Old 27th February 2006, 03:13   #31
Apples
Apples's Avatar
Garage: 2000 M5 Blue
It's going to be interesting to see how the weight bias will change and how much when it finished?
With the back half of the roof going and some aditional stuff like seats that should loose some weight and lower the center of gravity a bit...a good thing for sure.
We'll probably need to make some structual adjustments for the chassis to keeep the torsal strenght up to BMW standards so some weight will be added back?.
If we lenghten the wheel base about 8 inches that should pull the COG back a bit more to the center of the ute and give/keep the car great BMW M5 balance.
There are a few "I don't knows" in this project, but I'm very happy that it will be one great finished product in 07.
APPPES
2000 M5 LeMans blue
Headers/cats/exhaust/KW suspension/sway bars/UUC shifter/UUC clutch/BBS LM 19's.
2003 M5...actually MIB's (master yoda)
2004 Lamborghini Gallardo Pearl Yellow. HRE 840r 19's front 20's rear
2006 Ford GT Heritage blue
www.m5ute.com
Apples is offline
Old 27th February 2006, 03:52   #32
SANguru
SANguru's Avatar
Garage: 07 335i, 04 Ferrari Challenge Stradale, 04 S4 Avant
Sales Feedback: (-1)
good luck with Frankenstein Apples!
SANguru
07 335i
04 Ferrari 360 Challange Stradale - No mods needed!!
coming soon - 03 Lamborghini Murcielago 6spd
04 Audi S4 Avant - lots of mods
SANguru is offline
Old 27th February 2006, 11:20   #33
M5DAL
M5DAL's Avatar
Garage: M5 - Silverstone 11
mmmmm apples and nuts.........anyone with cream?
E60 M5 Silverstone 11 | VW Tiguan 125TSI Turbo
M5: The car above all others. Cash - used to be as good as money once upon a time....
M5DAL is offline
Old 27th February 2006, 19:47   #34
kees
Administrator
Garage: magic moderator wand
Originally Posted by MIB
Kees: Its great to be young and insane.
I know.
kees is offline
Old 6th March 2006, 03:38   #35
Apples
Apples's Avatar
You guys know who makes a 20mm wheel spacer for the M5?
I'm going to widen the rear about 25mm per side and if I get the Neez wheel in a 20 they only come only is certain off set sizes.
The best match would be the largest off set of 25mm, so the same as what I've got now.
It's a 20/10.5/25mm rim V's my BBS LM 19/10/25mm so getting a spacer of about 18 - 20mm will give me that 25mm wider stance then what I've got now.
APPLES
2000 M5 LeMans blue
www.m5ute.com
Apples is offline
Old 6th March 2006, 09:31   #36
kees
Administrator
H&R make spacers with the original BMW self-centering hubs for the E39 M5.
http://www.h-r.com/index.php?inhalt=...t-d&sprache=en
(use product search on the top-right)
Getting good quality spacers is important to avoid vibrations at speed.
kees is offline
Old 6th March 2006, 14:35   #37
Apples
Apples's Avatar
Thanks Kees
I couldn't seem to find what I was looking for...hmm
It was pretty busy with info, but I couldn't nail a 20mm spacer down on the site...hmm
It looks like the DRA spacer would be good as it bolts directly to the hub then you can use the current bolts to pin the wheel to the new spacer....sounds strong.
Cheers APPLES
2000 M5 LeMans blue
www.m5ute.com
Apples is offline
Old 8th March 2006, 10:21   #38
m5am
m5am's Avatar
Garage: n/a
Apples this is great! Do you plan on having a hard tonneau cover over the rear?
You should really incorporate something like this in the back. Especially for you...
That is just a quick example but I think you get the idea. It would be the final step in have a true M5 Ute.
Cant wait to see the final product.
-Sam
m5am is offline
Old 8th March 2006, 10:27   #39
m5am
m5am's Avatar
Garage: n/a
Also, the H&R wheel spacer that you want is part number 2075740. The DR. It would be better to bolt the wheels to the original hubs rather than having the spacer bolt to the hub and then the wheels bolt into the spacer. Only issue that might arise is the need to use lengthed wheel bolts to accommodate the extra 20mm. Hope that helps.
-Sam
m5am is offline
Old 8th March 2006, 11:54   #40
kees
Administrator
Actually the website of the US distributor for H&R is much better for finding the available products you need:
http://www.hrsprings.com/scripts/appguide.php
kees is offline
Wooo tfung gone off deep end... EBMCS03 Off Topic Forum 4492 Yesterday 13:54
New M5 information direct from Mr. Donnie Isley of the BMW Performance Center atomic80 E60 M5 and E61 M5 Touring Discussion 1 15th September 2004 10:45
Press Release no 2: The new V10 engine in the BMW M5: A masterpiece in engine cons... Gustav Most Memorable Threads' 31 4th July 2004 22:23
Page generated in 0.14802 seconds with 12 queries
