Old 29th March 2006, 21:26   #1
cosioboy
cosioboy's Avatar
Garage: 2000 M5 Carbon Black
My leather treatment clinic
Guys, after speaking to one of the best folks in the business, I went through a fairly extensive leather care exercise and I wanted to share my experience. To begin with, I want to give credit to Larry Reynolds, owner of Car Care Online (http://www.carcareonline.com/). He's a very knowledgeable and nice guy, and a true car aficionado – he’s about to replace his 996 911 GT2 (which has something like 70K of all track miles!) with a brand new 997 911 GT2 (or 3 perhaps). So I followed his advice on taking care of my leather interior. Keep in mind I have the full/extended leather option (dash, full doors, etc.) so it is a lot more detailed than for folks with the Sport/2-tone option. And considering that the leather has seen some sun over the years, it was in need for a full 'day spa' treatment.
So here is what he recommended I do, and I followed to the t. It is fairly involved, but half of the procedure I am about to outline below is more of a one-time job and the regular maintenance is far less manually intensive, so don’t freak out:
Step 1: You need to thoroughly clean the leather to essentially 'open' up the pores. Imagine a human body - you need to give it some good scrubbing and let the leather 'breath' before you apply the various treatments and conditioners. The pores have been clogged from dust, grime, and of course human contact. So first step is to use the Lexol pH Leather Cleaner: http://www.carcareonline.com/detail.asp?product_id=10701
You simply use a kitchen sponge which you dampen beforehand so it doesn't absorb the cleaner itself. As you vigorously scrub the leather, it will form a soapy-looking foam, but don't worry, it goes away easily. With this and the other products listed below, there is no such thing as applying too much. The leather will absorb everything it can and anything it doesn't soak up anymore, you can simply wipe off. You will notice a totally new shine in your leather, but wait, that is nothing compared to what follows…
Step 2: Next step is to apply this honey-looking substance, which is essentially a leather enricher and softener (think of it as leather food). It is called (not misspelled) Surflex Leather "Soffener" http://www.carcareonline.com/detail.asp?product_id=11951
The application is a bit tricky, I found best to use a cotton glass cleaning cloth and literally swirl it around my index finger and apply it that way. This is the messiest part of the entire exercise, as this thing really looks like honey and will mess up the plastic surrounding trim/windows/paneling, so be patient. This is not the time to worry too much about messing up your plastic trim, it comes off easily (I used an ammonia-free glass cleaner in a spray bottle in the last step outlined below to do all the cleaning up, but arguably you can use the Lexol Leather pH cleaner as per above.). Just careful not to apply any of it to the alcantara, they don't go well together at all, trust me on this one ;-o))
Now here is an important point, maybe a bit anal, but works especially well for all the spots that have been heavily hit by the sun (e.g. dashboard, top of door panels - something that the no-cost option equipped two-tone/sports interior M5s don’t need to worry about). After you apply the 'honey' softener, it is best you cover the freshly applied area with a saran wrap. You essentially want to keep away any evaporation of the softener. So apply it, cover it, and let it soak/suffocate (under sun preferably) for a few days. You may want to do the rear headrests and top of the rear bench seat like that too as they get the most punishment from the sun rays. After you are done with this, your leather will be softer than your living room La-Z-Boy chair This entire step to me is a one time thing (or say one time a year), after you have 'fed' your leather, steps 3 and 4 is all you need as regular maintenance.
Step 3: After you’ve let it stay for a couple or more days, you will notice that some areas have absorbed the 'honey' softener more than others. Don't worry about seeing these spots, perfectly normal, after all, we are talking about natural leather here that has varying absorption characteristics, especially after the dyeing process. Take the same ammonia-free cleaner as mentioned above but use a little of it, all you need is to quickly wipe off the entire surface area, don't scrub it in as you don't want it to eat in the leather softener, a simple one stroke application will do the trick. This will eliminate the 'spots' and ensure the leather is uniform all around. Next comes the Lexol Neatsfoot Formula Restorer http://www.carcareonline.com/detail.asp?product_id=10715.
There are various ways to apply it, I continued to use a dampened kitchen sponge (a new one though, not the one you applied the leather cleaner with). This step is much faster than step 2. Once done, I would let it sit for another couple of days.
Step 4: Final step is the leather conditioner, specifically the Lexol Leather Conditioner: http://www.carcareonline.com/detail.asp?product_id=10706. You can use this year round, and perhaps repeat step 3 every so often should you feel the leather is drying up/getting a bit dull.
