Old 28th February 2006, 20:38   #1
Ocean's M5
Ocean's M5's Avatar
Garage: 2002 M5
Thrust Arm Bushings
Is there a way to check and see if the Thrust Arm Bushings are slightly bad or worn? Or, Does it just break totally?
I feel a slight shimmy occcasionally on Breaking at high sppeed.
Lastly, Is it a DIY project?
2002-05 Build Carbon Black ///M5
First Aid Kit ~ Warning Triangle ~ Full BMW Tool Kit
Rear Cupholders ~ Stubby Air Stems ~ Rear Shades ~ PDC
M Audio ~ Fold-Down Rears ~ Black Sport Int.~ Yokohama Advan Sport~
Beast Power Sway Brackets ~ Tinting-80% Strip Windshield
Center Armrest *Storage Bin ~ ///M Black Trunk Mat
Ocean's M5 is offline
Old 28th February 2006, 20:46   #2
Beamer_usa
Beamer_usa's Avatar
Garage: explosive ford pinto
Have you checked your rotors, make sure their not warped? as far as the bushings they wear down gradually.
Dinan Cans
Dinan Software
Beamer_usa is offline
Old 28th February 2006, 20:47   #3
cosioboy
cosioboy's Avatar
Garage: 2000 M5 Carbon Black
On a lift I would think you should be able to see and inspect them.
I am about to replace mine pretty soon and will be running 275s up front on rear rims with spacers. I am thinking of using the allegedly more durable bushings frm the X5 4.8is. I believe Mike has installed these and is running them for a few months now, so maybe he can share his thoughts. Same exact fit, but I suspect more durable, so you may want to consider that if it is indeed your issue.
The shimmy while breaking at high speeds could be an indication of an uneven pad deposit on your rotors. An easy procedure described on Dave Z's and Stop Tech's website will clear these (basically a series of high speed controlled stops).
cosioboy is offline
Old 28th February 2006, 20:48   #4
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
it is a slow, gradual change. A good independent shop should be able to tell if they're getting worn, based on play in the suspension links.
I recently upgraded to X5 bushings, which seem to be a little 'beefier', so we'll see...
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 28th February 2006, 20:51   #5
cosioboy
cosioboy's Avatar
Warping and rotors are two words that do not go well together
The myth:
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Here is the removal procedure:
http://www.stoptech.com/tech_info/wp_padremoval.shtml
PS
Mike, we must have been typing simultaneously, I was just referring to your X5 bushings...
cosioboy is offline
Old 28th February 2006, 20:56   #6
mottati
mottati's Avatar
Originally Posted by cosioboy
PS
You just beat me! So far so good with the x5 bushings. I haven't had the car on the track since, but street driving is good. Nicer response than the old bushings (one of which had failed within about 10k miles of install, i think must have been a dealer install issue) but no harshness etc.
mottati is offline
Old 28th February 2006, 21:17   #7
palantirion
palantirion's Avatar
Garage: 2003 M5 (Dinan S2), Imola Red
If you're in southern CA, anywhere near Santa Ana, I'd take it to BMS. They've diagnosed the same problem with my beast when I thought I had a brake problem and coached me on how to get the dealership to replace the bushings under warranty. I'm getting ready to replace mine for the second time, although this time I may skip the dealership and have BMS replace them with the X5 bushings - stock M5 bushings die quickly with bigger tires and track driving.
You can contact BMS at 714-429-0257. Ask for Chris or Mike and tell them Earl sent you.
www.ebsart.com
2007 Z4 M Coupe, Titanium Silver with Imola Red, black and silver interior
-for details: www.mymcoupe.com
2003 M5, Imola Red with black and silver interior
-Dinan S2 drivetrain
-Dinan stage 3 suspension with JRZ shocks
-StopTech brakes
-Rogue Engineering short shift kit and clutch stop
-275/35R18 Michellins f/r on 18x9.5 BBS RS-GTs
-Progressive window tint
-Euro dash and armrest conversions
-CDT/Total audio, NavTv w/ DVD
-Seat massagers
2002 540iT, Sapphire Black with black and red interior
-Dinan stage 3 suspension with Koni shocks
-StopTech brakes
-255/40R18 PS2s f/r on 18x8.5 BBS RG-Rs
-Custom interior trim and seat massagers
-NavTv with DVD
palantirion is offline
Old 28th February 2006, 21:19   #8
imolaman
imolaman's Avatar
Garage: 2001 BMW M5 Imola Red
Send a message via MSN to imolaman
Has anyone tried "skimming" their rotors to remove deposits and perhaps the odd high spots? I have made an appointment with a reputable brake fitment centre as I also have a slight vibration under hard braking. I initially ruled out the thrust arm bushings as they were replaced about 10 000 km ago. Now reading Mike's reply about his bushings failing again so soon it might warrant a trip back to the dealership for a little warranty claim. On skimming the fitment centre claim they do not remove the rotor from the vehicle, only the wheel and the caliper set, then they just skim a very tiny amount of metal off the surface, enough to remove the now famous brake pad deposit and any high spots that might have developed over time.
Would be interesting to hear opinions from others before I do the skimming.
Rudi
2001 Imola Red II E39 M5 - Stock
imolaman is offline
Old 28th February 2006, 21:23   #9
emccallum
emccallum's Avatar
Garage: 2001 m5, 2003 525it
You can take a large screwdriver and a good light and check them. Look for cracking and play. Even new ones tend to have some cushion to them. It will be apparent once you see them up close if they are cracked. I think it is a DIY, however, I have no idea your comfort level. Two ways to do them. One is to replace the entire control arm with the bushings allready in place. That is probably the most straight forward, but more expensive method. The other is to replace only the bushings. I replace only the bushings, using a bushing press that doesnt require the control arm to be removed. After about two or three swaps the tool pays for itself...I like tools so any excuse to buy one suits me. Just make sure the bushings are put in properly, and the bolts are torqued with the suspension weighted (wheels on the ground/ramps etc.). I think you need to remove the sway bar brackets on the m5 to get the bolt out...along with moving the steering arm to just the right place! Front end alignment after installation wouldn't hurt. Find out how much a dealer/shop charges then make the call.
ernest
emccallum is offline
Old 28th February 2006, 22:40   #10
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
X5 standard or 4.8i?
gsfent is offline
X5 Thrust arm bushings mottati E39 M5 and E52 Z8 Discussion 48 9th March 2009 04:36
HELP...Part Number Needed for X5 Thrust Arm Bushings amrit50 Off Topic Forum 5 15th November 2005 04:33
PowerFlex Thrust Arm bushes for E34 vchachanidze E34 M5 Discussion 6 19th August 2005 14:16
Replacing Thrust Arm Bushings baf3472 E39 M5 and E52 Z8 Discussion 8 13th August 2005 21:09
Thrust Arm Bushing and Tie Rod Link x703jko E39 M5 and E52 Z8 Discussion 3 4th December 2004 04:55
Page generated in 0.18872 seconds with 11 queries
