Not sure how the DINAN components will alter the alignment specs, but here are the factory desgnated specs for our E39 M5s.
PIC1 is a list of conditions that must be met before a proper alignment is carried out.
PIC2 is the actual alignment specs for the E39 M5
PIC3 is the breakdown of the screen on the BMW alignment machine. (In case they let you watch the process and you want to double check their work
I would assume that regardless of how you wish to modify the alignment specs of your car, you should start by returning all settings to the original factory specs. Adjustments are always easiest when starting from "zero".
