Old 11th March 2006, 21:22   #1
baldy_bonce
baldy_bonce's Avatar
Garage: BMW M5/ Le Mans Blue
Battery problems! Trickle charger recommendations?
Hi Guys,
Been a while since I have posted so many apologies there.
My M5 is only used once a fortnight (what a crime) and as a consequence my battery keeps going flat. I have had BMW emergency services out twice now. The last technician said a new battery is required which under my warranty I will be getting a new one next weekend.
I have been advised to leave the battery on a trickle charger whilst the car is not in use, does anyone else do this and if so any particular model of charger to purchase?
baldy_bonce is offline
Old 11th March 2006, 22:31   #2
BKH
BKH's Avatar
Garage: 2000 BMW M5 Silverstone
http://www.batterytender.com/
BKH is offline
Old 11th March 2006, 22:57   #3
MartinW
MartinW's Avatar
Garage: 2001 M5 Estoril Blue / Black Nappa - sadly traded on!................. E60 530d Deep Green/ Beige - DMS chipped
this is the one for you!
http://www.hamiltonclassic.co.uk/Pro...ryCareCTEK.htm
I have three of these permanently working in the garage and they are brilliant. The basic 800 model is fine, but make sure you order the cigar lighter attachment for ease of use otherwise you are constantly connecting up under the bonnet, or worse in the boot.
Good luck!
Good fortune on the road ahead!
Martin.
MartinW is offline
Old 11th March 2006, 23:59   #4
gdoan
gdoan's Avatar
Garage: '03 ///M5 Black/Black
BMW Advanced Battery Charging System
I had similar problems during the winter, when the beast is hibernating. And, after leaving my radar detector plugged in in the garage for 2 weeks and killing my battery, I went out and bought the BMW Advanced Battery Charging System. With a CCA discount, it cost me around $60 plus tax.
http://www.bmw-online.com/BMWRA_prod...ry&bplo=&bphi=
It works well. I think it is OEMed by Battery Tender . . .
Greg
2003 ///M5 Jet Black/Black, Sport
Beastpower Sway Bar Brackets, Bluetooth, Aux Audio Input & all "plus" options except PDC
gdoan is offline
Old 12th March 2006, 00:26   #5
mancm5
Garage: bmw m5 e39 silverstone
what you want is a solar power panel you plug into the cig lighter it then trickle charges the battery thats what i use it feeds off the light
mancm5 is offline
Old 12th March 2006, 09:31   #6
baldy_bonce
Thanks Guys,
Will look into getting one of these this week, I have not had a car before that wasnt a daily driver so am not used to the pitfalls of storing cars for long periods without use.
Old 12th March 2006, 11:05   #7
mancm5
you can get them from maplins
mancm5 is offline
Old 12th March 2006, 20:45   #8
jclyman
jclyman's Avatar
If you decide on the BMW trickle charger, I would recommend the Mini trickle charger instead ... same identical unit, but the Mini charger has alligator clips and the BMW charger has a cig lighter insert.
- Daniel Boorstin
jclyman is offline
Old 13th March 2006, 02:35   #9
M Macht
M Macht's Avatar
Garage: 2001 Imola Red M5
My vote is for Battery Tender which if memory serves also makes the unit sold through your friendly BMW dealer.
Nick
2001 E39 ///M5: Imola Red/Caramel/Walnut
PowerChip Gold 91
9.5x18 inch OE Rims On All Four Corners
275/35 Michelin PS2's
Brake Ducts and M Technik Splitter
UUC EVO3 Short Shifter and Double Shear Selector Rod
Rogue Transmission Mounts
BeastPower Sway Bar Brackets
Valentine One and Stealth One
Titanium Pedals
Angel iBright V3.0
Sylvania Silverstar High Beams and Fog Lamps
Platinumvision 2.0 Bulbs
Tinted Windows
"Spare" 8x18 inch OEM Rim and Tire With Jack and All Trunk Lid Tools
M5 Trunk Mat
Trunk Storage Bin
M License Plate Bracket
Too much horsepower is never enough.
M Macht is offline
Old 13th March 2006, 02:52   #10
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
VW has an inexpensive solar charger that plugs into the cig lighter. On ebay. Around $15-$20 last time I checked.
gsfent is online now
Battery tender question.... leebro1 E39 M5 and E52 Z8 Discussion 27 12th April 2007 22:08
BMW battery charger q's GT4ME E39 M5 and E52 Z8 Discussion 10 30th December 2005 23:05
Weak battery kalvin E39 M5 and E52 Z8 Discussion 43 15th December 2005 20:44
Anyone use a trickle charger? JDOMROE E39 M5 and E52 Z8 Discussion 5 11th December 2003 15:22
Trickle Charger Andy G E34 M5 Discussion 8 11th March 2002 20:09
Page generated in 0.14465 seconds with 11 queries
