Old 6th March 2006, 16:53   #1
JTinAZ
JTinAZ's Avatar
Garage: 2000 Black on Black
passenger side mirror gets stuck...
I have a 2000 M5, and every now and then when I flip the mirrors up to show off or park in my garage the passenger one stays in the "up" position until I turn the car off and on again..then it works fine. I had the motor swapped out at the dealership so I doubt that the problem. any ideas?
JTinAZ is offline
Old 6th March 2006, 17:00   #2
alantd
alantd's Avatar
Garage: 09/02 E39 M5; Carbon Black; Stock
Do a search - there are several threads on this.
The mechanism is slightly weak (plastic cogs), possibly by design so as to prevent damage in the case of an impact or resistance, so it is a common problem.
Consensus is that judicios use of the hand, either as a gently support to the motor or as a good hearty thump does the trick.
02 Carbon Black Stock
05 Land Rover Defender
alantd is offline
Installed AA CAI, IATS Relo, and UUC Clutch Stop yesterday - my install notes HDClown E39 M5 and E52 Z8 Discussion 4 16th July 2005 18:17
Driver side angel eyes dimmer then passenger side HDClown E39 M5 and E52 Z8 Discussion 6 28th June 2005 14:34
HORRIBLE TRAGEDY 6speed member Ben Keaton (ben lj) and passenger in fatal crash LSM E39 M5 and E52 Z8 Discussion 32 7th June 2005 03:57
Missing front side airbags? wundercar E39 M5 and E52 Z8 Discussion 3 9th November 2001 17:32
My passenger seat is stuck!!!!! mannysandoval E34 M5 Discussion 1 2nd September 2000 05:36
Page generated in 0.07909 seconds with 11 queries
