Old 9th March 2006, 07:36   #1
birdie74
Garage: m5 silver
Test drive Questions
I test drove a MY '01 today. When I accelerated hard and close to redline, the car sort of hesitated. Is this normal? The seller said that it was sort of a signal to tell that you need to shift gears. Is that true?
Other than that, the car was very clean. New clutch, new tires and the body was pretty much perfect. The interior was pretty clean as well. The car has no warranty and has 44k. He's asking 39.9k. Is this a fair deal? The car is in CA.
birdie74 is offline
Old 9th March 2006, 09:11   #2
ard
ard's Avatar
There is a rev limiter at 7k rpms... not sure I'd call that a "signal to shift" (you need to shif PRIOR to hitting the limiter.)
How 'close' to the redline was it? every gear?
No warranty is foolish.
ard is offline
Old 9th March 2006, 09:25   #3
birdie74
Garage: m5 silver
I'm not sure which gear it was. I wasn't paying attention to the redline, but from the sound of the engine, I know it was close. The car sort of "hesitated".
What happens when you hit the rev limiter? What's the feeling like?
birdie74 is offline
Old 9th March 2006, 10:52   #4
dave_gt
dave_gt's Avatar
Garage: E39 M5 Le Mans Blue
Hitting the rev limiter in 1st or 2nd (done it once or twice, not deliberately) feels a lot more than a hesitation. With your foot mashed to the floor and major acceleration going on, your brain does not expect a let up in acceleration until your foot comes off the accelerator. If you hit the rev-limiter with your foot still down your brain doesn't expect it and so it almost feels like you have run into something - the power disappears.
In 1st gear the rev counter is a fair bit slower than the car, so the limiter which cuts in at 7200rpm (genuine) nabs all the power at an indicated 6000rpm or so, but it keeps up in 2nd gear. There are a few possibilities:
1) Something is wrong with the car and the seller is making something up about it signalling when to shift. The car does not give any sort of hesitation signal to change gear.
2) It is the rev-limiter that you hit and the seller is telling the truth that he uses the limiter as a signal to shift. If this is the case, run in the opposite direction as quickly as you can
The rev counter in an M5 lights up with yellow and red bars. The yellow bars go out as the engine warms up, but the final one at 6500rpm stays on as a warning that you should be thinking about changing gear. The red lights start at 7000rpm and this zone should not be entered to avoid damaging the engine. If you happen to get it wrong and over rev the engine, there is a cut out at about 7200rpm to stop you blowing the engine up. It aint good for the car to be constantly revved up to the limiter.
Hope this helps
2001 M5, Lemans Blue / Silverstone
Standard except for a few bits & stereo:
6.5" Focal components, 10" Directed sub, IceLink, JL Audio & Directed amps (hidden). Predator ICE, Stealth bulbs, V1, Roadpilot
1990 Mazda MX-5 (brilliant) 1998 Nissan Primera GT (modded)
dave_gt is offline
interesting article on BMW design MEnthusiast E60 M5 and E61 M5 Touring Discussion 33 28th November 2007 19:28
BMW 130i Test drive... Kirium GTBoard.com: General Sportscars 5 8th February 2006 11:11
M5 Test Drive Advice Lobo E39 M5 and E52 Z8 Discussion 0 16th August 2005 23:20
Dark Side-Keep My 02 M5 after Lease:Cadillac V Test Drive Impressions, Feedback?? Johnny D E39 M5 and E52 Z8 Discussion 12 30th October 2004 13:18
Top Gear test drive of the McLaren F1? DrSakke E34 M5 Discussion 2 28th April 2002 23:32
Page generated in 0.11105 seconds with 11 queries
