Old 13th March 2006, 23:06   #21
1mpowerme
1mpowerme's Avatar
Garage: 2000 Carbon Black M5
Sales Feedback: (7)
Having said that Robstar, then it would probably be wise for people to ask sellers on eBay to get the part number for the screen rather than the housing which I feel somehow is being done.
But how do you explain all the various part numbers I've seen for 16:9 widescreen units? You would think there would only be five part numbers and all the units being sold out there would match on of those five.
Does someone know if the screen and bezel surround are the only parts that determine the pitch angle and difference between widescreen units for an X5 or M5? I assume the housing doesn't matter since both I and Robstar have been told the frame is the same for the X5s and M5s.
2000 BMW M5
Carbon Black
Black/Aluminum Trim
- Bilstein PSS9 Suspention
- Dinan F&R Tower Struts
- Navigation Upgrade to MKIV Computer and 16:9 Widescreen
- Headlight Upgrade to Hella Headlights w/Angel Eyes and 6000K HIDs
- Fog Light Upgrade with 6000K HIDs
- Tail Light Upgrade with Hella Celis Tail Lights
- BBS RGR Diamondblack Wheels
- Tubi Exhaust
- UUC Short Shifter
- Black Kidney Grills
- Carbon Fiber Roundels on Wheels, Hood and Trunk
1mpowerme is offline
Old 13th March 2006, 23:12   #22
Whizzkid11
Whizzkid11's Avatar
Garage: 2001 E39 M5 - "the Black Beast!"
Send a message via MSN to Whizzkid11
Originally Posted by Robstar
The main housing unit is 65.52-6 934 413 and the LCD PN is 65.52-6 913 385.
Fully agreed - as LCD panels are changeable.
Whizzkid11 is offline
Old 13th March 2006, 23:15   #23
Robstar
Robstar's Avatar
Garage: '00 E39 M5 Silverstone Blue
Seems the PNs on this item are all a bit of a mystery, even to BMW.
I've been told that the electronics inside the LCD screen are the only difference. They're programmed to work on different angles, which is why Frits is going to have a go at modifying his X5 screen to work at the E39 viewing angle.
Jeez this is all too complicated
2000 M5 Silverstone Blue
Robstar is offline
Old 14th March 2006, 01:13   #24
1mpowerme
1mpowerme's Avatar
Sales Feedback: (7)
Amen. I had no idea when I decided a nice upgrade from a 4:3 screen to a 16:9 screen would be such a detailed ordeal. For cost savings purposes you would think BMW would have created only three part numbers. The frame being one and good for all E39s and X5s out there, then a part number for E39screens and pitch angle, then one for X5s and be done with it.
Have one supplier manufacture these three parts. Apline out of Mexico for example. The rest is programming and done on a regional level around the world.
But that would be too easy right?
2000 BMW M5
Carbon Black
Black/Aluminum Trim
- Tubi Exhaust
- UUC Short Shifter
Old 18th March 2006, 06:35   #25
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
any updates yet Fritz? (yes, i'm anxious).
I ran a web translation of the document:
In English:
A) Monitor from the car remove: 1. Screen down 2. 4 screws around the monitor solve 3. Cables starting from
screen of the housing remove
B1. (4 screws) 2 removes upper sheet metal cover. 2 kupferfarbene cables mark (white bolting device pull up) 3 out. (folded up position) 4 pulls monitor out. 4 screws solve 5 at the carriage. The 2 Kupferfarbenen cables by the housing lead 6.
C decrease screen) screen divide 1. At the back 4 screws remove 2. Front remove 3. (2 screws) 4 unscrews photoelectric cell of the front. 5 removes front. 6 lifts complete plate from the housing. At the back the automatic controllers are one can everything really adjust: Brightness, contrast, intensity, color disalignment, red, green, blue, photoelectric cells sensitivity, and and and. For brightness contrast and intensity are responsible the left automatic controllers. The function of the 3. Automatic controller from above do not have I yet to define can. Possibly the photoelectric cell, there this also substantially more sensitively is now - on the day with full strength and at night beautifully dark. Which for a wohltat for the eyes. Rights are only plaything (red, green, blue, color disalignment, inverting (which is black, becomes white, and looks turned around somehow like black light.
