Old 27th January 2006, 20:48   #1
BKM5
BKM5's Avatar
Garage: 2002 M5 Sterling Gray
Sales Feedback: (4)
Issues with window seals making windows dirty
Has anyone had a problem with the seals at the base of the windows? I washed my car Sunday night, after a wash I don't usually roll the windows down for a while b/c I don't want them to streak, and Monday when I rolled the windows down and then back up they are quite smudged form what I can only assume is dirt on the inside of the lower seal. I've noticed this before but not as much as this time.
Just wondering if this is a common problem?? Are my seals in need of replacement? BTW the car is a 2002 with 25,000 miles, I bought it as an obvious garage queen and it is practically the same for me although my daily driver, so I'd be surprised if the seals should be replaced.
Bernard
BKM5 is offline
Old 27th January 2006, 21:11   #2
Beamer_usa
Beamer_usa's Avatar
Garage: explosive ford pinto
When I had my 540, a pebble or rock got caught in there and everytime I put the window up and down it made a permanant scratch in the window. So brought to the dealer they replaced window. I figured they would be smart enough to see what was causing the problem and correct it before replacing the window. BUT NO, so needless to say the replacement window also had a permanent scratch . So back to the dealer and this time I specified I wanted what was causing the scratch to be found and removed, before replacing the window AGAIN! The second window was on their dime
Dinan Cans
Dinan Software
Beamer_usa is offline
Old 27th January 2006, 21:53   #3
Stickman
Stickman's Avatar
Garage: 2002 Black/Black M5, 91 535i Black/Black
Hello Bernard,
Like you, I usually don't roll down the windows after washing to avoid water streaks on the. But when I have done it, I've never had any smudging as you experienced. I do not think this is a common problem.
I also have a 2002 - now with 27K miles.
Alfred
Stickman is offline
Old 27th January 2006, 22:00   #4
Clem
Clem's Avatar
Garage: 2003 Jet Black Beast
Send a message via MSN to Clem
Happenning on my beast and it also happens on my E46 since new.
Respect a mans car, a man respects you.
"In every detail, the M5 was a poster child of the M philosophy: superb driving dynamics, luxurious interior and above all, uncompromised performance."
- BMW.ca regarding the E39 M5
~03 ///M5: SchwartzII/Imola, PDC, M-Audio, Rear Sunshade, Split Fold Rear Seats
Appearance: front grille w/
DIY sink drains & brake ducts (not installed)
Interior: ACS shift knob
| ACS park brake handle
Audio: ice>Link Plus
Electronics: hardwired V1 | Lidatek LE-30 (not installed) | BMW BT Kit | BMW V3 RAZR Snap-In
Lighting: Hella Euro headlight | Solaris Diamond Coat signal bulbs | Prolumen 5000K HID foglight conversion (not installed)
Clem is offline
Old 27th January 2006, 22:11   #5
J Irwan
J Irwan's Avatar
Garage: 02 CB M5
I just had my driver side window replace recently due to an outside-scratch underwarranty ... (the sratch getting in the way when looking at the outside mirror) .
They also replace the outside rubber trim when they replace the windows.
streak, when rolling down the window shortly after a wash is common/normal ..however I agree sith Stickman that a smudge is not...
Regardz,
J Irwan
02 Carbon Black ///M5
J Irwan is offline
Old 28th January 2006, 16:57   #6
Salty
Salty's Avatar
Garage: 2000 M5 Avus Blue
Bernard
I don't mean to start a panic, but if the smudge is really muddy looking, there is dirt inside the door.
The first question I would ask is, "was there flood damage at some time?"
That is one explanation for a lot of dirt (mud) inside the door iself.
I hope this is not the case for you, but removing the inside door panel would reveal the condition inside your doors.
There is a good thread on how to remove the panel.
Hopefully your smudging problem is something minor, but the "flood" question needs to be asked, especially since it is a Florida car.
Best of luck.
Salty.
Salty is offline
Old 28th January 2006, 20:43   #7
greg
greg's Avatar
Garage: 2000 Anthracite
Or perhaps you detailed and used a rubber/vinyl "protectant" product on the window seals? That stuff will DEFINITELY smudge your windows.
greg is offline
Old 30th January 2006, 16:10   #8
Absinthe
Absinthe's Avatar
Garage: Carbon Black 2000
Send a message via Yahoo to Absinthe
I too have this problem and assume it came from some tech's over use of lube.
Absinthe is offline
Old 1st February 2006, 07:36   #9
EM5PWR
EM5PWR's Avatar
Garage: 02 M5
the title would show a salvage title if it was a flood damaged car ....
EM5PWR is offline
Old 1st February 2006, 07:55   #10
BKH
BKH's Avatar
Garage: 2000 BMW M5 Silverstone
I asked my tech a few years ago about waxy streaking on my windows. He told me it was cosmoline and that he would take care of it on my next service and he did, because I haven't seen it again. I assume the door panel must have come off to effect the cleaning procedure.
BKH is offline
Creaking window seals driving me nuts bbreneman E39 M5 and E52 Z8 Discussion 24 12th June 2008 00:25
Page generated in 0.15417 seconds with 11 queries
