You're welcome. Another tell-tale sign that it is the FSR and not a fuse is if just prior to the blower not working at all, it was acting up, i.e. intermittently "stuck" on one speed, then working fine the next day. Mine did this a couple times before it went out completely. Heck, I couldn't even locate the fuse that was supposedly for the blower motor!
Being in So Cal in the middle of summer, I couldn't go without a.c. for long!
It is a bit of a PITA to locate, remove, and then replace the FSR, because it is located in such a crevice with other wires in the way and it is a tight fit for your hand/fingers...but it isn't something one can't do themself with a bit of persistence and patience....
Good luck!
