Troubleshooting electric adjustment of driver's seat & steering wheel? - BMW M5 Forum and M6 Forums
Old 13th March 2006, 05:55   #1
Machtig
Machtig's Avatar
Garage: 1988 M5
Well, I get in the car today and neither the drivers seat or steering wheel will adjust. Checked the fuses and they are fine, even swapped them out. While looking for loose connections, I also found a switch under the steering column, just behind the wheel. When I turn it on, with the ignition on, there is a series of beeps, when I turn it off and then place the ignition on, no beeps, any idea what the hell this switch does, there is no mention of it in the owners manual, at least that I could find.
Machtig is offline   Reply With Quote Quick reply to this message
Old 13th March 2006, 06:36   #2
Beamer_usa
Beamer_usa's Avatar
Garage: explosive ford pinto
Could be an after-market switch installed by previous owner. Possibly an ignition kill, or some type of aftermarket security system???
I used to have a similar problem with my old 540. Every once in a while the seat controls and steering wheel adjustment would not work. Had $tealer check for problem several times. Suprise, Suprise, $tealer could never find the problem! The problem would not happen that often, and I noticed it usually happened when the weather was raining/humid??? Darn Gremlins
Dinan Cans
Dinan Software
Beamer_usa is offline   Reply With Quote Quick reply to this message
Old 13th March 2006, 06:39   #3
chunpng
chunpng's Avatar
Garage: M5, silver/black
The steering column and seat memory module is one unit in the m5 and is prone to failure. I had mine replaced twice under warranty.
Good luck.
CP
CP
00 Titanium Silver: 6/00-1/05 RIP
95 Black Metallic RUF BTR-2
07 Meteor Grey Cayman
chunpng is offline   Reply With Quote Quick reply to this message
Old 13th March 2006, 14:12   #4
HDClown
HDClown's Avatar
Garage: 2002 M5
Good luck.
CP
Is the memory module part of the 4 button memory unit in the driver side door?
2002 LMB/LMB M5 - Alcantara Headliner, Electric Shades, Folder Down Seats, M-Audio
-Britalman Exhaust, Brembo GT 355f/345r Big Brake Kit, Centric Posi-Quiet Pads, AA CAI
-UF IATS Relocation, UUC Evo3 SSK + DSSR, UUC Clutch Stop 19" Breyton Spirit Rims
-TCD Rear Sway Brackets, Euro Angel Eyes, Angel iBright v3.0, Stealth Bulbs, Stealth One
-Valentine One, Roof Spoiler, OEM Voice Control, OEM Trunk Storage Bin, 13% Solar Gard HP Tint
HDClown is offline   Reply With Quote Quick reply to this message
Old 13th March 2006, 18:41   #5
chunpng
chunpng's Avatar
It is, but I do not know if it is in the door though. I was not there when they swapped it out.
CP
Old 25th March 2006, 11:32   #6
Machtig
Machtig's Avatar
Garage: 1988 M5
Well, I fixed it. Turns out it was the drivers seat/steering wheel memory module, which, fyi costs $167 with bmwcca discount. got a 24hr subscription to the BMW TIS website and after much searching, found a service bulletin, turns out it is prone to failure, also downloaded how to remove/replace it.
Old 25th March 2006, 12:27   #7
WylM5
WylM5's Avatar
Garage: 91 E34M5 01E39M5
Hey Rev,
Can the module be fixed or is it just a total loss? Also have you tried BMA? I am sure they carry stuff for the E39 and they have provided great service and deals for my E34
1991 E34 M5
Dinan Stage III Suspension///Dinan Chip
Brembo Cross Drilled Rotors///HRE 340 Rims
Supersprint Exhaust///UUC Short Shifter
____________________________________
2001 E39 M5
Dinan Front and Rear Brace///Dinan Software///Dinan Differential///Dinan Rear Swaybar///BP Sway bar braket
///Tubi Exhaust
Brembo Front brake kit///UUC Short Shifter///UUC Clutch + Lightweight Flywheel///Rouge Engineering Tranny Mounts///UF Motorsports IATS
///Koni front + rear
WylM5 is offline   Reply With Quote Quick reply to this message
Old 25th March 2006, 15:00   #8
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (4)
How about posting module description/part # and location for future reference? Thanks
gsfent is offline   Reply With Quote Quick reply to this message
Old 26th March 2006, 05:15   #9
Machtig
Machtig's Avatar
Garage: 1988 M5
No problem, the memory module actually contains the switches for the seat back and seat bottom (what moves the seat back and forth, up and down, etc), its all one unit, so you have to remove the whole panel thing on the side of the seat which can be a PITA there are a couple hidden screws that must come out. Once you got it off , the switch/memory module will just pop out. The part number is 61 31 6 910 717 I still have my old one, dont know if it can be repaired or not, I would bet not.
The Following User Says Thank You to Machtig For This Useful Post:
M-Alex (9th June 2009)
Old 26th March 2006, 14:10   #10
gsfent
gsfent's Avatar
Sales Feedback: (4)
2001+ Steering Wheel retrofit - complete billrM5 E39 M5 and E52 Z8 Discussion 66 9th March 2014 20:18
KDS, steering box adjustment, steering pull, etc, etc plisken E34 M5 Discussion 1 22nd October 2004 17:31
Did any BMW come with a SMG Pedals + Heated steering wheel? Auraraptor E39 M5 and E52 Z8 Discussion 2 6th October 2004 05:52
Automatic steering wheel tilt krullshards E39 M5 and E52 Z8 Discussion 20 20th August 2002 17:44
steering wheel lock et1bill E34 M5 Discussion 1 17th August 2002 17:08
