Old 30th March 2006, 17:57   #1
Shawn M5
Shawn M5's Avatar
Garage: M5
Send a message via MSN to Shawn M5 Send a message via Skype™ to Shawn M5
Stop-tech advice/help
Looking at the stoptech big brake kit with 4 pistons front AND back, problem is im gonna be running on stock wheels for a while and from what i can tell they dont fit with stock wheels? they fit the front but not the rear? why is this? is it just the rear caliper wont clear the wheels at the back so i just need some spacers and the rear caliper will fit??
Help or advice would be great on this matter.
Thank you in advance...
Shawn M5 is offline
Old 30th March 2006, 18:56   #2
JEM
JEM's Avatar
Garage: Silverstone MY2000 E39 M5
Except there's no room for spacers in back, the tire will hit the fender.
Simple answer: if you want to use stock wheels, you don't use that kit. If you want to use that kit, you buy new wheels.
JEM is offline
Old 30th March 2006, 18:58   #3
ard
ard's Avatar
Check out zeckhausen racing, a board sponsor (link is at the top of each page)... pretty complete list of compatibility of each brake kit with each model and each wheel size. Plus you can call or write Dave Zechausen and ask him to confirm the fitment once you understand what you want.
As I understand it, it isn't just rotor diameter that defines fit, otherwise you should be able to fit the same front and rear- the offset in the rear is different, so where the caliper sits under the volume defined by the rim and spokes is different for the rear- hence the need to push the rim out and away from the rotor to gain more room. (Which creates rub issues on the outside/fender.)
A
ard is offline
Old 30th March 2006, 19:16   #4
DZeckhausen
DZeckhausen's Avatar
Garage: 2001 540i 6-Speed, Alpine White
Send a message via AIM to DZeckhausen
Shawn,
If you want a 4-wheel kit that will work with the stock wheels (no spacers), you should order the following StopTech kit: 83-135-472G. That will get you a 355x32mm front kit with 4-piston calipers and a 345x28mm rear kit with 2-piston calipers.
There are no spacers that will make the 4-piston 355x32mm rear kit work with stock wheels. The 4-piston caliper interferes with the inside of the wheel, where it narrows toward the outside face. Any spacer thick enough to make the wheel clear, will also cause severe fender rub.
See: http://www.zeckhausen.com/BMW/E39_M5.htm for a complete list of all the brake options you have for the M5.
Dave Zeckhausen
Owner, Zeckhausen Racing
2001 540i 6-Speed
M5 Front Swaybar
Dinan Stage 3 Suspension
Dinan Front Strut Tower Brace
European Dash Conversion
CDV Deleted (of course!)
Bluetooth, NAV-TV, DVD Player
2006 Chrysler 300C SRT8 w/StopTech ST-60 front/ST-40 rear BBK
2007 Corvette Z51 Coupe 6-Speed w/StopTech Trophy ST-60 front/ST-40 rear
2009 Honda Fit Sport w/NAV w/Acura Integra front calipers, StopTech floating rotors on order
DZeckhausen is offline
Old 30th March 2006, 21:30   #5
BRN64666
BRN64666's Avatar
Garage: BMW M5 E39
I have 355x32mm all arround, you need 10mm spacers in back, and problem is solved
BRN64666 is offline
Old 30th March 2006, 21:46   #6
BRN64666
BRN64666's Avatar
Garage: BMW M5 E39
Originally Posted by DZeckhausen
Shawn,
You are absolute right, What I did is I have re-shaped the caliper ( shave the caliper a bit ) then I have painted it and install 10mm spacers in a back just to fit the stock wheels… I have no problem and it works fine with me ….
BRN64666 is offline
Old 30th March 2006, 22:22   #7
DZeckhausen
How did you manage to get a 10mm hubcentric spacer to work on the rear hub? The lip on the rear hub is 1.5mm taller than the lip on the front hub, thus preventing a 10mm hubcentric spacer from laying flat. Does your spacer look like this?
Or does it simply have an opening with no raised lip at all? If it has the lip, then it must be a 12mm spacer, not a 10mm spacer. If it does not have a lip, then your rear wheels are being centered by the wheel bolts and not by the hub lip or the spacer lip.
No fender rub problems with four adults in the car?
Dave Zeckhausen
2001 540i 6-Speed
M5 Front Swaybar
Old 30th March 2006, 22:29   #8
BRN64666
BRN64666's Avatar
Garage: BMW M5 E39
I got my spacers from beastpower and I believe they are H&Rs, I dont remeber if it has the lip but I will post a pic of those spacers as long im running on 19s.... I have no problem with fenders and it doesnt hit the fenders ....
BRN64666 is offline
How good are stop tech brakes for track use ? Black M5 E39 M5 and E52 Z8 Discussion 21 22nd December 2004 20:02
Stop Tech or Brembo for the M5? Lupo///M5 E39 M5 and E52 Z8 Discussion 47 27th April 2003 11:06
Help! Stop Tech Big Brakes: Rattling noises normal? Cerberus E39 M5 and E52 Z8 Discussion 9 8th July 2002 16:59
Stop tech pics. Rave E55 E39 M5 and E52 Z8 Discussion 7 26th March 2002 22:49
Stop tech Big brakes or Brembo. Rave E55 E39 M5 and E52 Z8 Discussion 0 15th January 2002 04:32
Page generated in 0.15621 seconds with 11 queries
