lip measured about 3 inches and the rear was over 5. The front wheels will clear the 355mm Stoptechs with much space but the rear is limited to the 345mm. They are very light!
        They are:
        19X9 +18
        19X10.5 +10
        sycosho is offline
        Old 13th April 2006, 21:21   #2 (permalink)
        Beamer_usa
        Beamer_usa's Avatar
        NICE! Wheels, sorry to hear you got the wrong finish! That sucks!
        2000 Silvr(354)/Blk(M1SW)
        Dinan Cans
        PC 93
        Beamer_usa is offline
        Old 13th April 2006, 21:35   #3 (permalink)
        Lscman
        The outer lip of this wheel is going to be pushed 33mm outward, compared to stock. Do you have that much clearance or are you planning to install a 4WD lift kit? From what I've seen, some stock M5's rub.
        Lscman is offline
        Old 13th April 2006, 21:55   #4 (permalink)
        vabchbmw
        vabchbmw's Avatar
        Wrong rims
        That was pretty nice of the manufacture to ship your rims with spending cash included.
        Thanks,
        Chris
        2001 M5 - Titanium Silver, Silverstone Sport Interior
        3-1/63 Navigation Software upgraded w/v26 disk
        1992 Nissan Maxima - 255,681 - RIP
        vabchbmw is offline
        Old 13th April 2006, 22:27   #5 (permalink)
        TiSiBeast
        TiSiBeast's Avatar
        Nice wheels - pretty bling bling pics with the fiddy sitting there.
        Current Toys: 2000 M5 with lots of goodies, 1997 993 Targa mostly stock, 2002 Jeep GC all set for offroad, 2004 Acura TL bone stock
        TiSiBeast is offline
        Old 14th April 2006, 00:49   #6 (permalink)
        sycosho
        sycosho's Avatar
        I guess we'll fine out when they "try" to put it on.
        The only clean bill I had was a fifty. Didn't want a raggady bill on a clean rim.
        sycosho is offline
        Old 14th April 2006, 00:55   #7 (permalink)
        TiSiBeast
        TiSiBeast's Avatar
        Nice call.
        Old 14th April 2006, 01:23   #8 (permalink)
        JEM
        JEM's Avatar
        They are:
        19X9 +18
        19X10.5 +10
        Stock rear offset is +22, my rear 18x9.5 Kinesis K28s were inadvertently made with +19 and with the 3mm-thicker-than-stock Stoptech rear hats I get occasional minor rubbing with stock-size 275/35 rears, so either you've got a typo there or your rear wheel fit is hopeless.
        The rears go back to Kinesis when I wear out my rear tires, they're going to take 4mm off the hub mating flange which should get me enough clearance as long as I don't ever intend to run 285/35 rears.
        JEM is offline
        Old 14th April 2006, 18:09   #9 (permalink)
        SoCalJD
        SoCalJD's Avatar
        Although I prefer the stock wheels, and probably will never change them, if I *did* I'd probably get *those*. They are some sweet looking wheels! (even if you don't like them)
        SoCalJD is offline
        Old 14th April 2006, 20:04   #10 (permalink)
        M Macht
        M Macht's Avatar
        I like the gloss black actually. They look good.
        Nick
        2001 E39 ///M5: Imola Red/Caramel/Walnut
        PowerChip Gold 91
        9.5x18 inch OE Rims On All Four Corners
        275/35 Michelin PS2's
        Brake Ducts and M Technik Splitter
        UUC EVO3 Short Shifter and Double Shear Selector Rod
        Rogue Transmission Mounts
        BeastPower Sway Bar Brackets
        Valentine One and Stealth One
        Titanium Pedals
        Angel iBright V3.0
        Sylvania Silverstar High Beams and Fog Lamps
        Platinumvision 2.0 Bulbs
        Tinted Windows
        "Spare" 8x18 inch OEM Rim and Tire With Jack and All Trunk Lid Tools
        M5 Trunk Mat
        Trunk Storage Bin
        M License Plate Bracket
        Too much horsepower is never enough.
        M Macht is offline
        Old 14th April 2006, 20:15   #11 (permalink)
        cableguy
        cableguy's Avatar
        Me too , why not ask for some serious discount and keep the gloss black.
        C.
        2003 996 GT2 - Brutal...
        cableguy is offline
        Old 14th April 2006, 20:36   #12 (permalink)
        sycosho
        sycosho's Avatar
        I don't have the stoptech's yet, so i might have to look into that.
        Well, it was close as hell but luck was definitely on my side.
        Fronts: 19X9 +18 with Toyo T1-R 265/30/19
        The only issue here was that the wheels were hitting the PSS9's. After a block's worth of shaving off some metal from the inside wheel, we had to raise up the car about 1/8th inch (only on the driverside - no, I'm not that heavy, the height was not even from left to right) so the wheels would clear the perches.
        Rears: 19X10.5 +10 with Toyo T1-R 285/30/19
        Keep in mind that my car was already lowered. After the wheels were on, it didn't look like it was going to clear the fenders. They were sticking out a lot. I brought the car down ever so gently and the rear tread just tucked in nicely into the fenders.
        BUT here's what we realized, the previous owner of my car had already rolled the rear fenders. So I got very lucky! A minor rub only on the freeways. Nothing a little camber shouldn't take care of.
        The car's at the alignment shop now, so I'll post pictures after it come out.
