there was recently a post on bimmerfest.com with a guy who put an earlier 540 intake on his later car. It is true, i believe, that 97-8 did have larger ports, and can be retrofitted. Later manifolds had smaller diameter ports, for improved low end torque, at the expense of top end. I think the dinan manifold is simply the earlier bmw part. Take a look at the bimmerfest post, or perhaps pm member lscman here as he knows the 540 quite well.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
