Old 1st February 2006, 20:14   #1
Clem
Clem's Avatar
Garage: 2003 Jet Black Beast
Send a message via MSN to Clem
Thoughts on automatic headlights and headlight washers?
Did my due diligence and all I found is questions on adding automatic headlights. So here is my question:
The 2003 Beast has an "option" to use automatic headlights when you have the dial turned all the way to the left.
Now my problem when it is broad daylight the lights don't turn off. Doesn't that kind of render the term "automatic" useless? The manual states that the lights should go off in bright conditions and should turn on at night, in tunnels etc.... Am I missing something? Does the dealer need to set something? My lights are on all the time.
Now regarding the windshield washer... Any time I pull the stalk towards me the normal windshield washer jets go off but so do the headlamp washers. In my E46 the headlmap washers only went off after the windshield washers had been activated 5 times. Is this something I need to get checked out?
It is my unterstanding that pushing the button on the stalk on the wiper/washer stalk is the "power" wash option. Which is obvious since the windshield washer jets spray for a few seconds so I know I'm not using the wrong feature.
Respect a mans car, a man respects you.
"In every detail, the M5 was a poster child of the M philosophy: superb driving dynamics, luxurious interior and above all, uncompromised performance."
- BMW.ca regarding the E39 M5
~03 ///M5: SchwartzII/Imola, PDC, M-Audio, Rear Sunshade, Split Fold Rear Seats
Appearance: front grille w/
DIY sink drains & brake ducts (not installed)
Interior: ACS shift knob
| ACS park brake handle
Audio: ice>Link Plus
Electronics: hardwired V1 | Lidatek LE-30 (not installed) | BMW BT Kit | BMW V3 RAZR Snap-In
Lighting: Hella Euro headlight | Solaris Diamond Coat signal bulbs | Prolumen 5000K HID foglight conversion (not installed)
Clem is offline
Old 1st February 2006, 20:23   #2
Michael_s
Michael_s's Avatar
Garage: 2007 M5
Clem,
something sounds wrong with the lights. I have mine set to automatic and they only come on when its dark (or getting dark) tunnels, etc. They should not be on during bright sun.
As to the washer, the lights get cleaned once in a while when pulling the stalk (maybe the 5X you mentioned) but all the time when I do the power wash.
Not sure if this is helpful just my experience.
Michael
Michael_s is online now
Old 1st February 2006, 20:30   #3
Clem
Clem's Avatar
Thanks Michael.
Looks like I've got an issue with my auto lights and my washer system. Thanks God I still have warranty till '07.
Thanks for sharing your experiences.
Clem is offline
Old 1st February 2006, 20:59   #4
Anzir
Anzir's Avatar
Garage: Silverstone 2000 M5
I thought the headlight washers only activate when the headlights are on as well. I'm not sure if there is any formula for that or not. On my previous A4, they would pop up each time the stalk was pulled as long as the lights were on.
Anzir is offline
Old 1st February 2006, 21:44   #5
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
are your fog lights on? Turing the fog lights on overrides the 'auto' function, since the car assumes it's foggy, the lights stay on. The auto function is only really auto if the fogs are off. If your fog lamps are off, there is something wrong.
The washers should work about every fifth time you pull the washers with the headlamps on, according to the manual. My car seems to follow this, the headlamp washers do not work each time.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 1st February 2006, 22:22   #6
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Don't Canadian cars have DRL's? Are you sure it is the headlights that are on, and not the reduced current DRL's?
gsfent is offline
Old 1st February 2006, 22:32   #7
Clem
Clem's Avatar
Interesting notions guys....
Canadian cars do have DRLs.
My foglights are on. I will retry the auto feature with the foglights off next time I am in the car.
Seems as though I do have an issue with the headlamp washers going off everytime the stalk is pulled. I don't think the headlights being on would affect this. Maybe I'm wrong.
Clem is offline
Old 1st February 2006, 23:23   #8
jclyman
jclyman's Avatar
I believe the headlight washers go on every 5th time you use the regular washers when the headlights are on ... basically, mottati is exactly correct. My auto headlights work as advertised and I NEVER touch them ... not sure about my headlight washers, but I have to rotate the wiper dial every time I turn on the car for the auto wipers to work ... If I follow that procedure, they also work as advertised.
- Daniel Boorstin
jclyman is offline
Old 2nd February 2006, 02:28   #9
Clem
Clem's Avatar
Ok haven't figured out the washer issue yet but the auto headlight problem was with the foglights. With the fogs on the headlights are defaulted on all the time in "auto mode"
Thanks for everyone's help.
Clem is offline
Old 2nd February 2006, 03:27   #10
Ag Surfer
Ag Surfer's Avatar
Garage: 996 TT - Black
+1
Sean
02 996TT
Cargraphic Exhaust (Loud)
02 M5 - Titanium Silver (Sold to Brother)
UUC V12 Clutch Conversion
Bilstein PSS9 Coilovers
Eibach Sway Bars (front and rear)
Tranny Mounts
Pinnacle Ceramic Tint
Britalman Exhaust
Icelink iPod
BSW Stage 1 (Rainbow)
BSW Rear-deck Sub
Powerchip Gold 91
Ground Control Adjustable Camber Plates
Strong Strut Front Brace (Silver with holes)
04 Ducati Monster S4R
Too many mods to list...
Ag Surfer is offline
Note to rest of world: learn the difference between HIDs and high beams! SilverSBlack5 E39 M5 and E52 Z8 Discussion 34 30th November 2007 03:51
Your Xenon Headlights KBK E39 M5 and E52 Z8 Discussion 17 26th November 2007 08:24
Question for those of you who switched to European headlights ATLANTA M5 E39 M5 and E52 Z8 Discussion 4 3rd November 2005 06:30
POTENTIAL OWNER-CHICAGO VROOM5 E39 M5 and E52 Z8 Discussion 15 17th November 2004 05:15
Bi-Xenon headlights on US 996TT msindi Porsche 911 Turbo and Porsche Panamera Forum | panameraboard.com 1 17th February 2003 21:05
Page generated in 0.19553 seconds with 12 queries
