Old 30th March 2006, 18:58   #61
1mpowerme
1mpowerme's Avatar
Garage: 2000 Carbon Black M5
Sales Feedback: (7)
Originally Posted by Frits
Ow, terrible to hear 1mpowerme! I guess you already tried reconnecting the copper ribbon cables, just to make sure they are properly fit in the connectors?
The copper ribbon cables are a pain to get in real good and sometimes they do slip. Once when the connection wasn't so good I noticed the screen didn't even light up or at times if you shake the cable the screen would turn white.
Once they are properly seated, it seems like you get correct picture and from there I would think all the navigation buttons on each side of the screen would work. In my case they don't now. The only one that works is the right bottom knob and it will only allow me to change my scale. If I press down for example to bring up the navigation menu for more options, it does nothing.
I tried pressing the eject button too for example so I could attach the screen to the frame and that doesn't work either.
I posted a thread specifically for this problem but I'm sure no one has really had it so not much help. I went to X5World and Bimmernav to see if anything was out there and nothing either.
I'm fairly happy with my 4:3 screen, especially after I upgraded to an MKIV computer and have the V27 firmware and the latest 2006.02 DVD.
But a 16:9 screen would be nice too.
Thanks for your write up Fritz. I enjoyed the many times you said "Watch for those copper cables!"
2000 BMW M5
Carbon Black
Black/Aluminum Trim
- Bilstein PSS9 Suspention
- Dinan F&R Tower Struts
- Navigation Upgrade to MKIV Computer and 16:9 Widescreen
- Headlight Upgrade to Hella Headlights w/Angel Eyes and 6000K HIDs
- Fog Light Upgrade with 6000K HIDs
- Tail Light Upgrade with Hella Celis Tail Lights
- BBS RGR Diamondblack Wheels
- Tubi Exhaust
- UUC Short Shifter
- Black Kidney Grills
- Carbon Fiber Roundels on Wheels, Hood and Trunk
1mpowerme is offline
Old 29th May 2007, 04:39   #62
mamsterla
mamsterla's Avatar
Garage: 2001 LMB 800 HP DA Twin - The Blue Beast
Send a message via Yahoo to mamsterla
Late but worth trying
I just came across this mod this weekend. I tried it out - I can say it was tough getting the two little black grommets that hold the copper cables back into position. I just skipped the little black pins that fit into the grommets. So far things look better. I still need a good nav disk to try everything out. I am awaiting a recode and this trick did not fix my horizontal 1 pixel line that goes across the screen. It did help with the sharpness of the picture. Thanks for the people suggesting this.
-MA
***For Sale*** 2000 M5 - Titanium Silver / Napa Black / Aluminum Trim -UFMotorsport IATS kit - Alutec Strut Tower Brace -16:9 Nav Screen upgrade - MKIV DVD Nav - Beastpower rear swaybar brackets
2001 M5 - DA Twin - The Blue Beast 800HP former PhillyM5 car
mamsterla is offline
Old 11th March 2009, 05:04   #63
Flybot
Garage: 2000 M5, 98 528i, 74 911S
Hello,
First post on The Board. What a huge amount of info here. Im going to pick up a Silver/Black 2000 M5 next week and have been soaking up all the info I can about my dream car. Anyway, the widescreen and Mk IV nav is first on the mod list. I already have those mods and I dont even have the car yet! The X5/E39 widescreen issue has me searching everything to try and pin down which widescreen I have. The serial numbers arent anything like what has been posted for E39s or X5s. I will do the surgery to get to the adjustments inside the screen if I have to but I may have found a simpler answer that may help. CHeck out this link from this post that shows how to access a software brightness adjustment (Link at bottom):
Posted by Jack on May 14, 1999 at 09:07:52:
In Reply to: Re: Cool Nav Easter Egg! posted by Mohammed on May 13, 1999 at 22:17:52:
go to the main nav menu, select the "set" option
then hold down the menu key for 20 to 30 seconds and it will bring you to this secret menu which has some diagnostic functions and some other cool toys.
that is just one of the many hidden features of the nav system. I haven't found the rest yet.
oh BTW on this hidden menu there is a TV option.
since european versions of the nav system can also receive TV signals I wonder if it is just disabled by software on the US version and if there is a way to hack around it. Jack
THIS IS THE LINK:
http://www.bmwtips.com/tipsntricks/t...ervicemode.htm
Not sure what version of nav this referes to, but its a lot easier than surgery. Anyone tried this?
Flybot is offline
Old 11th March 2009, 10:21   #64
RichardP
RichardP's Avatar
Garage: E39 M5, Carbon Black
Does you monitor have the surround? If so then the E39 version has almost streight sides, the X5 version is slightly curved with slightly thicker top an bottom.
E39 :
X5
RichardP is offline
Old 11th March 2009, 15:33   #65
Flybot
Interesting. Well, my widescreen is still in the mail. So Ill look when it gets here in a few days.
Flybot is offline
Old 26th March 2009, 00:41   #66
Flybot
Well,
It looks like I have an X5 trim ring. Its about 1/4 inch too tall compared to the old 4:3 trim. The screen works fine and is E39. In other words, it looks brightest when closed and not open like some were saying. Its from ebay, so Im sure the parts came from different sources. I guess Ill check the dealer for the trim.
By the way- The software brightness function posted 3 above works great.
Flybot is offline
Old 10th April 2009, 04:08   #67
tmlesko
tmlesko's Avatar
Garage: 2000 M5 Silver/black&grey w/walnut
Where is the best source for getting a 16:9 nav screen? I have gone through 2 used 4:3 screens, they seem to have the same problem crop up, the function knob stops working so the unit becomes un-useable.
Tom L.
tmlesko is offline
Old 10th April 2009, 05:26   #68
Flybot
I used ebay. Ive been buying stuff there for years and have not had any problems. I would stick with US addresses though (if you live in the US). Try to confirm that it is from a E39 body.
If you want new try Bimmernav.com
Flybot is offline
Old 9th June 2009, 09:28   #69
ccebrun
ccebrun's Avatar
Garage: 2000 m5, royal red
successful operation
This was a great thread! Here is a tip for those going to do it: place a mirror facing up in the space in front of the cup holder so you can see the amount of change you are making as you turn the adjustment dials in back of the monitor.
CJ
ccebrun is offline
Old 16th November 2009, 20:47   #70
Diny
Diny's Avatar
Garage: Anthracite M5
Sales Feedback: (3)
Thread resurrection! I'm having a bit of an issue
The row with the 4 knobs in it controls things like saturation, brightness, and contrast (altogether, not individually). The ones on the other side control color and things like that (which is handy).
I can see the screen perfectly while the sun is shining directly on it, which is perfect. However...
I can't seem to control side-to-side angle. My problem is that the right side of my screen seems to be brigher than the left. So instead of having a smooth color, it does a gradient of brightness to the right. All the knobs control color and vertical angle, but I can't figure out horizontal angle. Any ideas?
Cristian
Anthracite///Black
For Sale: Sumitomo HTRZ III for 19s
For Sale: 2 GoPro Motorsports Wide Cameras
Diny is offline
M5s sideways matt_d E34 M5 Discussion 6 2nd October 2001 06:16
3 M5s in Corte Madera sighted C43///M5 E39 M5 and E52 Z8 Discussion 1 22nd August 2001 07:45
Is the M5's aluminum trim the same color as the 3 series'? Zoli 007 E39 M5 and E52 Z8 Discussion 1 20th May 2001 10:46
Are used M5's really selling like this? SAB E39 M5 and E52 Z8 Discussion 1 11th August 2000 01:00
Page generated in 0.60060 seconds with 12 queries
