I've done it myself and I am not that good with mechanics.. although I will try anything once
The only thing that I found was that the rubber gasket over the plugs was a bit bigger than the surround it was meant to seal so it was a bit of a bugger to get to stay in place.
I went with the OEM NGK.... god forbid you break the engine some how and if you have different plugs then the game is up. Sure you could replace them with the BMW ones but its just a hassle... stick with OEM - they used them for a reason and they are not woefully inadequate.
1999 Imola Red M5. Extended Caramel Interior
Mods on my pre-update beast:Eisenmann "Race" exhaust (76mm tips), 19" Hamann PG2's, AACAI, Clear Angel Eyes, MK4 Nav, GC's M5 Coilover kit w/front camber plates, Dinan Front and rear sway bars, D/A swaybar mounts, Dinan front and rear strut brace, Braided brake lines, Eibach 3mm wheel spacers, Rogue Engineering underdrive pulleys, IATS Relocation, Powerchip, Xenon foglights & Lower engine covers w/Brake duct cutout
2008 Volkswagen Golf GTI. The wifes new car
2005 Ford Territory Ghia. The wifes car. (Sold)
1986 Toyota Landcruiser HJ75. The farm ute.
