9th March 2006, 21:04
#1
Spark plugs - NGK vs. Denso
NGK is OEM as I understand. Is the correct #3199 - BRK6QUP? I am getting ready to swap plugs and I think they are correct. Price vs. the denso's seems HUGE! Found the NGK's for $6.78 each vs. the first place I found the Denso Iridiums - $24.00 each! Can their really be that much desparity?
Current Toys: 2000 M5 with lots of goodies, 1997 993 Targa mostly stock, 2002 Jeep GC all set for offroad, 2004 Acura TL bone stock
9th March 2006, 22:57
#2
1999 Imola Red M5
NGK BKR6EQUP is what you are after (you missed an 'E'). It's personal preference I guess, but I figure that BMW used them for a reason and if they are good enough for BMW they are good enough for me. If I were cynical I could say that the only reason they used them is because they were cheap and they have agreements with NGK to use their plugs, but if we thought like that we'd never buy anything  The Iridiums are probably a fantastic plug, but the net increase in performance or efficiency is probably rather negligible.
At least if something goes wrong and you want to take it to a dealer to diagnose, you wont have to change the plugs incase they realise they are different and stop looking for the 'real' fault.
1999 Imola Red M5. Extended Caramel Interior
Mods on my pre-update beast:Eisenmann "Race" exhaust (76mm tips), 19" Hamann PG2's, AACAI, Clear Angel Eyes, MK4 Nav, GC's M5 Coilover kit w/front camber plates, Dinan Front and rear sway bars, D/A swaybar mounts, Dinan front and rear strut brace, Braided brake lines, Eibach 3mm wheel spacers, Rogue Engineering underdrive pulleys, IATS Relocation, Powerchip, Xenon foglights & Lower engine covers w/Brake duct cutout
2008 Volkswagen Golf GTI. The wifes new car
2005 Ford Territory Ghia. The wifes car. (Sold)
1986 Toyota Landcruiser HJ75. The farm ute.
9th March 2006, 23:00
#3
explosive ford pinto
IMO I would stay OE NGK. Like the previous post says if you go to the $tealer with a problem they will blame the non OE plugs. No matter if they are to blame or not. DON'T GIVE THEM ANY EXCUSES! THEY HAVE ENOUGH!
Dinan Cans
Dinan Software
9th March 2006, 23:06
#4
Im there with you Beamer - I ordered the NGK's. Just for S&G's I called the stealership for their price. $14.99 each. I bought them online for $6.78. And I didn't have to pay tax. I got the whole set of 8 shipped for less than half of what I would have paid the stealer for 4...
9th March 2006, 23:09
#5
I have the irridum densos in my car. Honestly, i can't say that they are 3x better than the factory plug. i put fresh bmw ngk's in the car (cost around $8-9 iirc, but i have a good source) and about 6k miles later i put a set of the denso irridums in. Left them in for another 6-7k miles. MPG actually went up according to the obc by around 0.5mpg, car didn't feel any different honestly. I read the potential internet horror stories about the irridums and put the oe ngks back in, mpg did drop slightly again, but no noticable difference in performance. After a little more research, i think the internet horror stories about plugs breaking up did not actually apply to the currently available denso's, so what the heck, i put them back in.
The only thing of interest in all of this rambling is this.... The denso's came out looking much 'cleaner' after 6-7k of use than the bmw/ngks for a similar amount of milage. Not sure if that means better or more complete combustion or what with the irridiums...
10th March 2006, 03:52
#6
Moderator Emeritus
The intended use for iridium plugs was for high boost applications. (thin electrode doesnt cause as much turbulence, and the small gap doesnt let the spark blow out). So, if there is any real difference in an NA car...it will be minute
10th March 2006, 05:06
#7
Red White and Blue
NGK is better than denso....
I have seen it both in the M5 and now with my 4runner. Toyota uses both plugs (and more times than not, mixes them in engines) with poor performance. The NGK's have been shown to really be the better plug.
Im in the highspeed aluminum business
10th March 2006, 05:35
#8
why not try a NGK IRidium...check out what's avaialbe at KRagen..
BTW , i you like changing plugs oftent copper plugs work fine
http://www.partsamerica.com/ProductL...or=Spark+Plugs
2001 E39 M5 Titanium Silver/Silverstone
1997 BMW M3 Gruppe N Race Car
2005 X5 4.4i
10th March 2006, 06:13
#9
73 Pinto Babypuke Green
Mottati, changing that soon was for a test?
I have NGK Iridiums in the BMW and NGK in everything I own.
I have seen first hand Toyota putting Denso in one side and NGK in the other. Falls into the JUST IN TIME parts theory.
I have not seen in recent months any of the old type of Denso's with the pad that comes off. Now if I can just figure out what oil wieght the NGK's like best.
I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way.
Modifications
Chipped paint
Worn tyres
Dirty Carpet
Chipped windshield
10th March 2006, 06:15
#10
Red White and Blue
Kirkland.
I am swapped from NGK Laser Iridium (an OEM plug for toyota) to the IX's and they made a significant difference in performance. Throttle response, mid range torque and upper band power all increase while smoothing out and already smooth idle.
I too would suggest those that want to swap over to an iridium plug to go with the NGKs
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
