Old 9th March 2006, 00:38   #1
jetblkm5
Garage: BMW M5 - 2002 Jet Black on Black
E34 Throwing stars on an E39 M5
Looking for a spare set of wheels for the winter (better late than never). Has anyone used the e34 throwing stars (17inch) from the 540i M Sport or the euro M5 on their E39 M5?
I used to have these on my E34 and loved them... and would prefer not to pony up for a spare set of M5 OEM wheels.
jetblkm5 is offline
Old 9th March 2006, 00:57   #2
Beamer_usa
Beamer_usa's Avatar
Garage: explosive ford pinto
yes, tirerack.com sells the winter tire/wheel combo. I have the Borbet 17" winter set up from them.
This should help:
http://www.tirerack.com/snow/WinterP...0&autoModClar=
Dinan Cans
Dinan Software
Beamer_usa is offline
Old 9th March 2006, 00:58   #3
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
e34 wheels should not fit the e39 due to a different center bore diameter. Few 17" wheels will clear the M5 brakes. bmw style 66 will, as will a few aftermarket wheels.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 9th March 2006, 01:23   #4
Absinthe
Absinthe's Avatar
Garage: Carbon Black 2000
Send a message via Yahoo to Absinthe
damn I was just thinking I have a good friend parting out an e34 with throwing stars and RD 5 spokes, so its a definate no go? sux no cheap wheels for the snow tires here then.
Absinthe is offline
Old 9th March 2006, 01:41   #5
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
If the throwing stars clear the calipers ( a big if), you could have the wheel centers bored out. But I would carefully measure the wheels and brakes before you do that. It is unlikely they will clear the big front brakes of the E39.
You are probably better off getting some used #66 wheels as suggested, or look for some repro's for winter use. Check ebay or check Tire Rack.
gsfent is online now
Old 9th March 2006, 01:44   #6
Absinthe
Absinthe's Avatar
yeah i have been checking both like crazy TR has some descent options cheap, the TS wheels just always made me laugh.
Absinthe is offline
Old 9th March 2006, 02:05   #7
jetblkm5
Throwing Stars for M5
The (large) brakes from the 1995 Canadian M540i are contained by the throwing stars...
The specs for these brakes are very large (although perhaps not large enough) -
From the old spec sheet "4 wheel floating independent disc brakes from the 1995 M5. 345x32mm front floating rotors and 328x20mm rear fixed rotors"
Does that give enough to understand if they'd fit?
jetblkm5 is offline
Wooo tfung gone off deep end... EBMCS03 Off Topic Forum 4494 Yesterday 18:20
e39 m5 is the undisputed champ cebu E39 M5 and E52 Z8 Discussion 7 1st February 2008 07:28
wtb: E34 throwing stars with 9" rears M540i LE For Sale or Wanted 1 12th February 2005 07:17
14 September press release in English, 0-100 4,7s SuperBMW E60 M5 and E61 M5 Touring Discussion 0 14th September 2004 12:23
My E34 M5 Turbo! Just an E39 M5 eater...PICS and VIDEO! Truglester[M5] E34 M5 Discussion 15 7th June 2004 20:31
Page generated in 0.13515 seconds with 11 queries
