This is normal...
An LED had different characteristics when compared to an incandescent bulb.
Because of the way the LCM (lighting control module) monitors the bulbs status, an LED, (or aftermarket HID fog light kit for example) will make the LCM "think" the bulb in that particular socket is bad.
There is a work around if you were to do HID fogs, but it’s not realistic for something like a side marker light.
Have you considered PIAA hyper white bulbs?
If its the brilliant color you're looking for, the PIAA lights will come close, but if you're after the 'snap' of LED then you might be out of luck, unless you dont mind living with the fault message.
-Audio
2006 M6 Indianapolis Red / Sepang Bronze
2004 SL55 Brilliant Silver / Berry Red
2000 M5 Carbon Black / Silverstone (Retired)
- Iforged Aeros
- Stoptech Reds
- BB Tri-flo
- 6000K
- Rogue SSK
