How to Remove the Front M5 Bumper - BMW M5 Forum and M6 Forums
Like Tree3Likes
Old 4th February 2006, 05:46   #1
M5BOSS
Banned
Garage: Blue e39 m5. Previously known as MARCVIP, KingM5
Can anyone provide steps to remove the front bumper or a link with exact
steps on an M5?
M5BOSS is offline   Reply With Quote
Old 4th February 2006, 06:06   #2
XrayMD
XrayMD's Avatar
Garage: LeMans Blue M5,Silver X5 & Dk. Silver Mini S
Try this: http://www.louv.tv/cars/m5/ducts/
It's an easy job, but a little easier with two people.
Steve
'02 M5 LeMans Blue:
Supersprint Headers and cats
Dinan Stage III suspension
BeastPower sway bar brackets
Dinan front strut tower brace
RMS short shifter
Llumar window tint (35%)
XrayMD is offline   Reply With Quote
Old 4th February 2006, 18:19   #3
mossy
Garage: 2000 E39 M5, Avus + Tan
Hi,
It was only last weekend I removed my UK spec front bumper from my M5,
Remove three screws from each front wheel liner,
Remove a whole load of screws that hold the bell pan to the bottom of bumper,
Remove two large "torx" screws that hold the bumper to the car, located vertically at the top of the lower grill,
Pull bumper forward BUT NOT RIGHT OFF as you have to reach in and disconnect the pipe for the headlight washers and the wires for the fog lights.
Then pull it right off while making sure it is not snagged on the wheel well liners.
Assuming you are replacing the bumper you will have to remove the aluminium panel from inside the bumper, this is held on with some plastic thingies that are behind the rubbing strips on each corned of the bumper, if you tap the pin in the middle if these thingies towards the front of the bumper the thingies will release.
mossy is offline   Reply With Quote
Old 26th January 2011, 22:02   #4
Misterfive
Misterfive's Avatar
Garage: M5 E60 alpine wht
This link is no good, got another link?
Misterfive is offline   Reply With Quote
Old 26th January 2011, 22:35   #5
pureretro
pureretro's Avatar
Garage: Porsche 997 C2S
Sales Feedback: (3)
I just did this over the weekend and the grease marks are still there under my nails....so.....
1. Remove the 3 hex head bolts (8mm) from each of the wheel liners. These are the ones on the front side of the wheel well, around midway height of the wheel. There is NO NEED to jack up the car, just turn the wheel each way for access.
2. Remove the 4 hex head bolts (10mm) from the wheel liner from bottom of car. You'll need a longer socket to access this. These 4 hold the same plastic liner in place. I believe it's called an "Engine Compartment Liner", but the part number is 51712694832 just for reference.
3. With wheels turned, you can actually just remove both left and right pieces.
4. Undo the fog light electrical connector as they'll be visible once #3 is complete.
5. Undo the Torx bolt that holds the bumper in place. You'll see them only if are looking UPWARDS from under the car. They are silver in color, and located on the top edge of the air intake. I think it may be a T45 size, available from Sears.
6. Once the Torx bolt is removed, yank the bumper forward (put some towel or sheeting on floor to rest your bumper) from EITHER of the edges. Note there is a catch on both sides. Some force is expected.
7. Don't remove the entire bumper just yet. Or if you do, rest it AS CLOSE AS POSSIBLE to the car.
8. Undo the headlight washer hose. Close to the source end of the hose, you'll find a quick-release clip. Just pull with your nails or a pair of needle nose pliers. Plastic is small and brittle, be careful.
9. If you have PDC, there will be 4 wires connecting to each sensor. The connector has a clip which you'll need to undo. Note they all face different directions.
10. Once the hose/wires and loose, remove the whole bumper.
Installation is easier with 2 people as you'll need to align the side "catch". You could stack some books to hold up the bumper to the correct height, so it'd be easier to maneuver.
Good luck!
2001 M5 - Alpine White, BBS RS-GT 19", Muffler Delete, E60 SSK/DSSR, Powerchip tune, functioning Brake Ducts. Otherwise stock.
1996 993 C2 - Speed Yellow, PSS10, Speedline Alesio, Euro Front, RS Splitters, Fister Ceramic Coated Stage 2, RS/Fister SSK, Golden Rod, RoW RS Ride Height
pureretro is offline   Reply With Quote
The Following 6 Users Say Thank You to pureretro For This Useful Post:
BiziM5 (7th July 2012), chowdah (26th January 2011), D-RodM5 (28th January 2011), renn5 (26th July 2011), shopard (26th February 2011), Tiauguinho (26th September 2011)
Old 27th January 2011, 07:48   #6
Kevin The Clean 1
Kevin The Clean 1's Avatar
Garage: 2002 BMW M5 (Sterling Gray)
Sales Feedback: (10)
I definitely want to remove mine this summer...
Kevin The Clean 1 is offline   Reply With Quote
Old 27th January 2011, 23:38   #7
Torquey5
Garage: 2003 ///M5
Sales Feedback: (3)
Definitely a 2 person job, but not too hard. Follow the instructions and you'll be fine, pretty straight forward.
2003 Titanium Silver ///M5
Torquey5 is offline   Reply With Quote
Old 28th January 2011, 04:10   #8
pureretro
pureretro's Avatar
Sales Feedback: (3)
2 person job for the first time, but OK if you prop up the bumper to the right height with some yellow pages. That's the last time I ask my wife to help with the car. Now she's discovered the go fast parts I constantly slap on.
Old 28th January 2011, 04:59   #9
D-RodM5
D-RodM5's Avatar
Garage: 2001 M5 Carbonschwarz Metallic
pureretro, thanks for the info! i wanted to do mine this past summer but the cold weather moved in too quickly...i might add to yours with some pics and tips...maybe i'll get around to it this summer
/// M5
Umnitza VXX
BeastPower Brackets
Schmiedmann Blck Chrm Grills
AFE Power Air Filters
XPEL Protection Film
StopTech ST-40
SlimmBones Finned Diffuser
CarbFib ACS-style Front Splitters
TimmayTips
Mesh Fog Housings
Style 65 275/35/18 x 4
Evolve Alpha-N
D-RodM5 is online now   Reply With Quote
Old 11th February 2011, 11:22   #10
Roninparadise
Roninparadise's Avatar
Garage: 02 M5 Titanium Silver
to grill or not to grill by yourself
Oh now thats just great!! Now you guys post something after I paid my body shop guy 60.00 to do the job for me and put on my new grill piece from Slimm.....I watched them and it was much easier with 2 guys on each side:=)
Roninparadise is offline   Reply With Quote
The Following User Says Thank You to Roninparadise For This Useful Post:
Spintrips (5th January 2012)
M5 E39 Body Style S62 engine FACTS...Long V-10 4 Me E39 M5 and E52 Z8 Discussion 63 5th June 2012 22:00
German AMS magazine tests M5 suspension kits lofstrom E39 M5 and E52 Z8 Discussion 25 11th April 2008 12:24
2 weeks old: My impressions of the SL 55 vs. M5 (very long) Rezf E39 M5 and E52 Z8 Discussion 34 30th September 2006 01:30
Wow! Just had a blast driving a E60 M5 and E55 AMG! ATLANTA M5 E60 M5 and E61 M5 Touring Discussion 36 4th May 2006 06:15
Someone asked which one-->Caddy Ctsv or M5 V-10 4 Me E39 M5 and E52 Z8 Discussion 3 26th March 2004 01:18