I should have taken pictures before and after, but got carried away. Trust me, the difference is dramatic! I even took the headrests home and especially under light, it is amazing. To the eye, and to the touch! You won't regret it. Just make sure you take your time, for one to let the leather treatments sink it, and two, perhaps most importantly, not to get the gentler sex completely mad at you for devoting time away from her! If this were to happen, you can easily make reference to the certainly-more-than-4 leather treatments she stores behind the bathroom mirror (and likely her anti-wrinkle cream is more expensive than all of the above combined!)
cosioboy is offline
Old 29th March 2006, 21:47   #2
imolaman
imolaman's Avatar
Garage: 2001 BMW M5 Imola Red
Send a message via MSN to imolaman
Cosio,
Thanks for a very informative thread there! It's a pity you did not do the before/after picture session, but judging by your comments it must look good!
I myself firmly believe in taking good care of leather seats. I have been using the BMW leather care range available here and the results are good. It certainly helps in maintaining the "new look" interior!
Best regards,
Rudi
2001 Imola Red II E39 M5 - Stock
imolaman is offline
Old 29th March 2006, 22:03   #3
TiSiBeast
TiSiBeast's Avatar
Garage: 2000 E39 M5 TiSi, 2002 Jeep GC Gray
Awesome post Cosio! Can you post any pics of the leather today? Also, does it bring back that "new car smell?"
Current Toys: 2000 M5 with lots of goodies, 1997 993 Targa mostly stock, 2002 Jeep GC all set for offroad, 2004 Acura TL bone stock
TiSiBeast is offline
Old 29th March 2006, 22:27   #4
Beamer_usa
Beamer_usa's Avatar
Garage: explosive ford pinto
Great info. Thx for the post!
Dinan Cans
Dinan Software
Beamer_usa is offline
Old 30th March 2006, 00:57   #5
emccallum
emccallum's Avatar
Garage: 2001 m5, 2003 525it
Nice write up. That sounds very similar to the Leatherique ( www.leatherique.com )system I used to bring back my 88 m5 leather. To get good results it takes a lot of time and patience.
emccallum is offline
Old 30th March 2006, 02:06   #6
cosioboy
cosioboy's Avatar
Thanks, guys. I figured since I am going through all this effort, might as well document it for future reference.
I will try to make some pics of the conditioned leather over the weekend, although I am a idiot for not doing a before and after comparo...
PS
Actually, come to think of it, I have an untreated leather panel at home, which at some point I will replace with my current one in the car that has a nick, so I can compare those alongside of eachother.
cosioboy is offline
Old 30th March 2006, 03:34   #7
HJB1988M5
Garage: 1988 M5 Black/Tan
Leather dash care
I have used the softener product on my 88 m5 and recently on my 20002 m5. I was concerned about the dash due to problems I had on an 87 M6 with leather dash. I have been told to use 303 protectant. I have used this on boats in the past with good success. Does anyone have experience with 303 on a leather dash. Thank you
HJB1988M5 is offline
Old 30th March 2006, 04:54   #8
bmwdctr
bmwdctr's Avatar
Garage: '01 M5 Titanium Silver w/black interiour
Great post, very informative. However, I would be interested to see how the leather looks/feels after some time. I have the full leather package in my beast as well. My Benzo didn't like leather treatment too well and in fact it looked worse after a few days. Granted, I didn't use Lexol products but now I'm a paranoid freak as a result.
-D
Dave
2001
TitaniumSiver
-Air intake system
-Supersprint cat-back exhaust
-Pure white LED Angel eyes by Umnitza...that failed.
- Dice iPod integration
-Stage one Rainbow speaker upgrade
-10" Kicker SolarBaric sub driven by an Elemental Designs NINe.2 amp
bmwdctr is offline
Old 31st March 2006, 18:54   #9
cosioboy
cosioboy's Avatar
Before and after pics
Due to popular demand, here are a few before-and-after pics.
Since I didn't take any pictures of the interior before and after (something I regret), I took out one of the treated headrests and compared it to an untreated leather panel I have sitting at home waiting to be installed in the place of my nicked one.
I will make some pics this weekend of the car itself under daylight, these are at night under artificial light, but enough to see the huge difference. I think the flash made it seem much shinier than it is in actuality (trust me, it doesn't look like you applied a cheap can of armorall), and it is not greasy to the touch.
cosioboy is offline
Old 31st March 2006, 20:01   #10
aw/ir02smg
aw/ir02smg's Avatar
Garage: m5 touring wannabe :)
hey cosioboy,
thanks for this post. i am needing to do something like this. hope to get the results u got. jack
aw/ir02smg is offline
M5 E39 Body Style S62 engine FACTS...Long V-10 4 Me E39 M5 and E52 Z8 Discussion 53 22nd March 2009 16:12
Perf Prep (leather seat treatment) WLightning E60 M5 and E61 M5 Touring Discussion 5 20th November 2005 19:12
Leather trim revisited WannaM5 E39 M5 and E52 Z8 Discussion 10 5th November 2005 22:52
Cleaned and conditioned leather Pete E39 M5 and E52 Z8 Discussion 5 6th October 2004 10:37
Dashboard Silverstreak E39 M5 and E52 Z8 Discussion 40 5th January 2002 03:08
Page generated in 0.20648 seconds with 12 queries
