Tire pressure settings - BMW M5 Forum and M6 Forums
Old 1st August 2000, 14:58   #1
nwood
Post Tire pressure settings
Picked my car up THursday with 36/38 set by dealer.
I have the Michelins
Any thoughts on the best pressures?
Nick
nwood is offline   Reply With Quote
Old 1st August 2000, 19:30   #2
MEnthusiast
Moderator Emeritus
MEnthusiast's Avatar
Garage: 03 M5
Post
Ive written on the boards about the various pressure numbers are told or are using. here are mine:
39fr/41rear
the door sticker says 44/48- but this was too high.
the book says 35/38 but I think this is too low.
my dealer first said follow the door sticker, but then after the 1200 mi service they set it to 38/41.
BMWNA said to follow the dealer.
I was experimenting with 40/42. I decided to go with the new dealer numbers of 38/41 but I bumped the fronts up to 39- bad roads where I am.
ME
MEnthusiast is offline   Reply With Quote
Old 2nd August 2000, 04:54   #3
one2000m5
All of have the same question nad the answer lies in common sense, personal preference, and tire ratings. The book is wrong, period. The door sticker is a good guide. I had Dunlops on my first M5 and ran them 41/43. I have Michelins on the second and I am running them 42/45. We have good roads here and I prefer the stiffer ride. If you have poor roads, your ride comfort at 43/45 will be terrible. The tire ratings on both the Michelins and Dunlops are 51 psi MAX. ALthough the guys at the performance center did not say what they were running, they did indicate it was near max. Running the tires below 39 is setting oneself up for severe cupping or outer edge wear IF you drive aggressively. If you drive like an old lady, then set those pressures in the 30s and enjoy the softer ride. At days end, the psi should be between 39 to 44 front, 41 to 46 rear. The rest is preference. Watch your tire wear and adjust pressures accordingly. If you go to the track, run the pressures up near max, but remember to defalte them when the pavement pounding is done...my 2 cents
one2000m5 is offline   Reply With Quote
Old 3rd August 2000, 08:18   #4
vapour
A word of caution. Increasing tire pressure to near-max will affect wet weather handling (it gets worse). Be careful in wet weather after you play with the pressure.
Vapour.
vapour is offline   Reply With Quote
Old 7th August 2000, 02:07   #5
marlin
Post
I just checked my tire pressures (500 miles)
picked up the car tuesday.
RF 35psi
LF 33psi
LR 33psi
RR 34psi
I'll adjust to 39/41 tomorrow.
Bye the way.. I picked up a preety cool backlit digital tire guage at Brookstone.
marlin is offline   Reply With Quote
Old 7th August 2000, 03:27   #6
Jester
Garage: M5 Titanium Silver
Post
SC performance center people said go with the door rating.
00' ///M5 Titanium Silver/Caramel
00' Vette convertible NBM
Jester is offline   Reply With Quote
Bridgestone S03's and track tire pressure rprellwitz E39 M5 and E52 Z8 Discussion 20 20th June 2003 08:28
? tire pressure warning ? LGREM E39 M5 and E52 Z8 Discussion 10 29th January 2003 01:45
droppping tire pressure M'nd E39 M5 and E52 Z8 Discussion 4 31st October 2002 17:06
New owners: You MUST calibrate the tire pressure monitor greg E39 M5 and E52 Z8 Discussion 2 25th October 2001 01:46
Did you check your tire pressure today? SteveP E39 M5 and E52 Z8 Discussion 6 7th November 2000 19:28