D) Adjust 1. The 2 kupferfarbenen cables again sticks on 2. Bolting device for the cables secure 3. Material between plate and metal parts of the housing put, thus it to the short-circuit do not come to 4. In the car attach (see 2. Photo above) 5. Rules to fits. Examine in each case an automatic controller and a result. I have about 40 minutes adjusted to I with the result content was long again and again. And one sees the result here with radiating sunshine AND camera lightning. That it was really very bright recognizes one by the plates on the left and on the right.
I'm a little concerned about those kupferfarbenen cables!
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 18th March 2006, 07:04   #26
1mpowerme
1mpowerme's Avatar
Sales Feedback: (7)
Great job mottati. Those translation programs are funny sometimes. I have a friend in Germany who can probably translate this document for us and put it in to a little better words. If you guys want, I can e-mail him.
Or, does anyone know someone who works at a BMW dealership where they can have that employee speak to their service department and access files on repairs and adjustments to 16:9 screens? I have to imagine there's something available.
Another angle may be someone who just bought a BMW recently where the sales person might feel indebted to help out here?
I don't know, I'm just brainstorming.
2000 BMW M5
Carbon Black
Black/Aluminum Trim
- Tubi Exhaust
- UUC Short Shifter
Old 18th March 2006, 07:19   #27
mottati
mottati's Avatar
A real german translation would be nice. I found the translation a bit amusing, but slightly more helpful than the german text! I'm going to go look at my tis cd and see if i can find any info (but it's an old version, from 01). I doubt we'd get any help from a dealer, but i am going to post a question and link this thread on bimmerboard.com, who are pretty nav savvy.
Now that i have my new splashscreen (thanks vancoverM) i really want the display to be sharper/brighter...
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 18th March 2006, 18:47   #28
1mpowerme
1mpowerme's Avatar
Sales Feedback: (7)
I'm installing my MKIV computer this morning. I purchased what is supposed to be an E39 screen from an eBay user named ana_cernys out of Lithuania. She's rather slow to respond and it's been a little frustrating trying to purchase the unit from her but she claims she has a 2003 screen in mint condition including the trim piece and I paid $560.00 including the shipping.
I'll keep an eye out for your thread or if you want to post it here, then we can all link over to it.
Thanks for the help.
2000 BMW M5
Carbon Black
Black/Aluminum Trim
- Tubi Exhaust
- UUC Short Shifter
Old 18th March 2006, 18:49   #29
Frits
Frits's Avatar
Garage: E36 M3 alpine white E39 M5 carbon black E24 M635CSi royal blue
Ok, guys, I'm working on it right now. This is NOT EASY!!!! I'm taking quite some pictures, and I'll give a decent report once finished, if ever
I'm removing the last 6 screws now, I think...
Frits is offline
Old 18th March 2006, 18:52   #30
1mpowerme
1mpowerme's Avatar
Sales Feedback: (7)
What a man.
By the way, I don't mean to be a post whore but I hate being a newbee with the < 31 posts thing and I'm just trying to rack up some posts here in the beginning.
2000 BMW M5
Carbon Black
Black/Aluminum Trim
- Tubi Exhaust
- UUC Short Shifter
M5s sideways matt_d E34 M5 Discussion 6 2nd October 2001 06:16
3 M5s in Corte Madera sighted C43///M5 E39 M5 and E52 Z8 Discussion 1 22nd August 2001 07:45
Is the M5's aluminum trim the same color as the 3 series'? Zoli 007 E39 M5 and E52 Z8 Discussion 1 20th May 2001 10:46
Are used M5's really selling like this? SAB E39 M5 and E52 Z8 Discussion 1 11th August 2000 01:00
Page generated in 2.17328 seconds with 12 queries
